<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[pm2 Error auto starting]]></title><description><![CDATA[<p dir="auto">I’ve followed all the instructions mentioned <a href="https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">here</a></p>
<p dir="auto">This is the error that I’m facing</p>
<pre><code>pi@raspberrypi:~ $ pm2 start mm.sh
[PM2] Applying action restartProcessId on app [mm](ids: 0)
[PM2] [mm](0) ✓
[PM2] Process successfully started
│ Name │ id │ mode │ status  │ ↺   │ cpu │ memory │
│ mm   │ 0  │ fork │ stopped │ 136 │ 0%  │ 0 B    │
 Use `pm2 show &lt;id|name&gt;` to get more details about an app
pi@raspberrypi:~ $ pm2 logs mm
[TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
/home/pi/.pm2/logs/mm-out.log last 15 lines:
/home/pi/.pm2/logs/mm-error.log last 15 lines:
0|mm       | bash: /home/pi/mm.sh: Permission denied
^C
pi@raspberrypi:~ $
]]></description><link>https://forum.magicmirror.builders/topic/10105/pm2-error-auto-starting</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 16:16:26 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10105.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 21 Mar 2019 17:57:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to pm2 Error auto starting on Thu, 21 Mar 2019 20:03:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/qqqqqqqq" aria-label="Profile: qqqqqqqq">@<bdi>qqqqqqqq</bdi></a><br />
<a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> is not marked executable at all or for the user trying to execute it…</p>
<p dir="auto">to make it executable for the user… but not any other user<br />
use the command</p>
<pre><code>chmod 766  /home/pi/mm.sh
<p dir="auto">to make it executable by ANY user  (root/pi/…)<br />
do</p>
<pre><code>chmod +x /home/pi/mm.sh
]]></description><link>https://forum.magicmirror.builders/post/54695</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54695</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 21 Mar 2019 20:03:51 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 Error auto starting on Fri, 22 Mar 2019 19:43:54 GMT]]></title><description><![CDATA[<p dir="auto">I would say is more ‘sure’ when you are in the right folder to do :</p>
<p dir="auto">sudo chmod +x ./mm.sh</p>
]]></description><link>https://forum.magicmirror.builders/post/54747</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54747</guid><dc:creator><![CDATA[ejay-ibm]]></dc:creator><pubDate>Fri, 22 Mar 2019 19:43:54 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 Error auto starting on Fri, 22 Mar 2019 17:49:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/qqqqqqqq" aria-label="Profile: qqqqqqqq">@<bdi>qqqqqqqq</bdi></a> said in <a href="/post/54732">pm2 Error auto starting</a>:</p>
<p dir="auto">But I wonder why it didn’t give <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> the permission when i used the command.</p>
<p dir="auto">what folder where u in at the time you issued the chmod +x <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a>?</p>
<p dir="auto">if MagicMirror , then  it would have failed…   should have given and error</p>
]]></description><link>https://forum.magicmirror.builders/post/54740</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54740</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 22 Mar 2019 17:49:08 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 Error auto starting on Fri, 22 Mar 2019 15:22:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/54695">pm2 Error auto starting</a>:</p>
use the command</p>
do</p>
<p dir="auto">Thanks! Worked perfectly.<br />
<pre><code>chmod +x mm.sh
]]></description><link>https://forum.magicmirror.builders/post/54732</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54732</guid><dc:creator><![CDATA[qqqqqqqq]]></dc:creator><pubDate>Fri, 22 Mar 2019 15:22:50 GMT</pubDate></item><item><title><![CDATA[Reply to pm2 Error auto starting on Thu, 21 Mar 2019 20:03:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/qqqqqqqq" aria-label="Profile: qqqqqqqq">@<bdi>qqqqqqqq</bdi></a><br />
use the command</p>
do</p>
]]></description><link>https://forum.magicmirror.builders/post/54695</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/54695</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 21 Mar 2019 20:03:51 GMT</pubDate></item></channel></rss>
