<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Advise for a voice assistant]]></title><description><![CDATA[<p dir="auto">Hello all!<br />
Have been looking around for a suitable voice command for my MM since a while but couldn’t get to pick up one that does/accept some pre-req. as:</p>
<p dir="auto">a bit of privacy as wake up hotword &amp;<br />
interaction with MM &amp;<br />
one that works well, is reliable and not a pain to install :)</p>
<p dir="auto">I have gone trough kalliope, open jarvis, thinking about Mk2assistant bur not tried yet…</p>
<p dir="auto">any sharing/experience would be much appreciated!</p>
<p dir="auto">by the way what do you guys use?</p>
]]></description><link>https://forum.magicmirror.builders/topic/10040/advise-for-a-voice-assistant</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 00:57:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10040.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 12 Mar 2019 21:28:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Advise for a voice assistant on Sun, 07 Apr 2019 19:44:12 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/ejay-ibm" aria-label="Profile: ejay-ibm">@<bdi>ejay-ibm</bdi></a>, was a bit busy last days… couldn’t work on MM. I finally install both MMM-Hotword and Mk2. Works fine but need some fine tuning. Maybe you or anybody can guide/help me on the following:</p>
<p dir="auto">Mk2 side, i still need to understand how it works and how i can “interact” with the other modules… If you have a simple example to show how to “link” Mk2 with any other modules, it would be very helpful!<br />
As usual thx to all for always supporting the community!</p>
]]></description><link>https://forum.magicmirror.builders/post/55549</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55549</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Sun, 07 Apr 2019 19:44:12 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Tue, 19 Mar 2019 21:03:06 GMT]]></title><description><![CDATA[<p dir="auto">finally what i did and what did work is :)</p>
<pre><code>sudo apt-get remove nodered -y
sudo apt-get remove nodejs nodejs-legacy -y
sudo apt-get remove npm -y
sudo curl -sL https://deb.nodesource.com/setup_6.x | sudo bash -
sudo apt-get install -y nodejs
node -v
npm -v
]]></description><link>https://forum.magicmirror.builders/post/54577</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54577</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Tue, 19 Mar 2019 21:03:06 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Tue, 19 Mar 2019 20:41:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a> said in <a href="/post/54574">Advise for a voice assistant</a>:</p>
<p dir="auto">I think i would just install it again but i don’t know if I should do it from /home/pi or from inside /home/pi/MagicMirror ?</p>
<p dir="auto">pi@raspberrypi:~ Here!</p>
]]></description><link>https://forum.magicmirror.builders/post/54575</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54575</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 19 Mar 2019 20:41:48 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Tue, 19 Mar 2019 20:37:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a>, thx for your post. It appears that when i want to check npm version, the system issues :</p>
<pre><code>pi@raspberrypi:~ $ npm -v
-bash: npm: command not found
<p dir="auto">Therefore something went wrong during the system upgrade to stretch.<br />
If i am not wrong npm comes along with nodejs which i have current version</p>
<pre><code>pi@raspberrypi:~ $ nodejs -v
v8.11.1
]]></description><link>https://forum.magicmirror.builders/post/54574</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54574</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Tue, 19 Mar 2019 20:37:56 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Tue, 19 Mar 2019 00:23:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a></p>
<p dir="auto"><a href="https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror</a></p>
]]></description><link>https://forum.magicmirror.builders/post/54536</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54536</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 19 Mar 2019 00:23:07 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Mon, 18 Mar 2019 22:53:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ejay-ibm" aria-label="Profile: ejay-ibm">@<bdi>ejay-ibm</bdi></a>, i wanted to follow your good practice and update MM to latest (ok) and OS to stretch (ok) but now it pm2 won’t start MM automatically as it did in the past… would kindly help me to solve this issue before i can install mk2?<br />
