<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Test modul in jsFiddle or liveweave]]></title><description><![CDATA[<p dir="auto">Hi<br />
If I need to test, let’s say the default clock in MM.<br />
Is it then possible to set up an environment in jsFiddle or liveweave, so I can take the index.html layout and add that to the HTML field, and then add the clock.js to the JS field and then test the settings?</p>
<p dir="auto">If yes, can someone add an example?</p>
]]></description><link>https://forum.magicmirror.builders/topic/10117/test-modul-in-jsfiddle-or-liveweave</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 23:06:18 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10117.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 Mar 2019 17:33:21 GMT</pubDate><ttl>60</ttl></channel></rss>
