<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[My first mirror build]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">I’m an avid Raspberry Pi user, but didn’t have any incentive to build a magic mirror until recently a 23" TV I had in my study blew up one evening (literally went bang!).</p>
<p dir="auto">I took a chance on the LCD panel itself still being OK and ordered a compatible driver board from China on ebay. After some issues issues with the LVDS cable (an adaptor was needed) I managed to get the screen working. Unfortunately some of the LED backlights in one corner are faulty, but I’ve simply kept that area blank and it looks fine.</p>
<p dir="auto">I used Pilkington Mirroview glass, which works brilliantly (shout out to <a href="http://www.mirrorsandglass.co.uk/shop/made-to-measure-mirroview-cut-to-size" target="_blank" rel="noopener noreferrer nofollow ugc">Mirrors and Glass</a> here in the UK who were excellent).</p>
<p dir="auto">Despite complaints on the forum, I’ve used a Pi 3 A+, which works without issue, though I don’t have any particularly resource hungry modules.</p>
<p dir="auto">Some pics:</p>
<p dir="auto"><img src="https://i.ibb.co/gm2nTvG/IMG-3802.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://i.ibb.co/ZhR4YBK/IMG-3810.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://i.ibb.co/7XtbRrF/IMG-3791.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">So that I only needed one cable running to the mirror, I’ve used a single 12v, 5amp PSU. The LCD is powered directly by the 12v and I’ve used a DC-DC step down board to power the Pi.</p>
<p dir="auto">I’ve attached a Pimoroni OnOff shim and wired that to a momentary switch at the bottom of the frame.</p>
<p dir="auto">There is also a PIR protruding from the bottom of the frame, it faces straight down, but it has a 100 degree FOV and picks up movement without issue. It’s powered directly from the 12v as the 5v pins on the Pi are covered by the shim.</p>
<p dir="auto"><img src="https://i.ibb.co/kyDZ9qp/IMG-3818.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">The frame consists of moulding glued to strip wood, which leaves a lip for the glass and panel to rest against.</p>
<p dir="auto"><img src="https://i.ibb.co/KWkzsGW/IMG-3812.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">The PIR and the power switch at the bottom of the frame.</p>
<p dir="auto">This is my most ambitious Raspberry Pi project yet, and I had a lot of fun putting it together. Let me know what you think or if you have any questions.</p>
<p dir="auto">Cheers,</p>
<p dir="auto">Simon.</p>
]]></description><link>https://forum.magicmirror.builders/topic/10118/my-first-mirror-build</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 04:17:36 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10118.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 Mar 2019 18:47:11 GMT</pubDate><ttl>60</ttl></channel></rss>