thx alot for any help as well</p>
]]></description><link>https://forum.magicmirror.builders/post/54535</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54535</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Mon, 18 Mar 2019 22:53:10 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Sun, 17 Mar 2019 14:13:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a></p>
<p dir="auto">npm WARN MMM-Hotword@1.1.0 No repository field.<br />
pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install --save snowboy<br />
npm WARN deprecated cryptiles@2.0.5: This version is no longer maintained. Please upgrade to the latest version.<br />
npm WARN deprecated boom@2.10.1: This version is no longer maintained. Please upgrade to the latest version.<br />
npm WARN deprecated hoek@2.16.3: This version is no longer maintained. Please upgrade to the latest version.<br />
npm WARN MMM-Hotword@1.1.0 No repository field.</p>
<p dir="auto">You can ignore some <strong>WARN</strong> unless your program is working.</p>
]]></description><link>https://forum.magicmirror.builders/post/54433</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54433</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 17 Mar 2019 14:13:26 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Sun, 17 Mar 2019 13:44:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a> start mirror in dev mode</p>
<pre><code>npm start dev
<p dir="auto">Select the console tab in the developers window</p>
<p dir="auto">You should see MMM-Hotword sending notifications of the words it recognizes</p>
]]></description><link>https://forum.magicmirror.builders/post/54431</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54431</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 17 Mar 2019 13:44:00 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Sat, 16 Mar 2019 19:38:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ejay-ibm" aria-label="Profile: ejay-ibm">@<bdi>ejay-ibm</bdi></a>, <a class="plugin-mentions-user plugin-mentions-a" href="/user/thestigh" aria-label="Profile: THeStigh">@<bdi>THeStigh</bdi></a>  i have installed MMM-Hotword. I hope correctly? as i got only warning via npm like</p>
<pre><code>npm WARN MMM-Hotword@1.1.0 No repository field.
<p dir="auto">I am not sure how i can test it tho?<br />
Or there is nothing to expect with only MMM-hotword installed?<br />
(sorry if my question is stupid :) )</p>
]]></description><link>https://forum.magicmirror.builders/post/54399</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54399</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Sat, 16 Mar 2019 19:38:48 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Sat, 16 Mar 2019 14:38:27 GMT]]></title><description><![CDATA[<p dir="auto">This is the error code:</p>
<p dir="auto">snowboy@1.3.1 install /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy<br />
node-pre-gyp install --fallback-to-build</p>
<p dir="auto">node-pre-gyp ERR! Tried to download(403): <a href="https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz" target="_blank" rel="noopener noreferrer nofollow ugc">https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz</a><br />
node-pre-gyp ERR! Pre-built binaries not found for snowboy@1.3.1 and node@10.15.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)<br />
node-pre-gyp ERR! Tried to download(undefined): <a href="https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz" target="_blank" rel="noopener noreferrer nofollow ugc">https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz</a><br />
internal/modules/cjs/loader.js:583<br />
throw err;<br />
^</p>
<p dir="auto">Error: Cannot find module ‘nan’<br />
at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)<br />
at Function.Module._load (internal/modules/cjs/loader.js:507:25)<br />
at Module.require (internal/modules/cjs/loader.js:637:17)<br />
at require (internal/modules/cjs/helpers.js:22:18)<br />
at [eval]:1:1<br />
at Script.runInThisContext (vm.js:96:20)<br />
at Object.runInThisContext (vm.js:303:38)<br />
at Object. ([eval]-wrapper:6:22)<br />
at Module._compile (internal/modules/cjs/loader.js:689:30)<br />
at evalScript (internal/bootstrap/node.js:587:27)<br />
gyp: Call to ‘node -e “require(‘nan’)”’ returned exit status 1 while in binding.gyp. while trying to load binding.gyp<br />
throw err;<br />
^</p>
at [eval]:1:1<br />
