<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Screen Flashes&#x2F;glitches after ~10 min of operation]]></title><description><![CDATA[<p dir="auto">Hello fellow mirror builders. A newbie asking for help :smiling_face_with_open_mouth_cold_sweat:</p>
<p dir="auto">I’ve encountered an issue in which the screen will start to “flash/glitch” after 10 or so minutes of otherwise perfectly fine operation. Link below:</p>
<p dir="auto"><a href="https://youtu.be/y-Qid6nDPNc" target="_blank" rel="noopener noreferrer nofollow ugc">Magic Mirror Glitch</a></p>
<p dir="auto">Now, here are some things that I have tried to troubleshoot:</p>
<ul>
<li>
<p dir="auto">Read somewhere that it could be a hardware issue with the pi itself. I switched to another pi I had from an old project and tested it on that. Exact same issue, and I know that pi should be fine.</p>
</li>
<li>
<p dir="auto">Tried connecting to a different monitor. Same thing was replicated on that monitor too.</p>
</li>
<li>
<p dir="auto">I stopped the mirror (pm2 stop mm) and left the pi running to see if it would happen anyway. Without the Magic Mirror running, it did not glitch.</p>
</li>
</ul>
<p dir="auto">output of <strong>pm2 log MagicMirror</strong>:</p>
<pre><code>pi@black-mirror:~ $ pm2 log MagicMirror
[TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
/home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
0|MagicMir | libGL error: MESA-LOADER: failed to retrieve device information
0|MagicMir | MESA-LOADER: failed to retrieve device information
/home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
0|MagicMir | No helper found for module: weatherforecast.
0|MagicMir | Initializing new module helper ...
0|MagicMir | Module helper loaded: newsfeed
0|MagicMir | All module helpers loaded.
0|MagicMir | Starting server on port 8080 ...
0|MagicMir | Server started ...
0|MagicMir | Connecting socket for: updatenotification
0|MagicMir | Connecting socket for: calendar
0|MagicMir | Starting node helper for: calendar
0|MagicMir | Connecting socket for: newsfeed
0|MagicMir | Starting module: newsfeed
0|MagicMir | Sockets connected &amp; modules started ...
0|MagicMir | Launching application.
0|MagicMir | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/en.canadian%23holiday%40group.v.calendar.google.com/public/basic.ics - Interval: 300000
0|MagicMir | Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
<p dir="auto">Thanks so much for all your help! I’m very new to all this so let me know what I can give you to help out.</p>
]]></description><link>https://forum.magicmirror.builders/topic/10001/screen-flashes-glitches-after-10-min-of-operation</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 11:14:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10001.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 09 Mar 2019 02:22:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Screen Flashes&#x2F;glitches after ~10 min of operation on Mon, 11 Mar 2019 20:30:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jynx13" aria-label="Profile: jynx13">@<bdi>jynx13</bdi></a></p>
<p dir="auto">Glad you got it sorted out. :thumbsup:</p>
]]></description><link>https://forum.magicmirror.builders/post/54103</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54103</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 11 Mar 2019 20:30:50 GMT</pubDate></item><item><title><![CDATA[Reply to Screen Flashes&#x2F;glitches after ~10 min of operation on Mon, 11 Mar 2019 17:41:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> you are my favorite! That link totally did the trick.</p>
<p dir="auto">At the end of the day, it turned out to be that HDMI issue. All I had to do was use the Open GL driver instead of the fake one and use Xrandr to rotate the screen after the fact.</p>
<p dir="auto">So far it has run smoothly without any incident. I’m gonna mark this as solved.</p>
]]></description><link>https://forum.magicmirror.builders/post/54096</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54096</guid><dc:creator><![CDATA[jynx13]]></dc:creator><pubDate>Mon, 11 Mar 2019 17:41:42 GMT</pubDate></item><item><title><![CDATA[Reply to Screen Flashes&#x2F;glitches after ~10 min of operation on Sat, 09 Mar 2019 19:20:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jynx13" aria-label="Profile: jynx13">@<bdi>jynx13</bdi></a><br />
As you are operating your mm in portrait mode, maybe it is an performance issue.</p>
<p dir="auto">Here is a link you can try <a href="https://forum.magicmirror.builders/topic/9707/save-performance-when-rotating-screen-e-g-on-raspberry-pi">https://forum.magicmirror.builders/topic/9707/save-performance-when-rotating-screen-e-g-on-raspberry-pi</a></p>
<p dir="auto">Maybe this helps.</p>
<p dir="auto">AxLED</p>
]]></description><link>https://forum.magicmirror.builders/post/54006</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54006</guid><dc:creator><![CDATA[AxLed]]></dc:creator><pubDate>Sat, 09 Mar 2019 19:20:35 GMT</pubDate></item><item><title><![CDATA[Reply to Screen Flashes&#x2F;glitches after ~10 min of operation on Sat, 09 Mar 2019 02:51:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jynx13" aria-label="Profile: jynx13">@<bdi>jynx13</bdi></a></p>
<p dir="auto">I remember seeing something like this before on the forum. I found this which might help you. <a href="https://forum.magicmirror.builders/topic/8754/strange-glitching-on-hdmi">https://forum.magicmirror.builders/topic/8754/strange-glitching-on-hdmi</a></p>
<p dir="auto">Perhaps someone that has experienced this will chime in for you</p>
]]></description><link>https://forum.magicmirror.builders/post/53970</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53970</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 09 Mar 2019 02:51:00 GMT</pubDate></item></channel></rss>
