<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Weather & Newsfeed]]></title><description><![CDATA[<p dir="auto">Hi, i’m not great at this, so i’m hoping for your help in here.<br />
i have tried alot to get this to work but no luck.</p>
<p dir="auto">i live in denmark europe, i’m trying to get a danish news feed and local weather on my magic mirror 2<br />
this is my config file and it only shows the clock and my google calendar.</p>
<p dir="auto">hope that someone have an idea for me :-)</p>
<p dir="auto">thanks guys</p>
<pre><code>	module: "compliments",
			position: "lower_third"
			module: "currentweather",
				locationID: "",  //ID from https://openweathermap.org/sample/; unzip the gz file and find your city
				appid: "YOUR_OPENWEATHER_API_KEY"
			module: "weatherforecast",
			header: "Weather Forecast",
				locationID: "",  //ID from https://openweathermap.org/city/6543928
				appid: "6543928"
			module: "newsfeed",
			position: "bottom_bar",
				feeds: [
						title: "TV2 Nyheder",
						url: "http://tv2.dk/profiles/tv2/modules/custom/t2zerowing/pkg/img/apple-touch-icon-precomposed.png&lt;/url"
				showSourceTitle: true,
				showPublishDate: true
]]></description><link>https://forum.magicmirror.builders/topic/10096/weather-newsfeed</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 19:26:42 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10096.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Mar 2019 17:34:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Weather & Newsfeed on Wed, 20 Mar 2019 19:45:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sonicgoose" aria-label="Profile: sonicgoose">@<bdi>sonicgoose</bdi></a></p>
<p dir="auto">i’ve got it to work now, thanks to you all :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/54635</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54635</guid><dc:creator><![CDATA[jobjha1973]]></dc:creator><pubDate>Wed, 20 Mar 2019 19:45:20 GMT</pubDate></item><item><title><![CDATA[Reply to Weather & Newsfeed on Wed, 20 Mar 2019 19:38:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sonicgoose" aria-label="Profile: sonicgoose">@<bdi>sonicgoose</bdi></a><br />
thank you, i just did it now and put the API in the config but still no luck :-(</p>
]]></description><link>https://forum.magicmirror.builders/post/54633</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54633</guid><dc:creator><![CDATA[jobjha1973]]></dc:creator><pubDate>Wed, 20 Mar 2019 19:38:07 GMT</pubDate></item><item><title><![CDATA[Reply to Weather & Newsfeed on Wed, 20 Mar 2019 19:26:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jobjha1973" aria-label="Profile: jobjha1973">@<bdi>jobjha1973</bdi></a> You need to register with <a href="https://home.openweathermap.org/users/sign_up" target="_blank" rel="noopener noreferrer nofollow ugc">OpenWeather</a> and they will provide you with an API key.</p>
]]></description><link>https://forum.magicmirror.builders/post/54632</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54632</guid><dc:creator><![CDATA[sonicgoose]]></dc:creator><pubDate>Wed, 20 Mar 2019 19:26:40 GMT</pubDate></item><item><title><![CDATA[Reply to Weather & Newsfeed on Wed, 20 Mar 2019 19:13:50 GMT]]></title><description><![CDATA[<p dir="auto">@Sean<br />
i’ve tried to look for that code size but can only find the short one so it still wont work, i’ll try again tomorrow</p>
]]></description><link>https://forum.magicmirror.builders/post/54631</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54631</guid><dc:creator><![CDATA[jobjha1973]]></dc:creator><pubDate>Wed, 20 Mar 2019 19:13:50 GMT</pubDate></item><item><title><![CDATA[Reply to Weather & Newsfeed on Wed, 20 Mar 2019 18:56:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jobjha1973" aria-label="Profile: jobjha1973">@<bdi>jobjha1973</bdi></a><br />
AppID(API key) Should look similar with this; <code>616969b353bc8c809aab84d4033c4f72</code></p>
]]></description><link>https://forum.magicmirror.builders/post/54629</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54629</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 20 Mar 2019 18:56:41 GMT</pubDate></item><item><title><![CDATA[Reply to Weather & Newsfeed on Wed, 20 Mar 2019 18:54:15 GMT]]></title><description><![CDATA[<p dir="auto">@Sean<br />
