<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Starting my project]]></title><description><![CDATA[<p dir="auto">Hi guys, I would like to know if what is in my mind is correct.</p>
<p dir="auto">To start my project I need a Laptop Monitor right?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/100/starting-my-project</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 07:24:51 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/100.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 May 2016 16:49:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Starting my project on Wed, 18 May 2016 18:20:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paulofernandesjr" aria-label="Profile: paulofernandesjr">@<bdi>paulofernandesjr</bdi></a>, you can install your monitor any which way you want, it’s your project to build and customize. If that’s the easier path to go, then by all means, go with it. Displaying MM on a regular monitor without a two-way mirror in front of that is perfectly fine. My development setup is exactly that, a 27" monitor rotated vertically sitting on my desk with an rPi connected to it. You can just as easy take a 7" Lilliput monitor and stick it ON an existing mirror.</p>
]]></description><link>https://forum.magicmirror.builders/post/776</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/776</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Wed, 18 May 2016 18:20:29 GMT</pubDate></item><item><title><![CDATA[Reply to Starting my project on Wed, 18 May 2016 18:11:23 GMT]]></title><description><![CDATA[<p dir="auto">nice!<br />
Another question, what do you think about install a small monitor on the top of the mirror?<br />
Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/773</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/773</guid><dc:creator><![CDATA[paulofernandesjr]]></dc:creator><pubDate>Wed, 18 May 2016 18:11:23 GMT</pubDate></item><item><title><![CDATA[Reply to Starting my project on Mon, 16 May 2016 21:49:08 GMT]]></title><description><![CDATA[<p dir="auto">I’m using this - <a href="http://www.iiyama.com/gb_en/products/prolite-x2775hds-1/" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.iiyama.com/gb_en/products/prolite-x2775hds-1/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/718</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/718</guid><dc:creator><![CDATA[Mitchfarino]]></dc:creator><pubDate>Mon, 16 May 2016 21:49:08 GMT</pubDate></item><item><title><![CDATA[Reply to Starting my project on Mon, 16 May 2016 21:13:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paulofernandesjr" aria-label="Profile: paulofernandesjr">@<bdi>paulofernandesjr</bdi></a> a laptop monitor might be complicated to connect a Pi to. Most of use just use a simple desktop monitor and remove it’s housing :)</p>
]]></description><link>https://forum.magicmirror.builders/post/713</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/713</guid><dc:creator><![CDATA[paviro]]></dc:creator><pubDate>Mon, 16 May 2016 21:13:51 GMT</pubDate></item><item><title><![CDATA[Reply to Starting my project on Mon, 16 May 2016 20:15:57 GMT]]></title><description><![CDATA[<p dir="auto">I’m using a normal Screen, 27".</p>
]]></description><link>https://forum.magicmirror.builders/post/710</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/710</guid><dc:creator><![CDATA[Wilco89]]></dc:creator><pubDate>Mon, 16 May 2016 20:15:57 GMT</pubDate></item></channel></rss>
