<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Strange line in the middle of the monitor]]></title><description><![CDATA[<p dir="auto">Hi friends,<br />
has anybody an idea were this line comes from?<br />
thanks</p>
<p dir="auto">Regards</p>
 * MIT Licensed.
var config = {
	port: 8080,
	language: "de",
	timeFormat: 24,
	units: "metric",
			module: "alert",
			module: "updatenotification",
			position: "top_bar"
			module: "clock",
			position: "top_left"
				/*{//MMM-MVG-LocalTransport
				  module: 'MMM-MVG-LocalTransport',
				  position: 'top_left',
				  header: '
				{//MM-WeatherBackground
				   disabled: false,
						module: "MMM-WeatherBackground",
						opacity: "0.3" //This is the color behind the modules so you can see them better.   Higher the number the darker the color
						//  default in module is set to 0.4
				{//MMM-NOAAA3
							module: 'MMM-NOAA3',
							position: 'top_right',
										provider: "openweather", 							// From list above
										apiKey: ,        // From one of the providers listed above
										airKey: "
										css: "NOAA4",                   				// THIS MUST CONTAIN A CSS STYLE NAME
										userlat: "
										userlon:
				/*{//MMM-WunderGround
						module: 'MMM-WunderGround',
							apikey: 'xxxx,
							pws: 'pws:xxx
							hourly: '3',
							fctext: '1',
							fcdaycount: "2",
							fcdaystart: "0",
							hourlyinterval: "3",
							hourlycount: "2",
							alerttime: 10000,
							lang: "de",
							alerttruncatestring: "english:",
							coloricon: true,
						roundTmpDecs: 1,
						UseCardinals: 0,
						layout: "horizontal",
						iconset: "VCloudsWeatherIcons",
						sysstat: 0
				{//MMM-Timetable
							  //disabled:true,
							  module: "MMM-Timetable",
							  position: "top_center",
								timeFormat: "HH:mm",
								height: "520px",
								width: "180px",
								mode: "5days", // "today", "5days", "7days"
								refreshInterval: 1000*60,
								displayEndTime:false, //whether display endTime on timeline or not.
								schedules: [ //array of schedules
				{//MMM-PublicTransportHafas
				  module: "MMM-PublicTransportHafas",
					stationID: "xxx",                   // Replace with your stationID!
					stationName: "xxx",   // Replace with your station name!
					direction: "xxx",            // Show only departures heading to this station. (A station ID.)
					ignoredLines: [],                 // Which lines should be ignored? (comma-separated list of line names)
					excludedTransportationTypes: [],  // Which transportation types should not be shown on the mirror? (comma-separated list of types) possible values: StN for tram, BuN for bus, s for suburban
					timeToStation: 5,                // How long do you need to walk to the next Station?
					timeInFuture: 120,                 // Show departures for the next *timeInFuture* minutes.
					showColoredLineSymbols: true,     // Want colored line symbols?
					useColorForRealtimeInfo: true,    // Want colored real time information (timeToStation, early)?
					showTableHeadersAsSymbols: true,  // Table Headers as symbols or text?
					maxUnreachableDepartures: 0,      // How many unreachable departures should be shown?
					maxReachableDepartures: 3,        // How many reachable departures should be shown?
					customLineStyles: "leipzig",      // Prefix for the name of the custom css file. ex: Leipzig-lines.css (case sensitive)
					showOnlyLineNumbers: false        // Display only the line number instead of the complete name, i. e. "11" instead of "STR 11"
					stationName: "Possenhofen S-Bahn",   // Replace with your station name!
					direction: "xxxx",                    // Show only departures heading to this station. (A station ID.)
					timeInFuture: 90,                 // Show departures for the next *timeInFuture* minutes.