gyp ERR! configure error<br />
gypgyp ERR! stack Error: <code>gyp</code> failed with exit code: 1<br />
gyp  ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)<br />
ERR!gyp  ERR!configure error<br />
stack     at ChildProcess.emit (events.js:189:13)<br />
gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)<br />
gyp ERR! System Linux 4.14.98-v7+<br />
gyp ERR!gyp stack  Error: <code>gyp</code> failed with exit code: 1<br />
ERR!gyp  commandERR! “/usr/bin/node” “/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “configure” “–fallback-to-build” “–module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node” “–module_name=snowboy” “–module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm”<br />
gyp gypERR!  ERR!stack      at ChildProcess.emit (events.js:189:13)<br />
cwdgyp /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy<br />
ERR! gypstack      at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)<br />
ERR! node -v v10.15.2<br />
gyp ERR! node-gyp -v v3.8.0<br />
gyp ERR! not ok<br />
gyp ERR! command “/usr/bin/node” “/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “configure” “–fallback-to-build” “–module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node” “–module_name=snowboy” “–module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm”<br />
gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy<br />
gyp ERR! node -v v10.15.2<br />
node-pre-gyp ERR! build error<br />
node-pre-gyp ERR! stack Error: Failed to execute ‘/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node --module_name=snowboy --module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm’ (1)<br />
node-pre-gyp ERR! stack     at ChildProcess. (/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/node-pre-gyp/lib/util/compile.js:83:29)<br />
node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:189:13)<br />
node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:970:16)<br />
node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)<br />
node-pre-gyp ERR! System Linux 4.14.98-v7+<br />
node-pre-gyp ERR! command “/usr/bin/node” “/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/.bin/node-pre-gyp” “install” “–fallback-to-build”<br />
node-pre-gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy<br />
node-pre-gyp ERR! node -v v10.15.2<br />
node-pre-gyp ERR! node-pre-gyp -v v0.6.39<br />
node-pre-gyp ERR! not ok<br />
<p dir="auto">npm ERR! code ELIFECYCLE<br />
npm ERR! errno 1<br />
npm ERR! snowboy@1.3.1 install: <code>node-pre-gyp install --fallback-to-build</code><br />
npm ERR! Exit status 1<br />
npm ERR!<br />
npm ERR! Failed at the snowboy@1.3.1 install script.<br />
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.</p>
]]></description><link>https://forum.magicmirror.builders/post/54387</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54387</guid><dc:creator><![CDATA[thedoorsfanatic]]></dc:creator><pubDate>Sat, 16 Mar 2019 14:38:27 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Thu, 14 Mar 2019 15:32:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedoorsfanatic" aria-label="Profile: thedoorsfanatic">@<bdi>thedoorsfanatic</bdi></a> Snowboy can be tricky, but @sean has made some good troubleshooting guides on the page for MMM-Hotword. But you can delete the MMM-Hotword folder and try to re-install it following these instructions to do it quite manually. If it fails, you at least will get a clear picture of where it actually failed:</p>
<pre><code>cd ~/MagicMirror/modules/
sudo apt-get install libmagic-dev libatlas-base-dev sox libsox-fmt-all
git clone https://github.com/eouia/MMM-Hotword.git
cd MMM-Hotword
npm install
cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
npm install --save-dev electron-rebuild
npm install nan
./node_modules/.bin/electron-rebuild
]]></description><link>https://forum.magicmirror.builders/post/54265</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54265</guid><dc:creator><![CDATA[THeStigh]]></dc:creator><pubDate>Thu, 14 Mar 2019 15:32:18 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Thu, 14 Mar 2019 15:09:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thestigh" aria-label="Profile: THeStigh">@<bdi>THeStigh</bdi></a><br />
I am using a Raspi 3 B+ and latest release of Stretch and MagicMirror.<br />
I am a newbie and though I tried all the troubleshooting tipps described I wasn’t able to install Hotword and snowboy.</p>
