<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Blank screen after updating tonight...]]></title><description><![CDATA[<p dir="auto">I just updated my MagicMirror, and I now get a blank screen. There is only one instance running, and when I stop and start the process through pm2, I get the desktop and the blank screen again, respectively.</p>
<p dir="auto">I used:</p>
<p dir="auto">git pull</p>
<p dir="auto">and received a message about package-lock.json needing to be stashed. I backed it up, then used:</p>
<p dir="auto">git reset --hard<br />
git pull<br />
npm install</p>
<p dir="auto">Immediately upon reboot, I received a blank screen. I also copied package-lock.bak to package-lock.json, and I still get the blank screen. I’m running both pihole and MagicMirror. Any assistance would be greatly appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/topic/10191/blank-screen-after-updating-tonight</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 23:12:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10191.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Apr 2019 04:41:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Blank screen after updating tonight... on Wed, 03 Apr 2019 12:39:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/55287">Blank screen after updating tonight...</a>:</p>
<p dir="auto">git stash</p>
<p dir="auto">Thanks for your quick reply and your tipp that worked for me.<br />
After git stash I updated MM to 2.7.1 and then I cd 'ed into every installed module and did npm install.</p>
<p dir="auto">Excuse my bad English and sorry to bug you and thanks again fpr your time!</p>
<p dir="auto">Noob from Germany</p>
]]></description><link>https://forum.magicmirror.builders/post/55368</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55368</guid><dc:creator><![CDATA[thedoorsfanatic]]></dc:creator><pubDate>Wed, 03 Apr 2019 12:39:26 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after updating tonight... on Wed, 03 Apr 2019 05:26:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> LIKE A CHARM.  All is well with Assistant and Hotword, just as you describe.  MMM-Buttons also required and npm install, as well as MMM-PIR-Sensor.  So, basically, maintenance on all the plugins.</p>
]]></description><link>https://forum.magicmirror.builders/post/55351</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55351</guid><dc:creator><![CDATA[nakedrabbit]]></dc:creator><pubDate>Wed, 03 Apr 2019 05:26:16 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after updating tonight... on Wed, 03 Apr 2019 00:21:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks for these leads! Now that you mention it, why would I not need to do this… I’ll let you know how it goes…</p>
]]></description><link>https://forum.magicmirror.builders/post/55332</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55332</guid><dc:creator><![CDATA[nakedrabbit]]></dc:creator><pubDate>Wed, 03 Apr 2019 00:21:27 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after updating tonight... on Tue, 02 Apr 2019 22:04:35 GMT]]></title><description><![CDATA[<p dir="auto">I got it working by removing MMM-PIR-Sensor and reinstalling it. Simply updating it did not work.</p>
]]></description><link>https://forum.magicmirror.builders/post/55316</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55316</guid><dc:creator><![CDATA[uatuba]]></dc:creator><pubDate>Tue, 02 Apr 2019 22:04:35 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after updating tonight... on Tue, 02 Apr 2019 15:11:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedoorsfanatic" aria-label="Profile: thedoorsfanatic">@<bdi>thedoorsfanatic</bdi></a> you can pout those changes away temporarily with</p>
<p dir="auto">after installing, if u want those back,</p>
<p dir="auto">git stash pop</p>
]]></description><link>https://forum.magicmirror.builders/post/55287</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55287</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Apr 2019 15:11:43 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after updating tonight... on Tue, 02 Apr 2019 15:05:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Sorry, I am a beginner from Germany. Maybe you can help.</p>
<p dir="auto">It won’t let me update because of this message:<br />
“Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden”<br />
which translates to:<br />
“Your local changes in the following files would be overwritten by the merge”<br />
and then it lists like 5 or 6 package.json files. What can I do?</p>
<p dir="auto">Danke/Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/55286</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55286</guid><dc:creator><![CDATA[thedoorsfanatic]]></dc:creator><pubDate>Tue, 02 Apr 2019 15:05:41 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after updating tonight... on Tue, 02 Apr 2019 15:01:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/55280">Blank screen after updating tonight...</a>:</p>
<p dir="auto">./node_modules/.bin/electron-rebuild</p>
<p dir="auto">thank you <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  , the problem was solved  you need to make the electron-rebuilt into mmm-assistantMk2 and mmm-hotword too</p>
]]></description><link>https://forum.magicmirror.builders/post/55285</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55285</guid><dc:creator><![CDATA[ines]]></dc:creator><pubDate>Tue, 02 Apr 2019 15:01:05 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after updating tonight... on Tue, 02 Apr 2019 14:27:02 GMT]]></title><description><![CDATA[<p dir="auto">note that you will have the same problem in Assistant too</p>
<p dir="auto">see</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/10189/mmm-assistantmk2-breaks-with-mm-v2-7-0">https://forum.magicmirror.builders/topic/10189/mmm-assistantmk2-breaks-with-mm-v2-7-0</a></p>
]]></description><link>https://forum.magicmirror.builders/post/55281</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55281</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Apr 2019 14:27:02 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after updating tonight... on Tue, 02 Apr 2019 14:24:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ines" aria-label="Profile: ines">@<bdi>ines</bdi></a>  ok, you need to follow the instructions in hotword for the electron-rebuild</p>
<pre><code>But maybe in kiosk mode, you may meet some error like this;
Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/electron-v2.0-linux-arm/snowboy.node'
In that case, you need to rebuild some binaries to match with Electron version.
cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
npm install --save-dev electron-rebuild
npm install nan
./node_modules/.bin/electron-rebuild   # It could takes dozens sec.
]]></description><link>https://forum.magicmirror.builders/post/55280</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55280</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Apr 2019 14:24:57 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after updating tonight... on Tue, 02 Apr 2019 14:21:03 GMT]]></title><description><![CDATA[<h2>WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/electron-v3.0-linux-arm/snowboy.node’</h2>
<p dir="auto">this the error that i ve faced after the new update</p>
]]></description><link>https://forum.magicmirror.builders/post/55279</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55279</guid><dc:creator><![CDATA[ines]]></dc:creator><pubDate>Tue, 02 Apr 2019 14:21:03 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after updating tonight... on Tue, 02 Apr 2019 14:19:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ines" aria-label="Profile: ines">@<bdi>ines</bdi></a> ok, we need to see the error… open the developers window</p>
<p dir="auto">how do you start MM, with PM2, or something else…</p>
<p dir="auto">the pm2.log might help too if used</p>
]]></description><link>https://forum.magicmirror.builders/post/55278</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55278</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Apr 2019 14:19:08 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after updating tonight... on Tue, 02 Apr 2019 14:12:22 GMT]]></title><description><![CDATA[<p dir="auto">thank you , i make the npm install in every module with package.json but he doesn’t work</p>
]]></description><link>https://forum.magicmirror.builders/post/55277</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55277</guid><dc:creator><![CDATA[ines]]></dc:creator><pubDate>Tue, 02 Apr 2019 14:12:22 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after updating tonight... on Tue, 02 Apr 2019 14:06:02 GMT]]></title><description><![CDATA[<p dir="auto">use ctrl-shift-i to open the developers window and select the console tab, scroll around to see any errors, (red text)</p>
<p dir="auto">also, if you updated, u generally need to re-run npm install in every module that has a package,json file.<br />
The Hotword and Assistant will need electron-rebuild more than likely</p>
]]></description><link>https://forum.magicmirror.builders/post/55276</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55276</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Apr 2019 14:06:02 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after updating tonight... on Tue, 02 Apr 2019 14:00:46 GMT]]></title><description><![CDATA[<p dir="auto">I have faced  the same problem , any solution ?</p>
]]></description><link>https://forum.magicmirror.builders/post/55275</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55275</guid><dc:creator><![CDATA[ines]]></dc:creator><pubDate>Tue, 02 Apr 2019 14:00:46 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after updating tonight... on Tue, 02 Apr 2019 07:32:18 GMT]]></title><description><![CDATA[<p dir="auto">Mine also not working on RPi3, and removing the exact same plugin does not remedy the situation.  Sample config does make it behave, but it seems like there might be another plugin issue?</p>
<p dir="auto">I’m running (or used to run)</p>
<p dir="auto">Remote Control<br />
DarkSky Forecast<br />
Network Scanner<br />
Volumio Playing<br />
Roomba<br />
Notification Trigger<br />
Hotword<br />
Assistant Mk2<br />
Buttons<br />
and PIR sensor.</p>
<p dir="auto">I upgraded because Electron was leaking or whatever it does to slow to a crawl, and slushing back to a previous Electron had not fixed the problem.  Too tired to try them all one at a time right now, but I guess I’ll go to it tomorrow.</p>
]]></description><link>https://forum.magicmirror.builders/post/55255</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55255</guid><dc:creator><![CDATA[nakedrabbit]]></dc:creator><pubDate>Tue, 02 Apr 2019 07:32:18 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen after updating tonight... on Tue, 02 Apr 2019 05:18:31 GMT]]></title><description><![CDATA[<p dir="auto">UPDATE: It’s the PIR-Sensor Module which isn’t working. When I delete it from the config file, everything works great. When I add it back, the screen is completely blank. It’s the same config that was working before the update.</p>
]]></description><link>https://forum.magicmirror.builders/post/55252</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55252</guid><dc:creator><![CDATA[uatuba]]></dc:creator><pubDate>Tue, 02 Apr 2019 05:18:31 GMT</pubDate></item></channel></rss>
