<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[the installation does not end]]></title><description><![CDATA[<p dir="auto">hi all<br />
I have never managed to install magicmirror with rasbian Stretch, so I took the jessie (full) with all upgrade, but when I install magic miror, the system seems to no longer respond …<br />
<img src="/assets/uploads/files/1552816914277-magic.jpg" alt="0_1552816909479_magic.jpg" class=" img-fluid img-markdown" /><br />
after the question “do you want to use pm2 for auto starting”<br />
and then I have lines "extract: moment: sill extract moment@ ^ 2.22.2 extracted to … and it stays like that, thank you for helping me :-)<br />
Jean-Philippe</p>
]]></description><link>https://forum.magicmirror.builders/topic/10064/the-installation-does-not-end</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 02:38:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10064.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 17 Mar 2019 10:02:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to the installation does not end on Sun, 17 Mar 2019 14:42:33 GMT]]></title><description><![CDATA[<p dir="auto">oups… seems all is ok now<br />
i restarted the raspberry,</p>
<p dir="auto">run again npm install<br />
cp config/config.js.sample config/config.js<img src="/assets/uploads/files/1552833746496-2019-03-17-15_40_54-raspberrypi.png" alt="0_1552833744501_2019-03-17 15_40_54-raspberrypi.png" class=" img-fluid img-markdown" /><br />
npm start<br />
and tadaaa… work in progress for configuration ^_^<br />
thanks<br />
Jean-Philippe</p>
]]></description><link>https://forum.magicmirror.builders/post/54434</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54434</guid><dc:creator><![CDATA[Atelier-Made-in-iKi]]></dc:creator><pubDate>Sun, 17 Mar 2019 14:42:33 GMT</pubDate></item></channel></rss>