				{//MMM-Calendar
				module: 'MMM-CalendarExt',
				position: "lower_third", //anywhere. It is not related to real position of view
				config: { // Read below
				system: {
				  show: [/*'current','upcoming',*/'weeks'],
				  locale: 'de', //when omitted, default value would be your system default locale by moment.js
				  showEmptyView: 0,
				  fullDayEventLocalize: 1,
				  redrawInterval: 30*60*1000, //minimum 60000
				  useProfileConfig: 0,
				  startProfile: ''
				 views: {
						current: {
						  title: "Heute",
						  limit: 2,
						upcoming: {
						  title: "Demnächst",
						  limit: 2,
						weeks: {
						  position: "bottom_bar",
						  title: "Überblick",
						  counts: 2,
					url: "webcal://www.ecoline-media.de/ics/bayern_gf.ics",
					styleName: "style1",
					symbol: 'de@em',
				    maxEntries: 50,
					maxDays:365,
					interval: 24*60*60*1000,
					url: "http://localhost:8080/modules/abfallkalender.ics",
					classPattern: [["/Gelber Sack/g", "style7"], ["/Restmülltonne/g", "style18"], ["/Biotonne/g", "style20"],["/Papiertonne/g", "style5"],["/Problemabfälle/g", "style1"]],
					symbol: 'put_litter_in_its_place@em',
					maxEntries: 50,
					maxDays:365,
					url: xxx
					styleName: "style19",
					symbol: 'guitar@em',
				    maxEntries: 50,
					maxDays:365,
					url: xxx
					styleName: "style6",
					symbol: 'man-woman-boy-boy@em',
				    maxEntries: 50,
					maxDays:365,
					url: xxx
					styleName: "style11",
					symbol: 'bike@em',
				    maxEntries: 50,
					maxDays:365,
					url: xxxx
					styleName: "style12",
					symbol: 'birthday@em',
				    maxEntries: 50,
					maxDays:365,
					url: xxxx,
					symbol: 'crown@em',
				    maxEntries: 50,
					maxDays:365,
					url: "xxxx,
					symbol: 'baby@em',
				    maxEntries: 50,
					maxDays:365,
<p dir="auto"><img src="/assets/uploads/files/1552132364071-2019-03-09-12_52_22-fotos.jpg" alt="0_1552132365407_2019-03-09 12_52_22-Fotos.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/10003/strange-line-in-the-middle-of-the-monitor</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 22:11:34 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10003.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 09 Mar 2019 11:49:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Strange line in the middle of the monitor on Sat, 09 Mar 2019 12:40:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vauxdvihl" aria-label="Profile: Vauxdvihl">@<bdi>Vauxdvihl</bdi></a> then I would simply raise a git issue to the dev.<br />
I don’t know this module, but I would say at first it come from the css, I might be worng.<br />
Other user of the module can probably help better , but I think the dev can figure this out quickly</p>
<p dir="auto">Ejay</p>
]]></description><link>https://forum.magicmirror.builders/post/53985</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53985</guid><dc:creator><![CDATA[ejay-ibm]]></dc:creator><pubDate>Sat, 09 Mar 2019 12:40:58 GMT</pubDate></item><item><title><![CDATA[Reply to Strange line in the middle of the monitor on Sat, 09 Mar 2019 12:38:42 GMT]]></title><description><![CDATA[<p dir="auto">It comes from “calendar ext”<br />
If i remove this module the line is not there anymore</p>
]]></description><link>https://forum.magicmirror.builders/post/53984</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53984</guid><dc:creator><![CDATA[Vauxdvihl]]></dc:creator><pubDate>Sat, 09 Mar 2019 12:38:42 GMT</pubDate></item><item><title><![CDATA[Reply to Strange line in the middle of the monitor on Sat, 09 Mar 2019 12:09:57 GMT]]></title><description><![CDATA[<p dir="auto">I would suggest to comment your modules one by one to find out the culprit .<br />
Once target found it will be easier to debug .</p>
]]></description><link>https://forum.magicmirror.builders/post/53983</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53983</guid><dc:creator><![CDATA[ejay-ibm]]></dc:creator><pubDate>Sat, 09 Mar 2019 12:09:57 GMT</pubDate></item></channel></rss>
