<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[My first Mirror (45cm x 65cm) with 24&quot; monitor (Netherlands)]]></title><description><![CDATA[<p dir="auto">After being infected with the Magic Mirror virus, I’ve decided to build one.<br />
It’s my first attempt with an 24" monitor. The frame is prepared for an 27" monitor, but because it’s my first mirror I first started with an old 24".</p>
<p dir="auto"><strong>Used parts:</strong></p>
<ul>
<li>Raspberry Pi 3B+</li>
<li>8GB SD Card</li>
<li>PIR Infrared Motion Sensor (HC-SR501)</li>
<li>Spymirror Silver (45cm x 65 cm) – <a href="https://www.pyrasied.nl/product/spionspiegel/" target="_blank" rel="noopener noreferrer nofollow ugc">Pyrasied</a></li>
<li>HP 24″ LCD Scherm</li>
<li>2x surface-mounted outlet</li>
<li>Wood – inner frame</li>
<li>Wood –  outer frame</li>
</ul>
<p dir="auto"><strong>Modules:</strong></p>
<ul>
<li>Clock</li>
<li>MMM-MyGarbage</li>
<li>MMM-DarkSkyForecast</li>
<li>MMM-MyCalendar</li>
<li>MMM-Remote-Control</li>
<li>MMM-RPI-LED</li>
</ul>
<p dir="auto"><img src="http://magicmirror.tilburgs.com/wp-content/uploads/2019/03/mm-frame1.png" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="http://magicmirror.tilburgs.com/wp-content/uploads/2019/03/mm-frame2.png" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="http://magicmirror.tilburgs.com/wp-content/uploads/2019/03/mm-achterkant.png" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="http://magicmirror.tilburgs.com/wp-content/uploads/2019/03/mm-voor2.png" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/10039/my-first-mirror-45cm-x-65cm-with-24-monitor-netherlands</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 13:17:02 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10039.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 12 Mar 2019 15:51:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to My first Mirror (45cm x 65cm) with 24&quot; monitor (Netherlands) on Fri, 12 Apr 2019 10:41:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a>  I’ve looked at <a href="http://cure-afvalbeheer.nl" target="_blank" rel="noopener noreferrer nofollow ugc">cure-afvalbeheer.nl</a> and <a href="http://hvcinzameling.nl" target="_blank" rel="noopener noreferrer nofollow ugc">hvcinzameling.nl</a>… its looks the same.<br />
I’m going to make a request … someday.</p>
<p dir="auto">Or I’m going to adjust the calendar<br />
<img src="/assets/uploads/files/1555065647464-vncviewer_2019-04-12_12-37-24.png" alt="0_1555065648776_vncviewer_2019-04-12_12-37-24.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/55794</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55794</guid><dc:creator><![CDATA[Screwyoudriver]]></dc:creator><pubDate>Fri, 12 Apr 2019 10:41:33 GMT</pubDate></item><item><title><![CDATA[Reply to My first Mirror (45cm x 65cm) with 24&quot; monitor (Netherlands) on Fri, 12 Apr 2019 10:16:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/screwyoudriver" aria-label="Profile: Screwyoudriver">@<bdi>Screwyoudriver</bdi></a> (Currently) it’s not possible to read ical files. One of the reasons is that every waste company uses it’s own formats / dates / ect. I will gone take a look at that in the near future, but currently I’ve not enought spare time :disappointed_face:</p>
<p dir="auto">En bedankt! :face_with_stuck-out_tongue_winking_eye:</p>
]]></description><link>https://forum.magicmirror.builders/post/55792</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55792</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Fri, 12 Apr 2019 10:16:26 GMT</pubDate></item><item><title><![CDATA[Reply to My first Mirror (45cm x 65cm) with 24&quot; monitor (Netherlands) on Fri, 12 Apr 2019 09:40:41 GMT]]></title><description><![CDATA[<p dir="auto">Is you’re  MMM-MyGarbage based  on a csv file?</p>
<p dir="auto">I am looking for one that can read ical… From HVC :P</p>
<ul>
<li>Mooi spiegeltje! :P</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/55790</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55790</guid><dc:creator><![CDATA[Screwyoudriver]]></dc:creator><pubDate>Fri, 12 Apr 2019 09:40:41 GMT</pubDate></item><item><title><![CDATA[Reply to My first Mirror (45cm x 65cm) with 24&quot; monitor (Netherlands) on Wed, 10 Apr 2019 20:35:14 GMT]]></title><description><![CDATA[<p dir="auto">thanks again.</p>
]]></description><link>https://forum.magicmirror.builders/post/55728</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55728</guid><dc:creator><![CDATA[jmigoliva]]></dc:creator><pubDate>Wed, 10 Apr 2019 20:35:14 GMT</pubDate></item><item><title><![CDATA[Reply to My first Mirror (45cm x 65cm) with 24&quot; monitor (Netherlands) on Tue, 09 Apr 2019 13:30:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jmigoliva" aria-label="Profile: jmigoliva">@<bdi>jmigoliva</bdi></a>, I use a simple python script for the PIR sensor. I’ve used the instructions on <a href="https://www.magicmirrorcentral.com/pir-sensor-raspberry-pi-magic-mirror/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.magicmirrorcentral.com/pir-sensor-raspberry-pi-magic-mirror/</a><br />
This page provided me everything I needed to get the PIR sensor working.</p>
]]></description><link>https://forum.magicmirror.builders/post/55675</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55675</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Tue, 09 Apr 2019 13:30:12 GMT</pubDate></item><item><title><![CDATA[Reply to My first Mirror (45cm x 65cm) with 24&quot; monitor (Netherlands) on Tue, 09 Apr 2019 09:49:32 GMT]]></title><description><![CDATA[<p dir="auto">Hello, just a simple question.<br />
How do you use the pir sensor?<br />
Turn off the screen or leds.<br />
Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/55670</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55670</guid><dc:creator><![CDATA[jmigoliva]]></dc:creator><pubDate>Tue, 09 Apr 2019 09:49:32 GMT</pubDate></item><item><title><![CDATA[Reply to My first Mirror (45cm x 65cm) with 24&quot; monitor (Netherlands) on Tue, 12 Mar 2019 21:42:13 GMT]]></title><description><![CDATA[<p dir="auto">I have the spymirror. If you click on the word Pyrasied, you see what I ordered (As I said in the bullet 😉)</p>
]]></description><link>https://forum.magicmirror.builders/post/54179</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54179</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Tue, 12 Mar 2019 21:42:13 GMT</pubDate></item><item><title><![CDATA[Reply to My first Mirror (45cm x 65cm) with 24&quot; monitor (Netherlands) on Tue, 12 Mar 2019 20:46:55 GMT]]></title><description><![CDATA[<p dir="auto">Hello fellow dutchy!</p>
<p dir="auto">I saw  you also use a mirror from pyrasied. Did you get the spy mirror or something else?</p>
]]></description><link>https://forum.magicmirror.builders/post/54172</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54172</guid><dc:creator><![CDATA[hardbats]]></dc:creator><pubDate>Tue, 12 Mar 2019 20:46:55 GMT</pubDate></item></channel></rss>