]]></description><link>https://forum.magicmirror.builders/post/54262</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54262</guid><dc:creator><![CDATA[thedoorsfanatic]]></dc:creator><pubDate>Thu, 14 Mar 2019 15:09:20 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Thu, 14 Mar 2019 14:32:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedoorsfanatic" aria-label="Profile: thedoorsfanatic">@<bdi>thedoorsfanatic</bdi></a></p>
<p dir="auto">What hardware and OS are you using ?</p>
]]></description><link>https://forum.magicmirror.builders/post/54259</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54259</guid><dc:creator><![CDATA[THeStigh]]></dc:creator><pubDate>Thu, 14 Mar 2019 14:32:25 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Thu, 14 Mar 2019 09:10:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedoorsfanatic" aria-label="Profile: thedoorsfanatic">@<bdi>thedoorsfanatic</bdi></a><br />
Give me a telegram When you are stuck on. Telegram:@eouia</p>
]]></description><link>https://forum.magicmirror.builders/post/54239</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54239</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 14 Mar 2019 09:10:47 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Thu, 14 Mar 2019 08:39:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ejay-ibm" aria-label="Profile: ejay-ibm">@<bdi>ejay-ibm</bdi></a><br />
all right, thanks, I will try it again but usually it failed when trying to install snowboy</p>
]]></description><link>https://forum.magicmirror.builders/post/54238</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54238</guid><dc:creator><![CDATA[thedoorsfanatic]]></dc:creator><pubDate>Thu, 14 Mar 2019 08:39:58 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Thu, 14 Mar 2019 07:55:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedoorsfanatic" aria-label="Profile: thedoorsfanatic">@<bdi>thedoorsfanatic</bdi></a><br />
I think the Readme here : <a href="https://github.com/eouia/MMM-Hotword/" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/eouia/MMM-Hotword/</a><br />
is pretty clear, that is what I followed and I have it working directly.<br />
check out the Tip section to include hotword in the mk2 assistant and you should be good.<br />
If you run into issue you can share your config file and I can have a look .</p>
<p dir="auto">Ejay</p>
]]></description><link>https://forum.magicmirror.builders/post/54237</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54237</guid><dc:creator><![CDATA[ejay-ibm]]></dc:creator><pubDate>Thu, 14 Mar 2019 07:55:45 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Thu, 14 Mar 2019 07:38:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ejay-ibm" aria-label="Profile: ejay-ibm">@<bdi>ejay-ibm</bdi></a><br />
I was able to run MK2assistant but never managed to install Hotword.<br />
Is there a tutorial out there which shows me how to do it, absolute beginner style?</p>
]]></description><link>https://forum.magicmirror.builders/post/54236</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54236</guid><dc:creator><![CDATA[thedoorsfanatic]]></dc:creator><pubDate>Thu, 14 Mar 2019 07:38:10 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Thu, 14 Mar 2019 06:44:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thestigh" aria-label="Profile: THeStigh">@<bdi>THeStigh</bdi></a> Indeed, using it on a Rasp 3 b+ fully up to date.</p>
]]></description><link>https://forum.magicmirror.builders/post/54235</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54235</guid><dc:creator><![CDATA[ejay-ibm]]></dc:creator><pubDate>Thu, 14 Mar 2019 06:44:32 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Thu, 14 Mar 2019 01:06:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ejay-ibm" aria-label="Profile: ejay-ibm">@<bdi>ejay-ibm</bdi></a> Yeah, works perfect if you keep to the ‘correct’ hardware and OS like Pi or ATB.</p>
]]></description><link>https://forum.magicmirror.builders/post/54231</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54231</guid><dc:creator><![CDATA[THeStigh]]></dc:creator><pubDate>Thu, 14 Mar 2019 01:06:04 GMT</pubDate></item><item><title><![CDATA[Reply to Advise for a voice assistant on Wed, 13 Mar 2019 21:09:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a> Hi,<br />
I would definitely recommend Mk2assistant + Hotword module.<br />
Ejay</p>
]]></description><link>https://forum.magicmirror.builders/post/54227</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54227</guid><dc:creator><![CDATA[ejay-ibm]]></dc:creator><pubDate>Wed, 13 Mar 2019 21:09:33 GMT</pubDate></item></channel></rss>