okey thanks i’ll try and try again, and return if it don’t work</p>
]]></description><link>https://forum.magicmirror.builders/post/54628</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54628</guid><dc:creator><![CDATA[jobjha1973]]></dc:creator><pubDate>Wed, 20 Mar 2019 18:54:15 GMT</pubDate></item><item><title><![CDATA[Reply to Weather & Newsfeed on Wed, 20 Mar 2019 18:43:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jobjha1973" aria-label="Profile: jobjha1973">@<bdi>jobjha1973</bdi></a><br />
I think 2614478 or 6543928 wil be locationId, not appId.<br />
AppId might be more long. It seems being missed in your configuration.</p>
]]></description><link>https://forum.magicmirror.builders/post/54627</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54627</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 20 Mar 2019 18:43:55 GMT</pubDate></item><item><title><![CDATA[Reply to Weather & Newsfeed on Wed, 20 Mar 2019 18:21:46 GMT]]></title><description><![CDATA[<p dir="auto">maybe i need to put the code in</p>
<p dir="auto">locationID: “6543928”,  like this?</p>
<p dir="auto">hmm nope</p>
]]></description><link>https://forum.magicmirror.builders/post/54624</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54624</guid><dc:creator><![CDATA[jobjha1973]]></dc:creator><pubDate>Wed, 20 Mar 2019 18:21:46 GMT</pubDate></item><item><title><![CDATA[Reply to Weather & Newsfeed on Wed, 20 Mar 2019 18:17:01 GMT]]></title><description><![CDATA[<p dir="auto">@Sean said in <a href="/post/54617">Weather &amp; Newsfeed</a>:</p>
<p dir="auto"><a href="http://feeds.tv2.dk/nyhederne_seneste/rss%E2%80%9D" target="_blank" rel="noopener noreferrer nofollow ugc">http://feeds.tv2.dk/nyhederne_seneste/rss”</a></p>
<p dir="auto">Thanks Sean, now the news feed work but not the weather yet.</p>
<p dir="auto">can you see if i’m doing something wrong```<br />
module: “compliments”,<br />
position: “lower_third”<br />
},<br />
{<br />
module: “currentweather”,<br />
position: “top_right”,<br />
config: {<br />
locationID: “”,  //ID from <a href="https://openweathermap.org/city/6543928" target="_blank" rel="noopener noreferrer nofollow ugc">https://openweathermap.org/city/6543928</a>; unzip the gz file and find your city<br />
appid: “6543928”<br />
}<br />
},<br />
{<br />
module: “weatherforecast”,<br />
header: “Weather Forecast”,<br />
config: {<br />
locationID: “”,  //ID from <a href="https://openweathermap.org/city/6543928" target="_blank" rel="noopener noreferrer nofollow ugc">https://openweathermap.org/city/6543928</a><br />
}<br />
},<br />
{<br />
module: “newsfeed”,<br />
position: “bottom_bar”,<br />
config: {<br />
feeds: [<br />
{<br />
title: “TV2 Nyheder”,<br />
url: “<a href="http://feeds.tv2.dk/nyhederne_seneste/rss" target="_blank" rel="noopener noreferrer nofollow ugc">http://feeds.tv2.dk/nyhederne_seneste/rss</a>”<br />
}<br />
],<br />
showSourceTitle: true,<br />
showPublishDate: true</p>
<pre><code></code></pre>
]]></description><link>https://forum.magicmirror.builders/post/54623</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54623</guid><dc:creator><![CDATA[jobjha1973]]></dc:creator><pubDate>Wed, 20 Mar 2019 18:17:01 GMT</pubDate></item><item><title><![CDATA[Reply to Weather & Newsfeed on Wed, 20 Mar 2019 17:58:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jobjha1973" aria-label="Profile: jobjha1973">@<bdi>jobjha1973</bdi></a><br />
Put your local information in <code>currentWeather</code> part also.<br />
And, As far as I know, <code>TV2 Nyheader</code> rss feed url is “<a href="http://feeds.tv2.dk/nyhederne_seneste/rss" target="_blank" rel="noopener noreferrer nofollow ugc">http://feeds.tv2.dk/nyhederne_seneste/rss</a>”</p>
]]></description><link>https://forum.magicmirror.builders/post/54617</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54617</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 20 Mar 2019 17:58:26 GMT</pubDate></item></channel></rss>
