<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[force_s3tc_enable overridden by environment.]]></title><description><![CDATA[[[topic:post-is-deleted]]]]></description><link>https://forum.magicmirror.builders/topic/10195/force_s3tc_enable-overridden-by-environment</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 18:57:10 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10195.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Apr 2019 17:00:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to force_s3tc_enable overridden by environment. on Wed, 03 Apr 2019 03:23:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/siddhartha" aria-label="Profile: siddhartha">@<bdi>siddhartha</bdi></a> could u mark your issues solved… thx</p>
]]></description><link>https://forum.magicmirror.builders/post/55347</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55347</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 03 Apr 2019 03:23:50 GMT</pubDate></item><item><title><![CDATA[Reply to force_s3tc_enable overridden by environment. on Wed, 03 Apr 2019 01:46:12 GMT]]></title><description><![CDATA[<p dir="auto">No problem. Thank you :)</p>
]]></description><link>https://forum.magicmirror.builders/post/55343</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55343</guid><dc:creator><![CDATA[siddhartha]]></dc:creator><pubDate>Wed, 03 Apr 2019 01:46:12 GMT</pubDate></item><item><title><![CDATA[Reply to force_s3tc_enable overridden by environment. on Wed, 03 Apr 2019 01:42:19 GMT]]></title><description><![CDATA[<p dir="auto">Cool. Thx for the feedback</p>
]]></description><link>https://forum.magicmirror.builders/post/55341</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55341</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 03 Apr 2019 01:42:19 GMT</pubDate></item><item><title><![CDATA[Reply to force_s3tc_enable overridden by environment. on Wed, 03 Apr 2019 01:35:47 GMT]]></title><description><![CDATA[<p dir="auto">After upgrading OS. i faced problem with display.<br />
i fixed some problem with<br />
npm audit fix --force.</p>
<p dir="auto">Then i shifted to VNC<br />
used DISPLAY=:1 and then the magicmirror started.<br />
but now there ware two process running at time.</p>
<p dir="auto">MagicMirror with DISPLAY=:0<br />
MM with DISPLAY=:1</p>
<p dir="auto">so using pm2 i deleted MagicMirror and gave reboot.<br />
everything worked perfectly. so i changed back DISPLAY=:0 in MM.</p>
<p dir="auto">and gave reboot again…</p>
<p dir="auto">and problem solved. no black screen no error :)</p>
]]></description><link>https://forum.magicmirror.builders/post/55340</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55340</guid><dc:creator><![CDATA[siddhartha]]></dc:creator><pubDate>Wed, 03 Apr 2019 01:35:47 GMT</pubDate></item><item><title><![CDATA[Reply to force_s3tc_enable overridden by environment. on Tue, 02 Apr 2019 23:13:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/siddhartha" aria-label="Profile: siddhartha">@<bdi>siddhartha</bdi></a> so, what does 'does not start ’ mean?</p>
<p dir="auto">npm start<br />
in the Magic Mirror folder gets the command prompt back? or not<br />
screen goes black, or not</p>
<p dir="auto">have you done</p>
<pre><code>export DISPLAY=:0
npm start
<p dir="auto">on my mm I also have to</p>
<pre><code>npm --enable-transparent-visuals --disable-gpu start
]]></description><link>https://forum.magicmirror.builders/post/55326</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55326</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Apr 2019 23:13:06 GMT</pubDate></item><item><title><![CDATA[Reply to force_s3tc_enable overridden by environment. on Tue, 02 Apr 2019 19:39:57 GMT]]></title><description><![CDATA[<p dir="auto">Chromium. yeah i have seen many reports on google about this chrome/chromium :(</p>
<p dir="auto">I think must be issue with the GPU or else the syntax . i am looking into it but cant find anything :(</p>
]]></description><link>https://forum.magicmirror.builders/post/55304</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55304</guid><dc:creator><![CDATA[siddhartha]]></dc:creator><pubDate>Tue, 02 Apr 2019 19:39:57 GMT</pubDate></item><item><title><![CDATA[Reply to force_s3tc_enable overridden by environment. on Tue, 02 Apr 2019 23:09:57 GMT]]></title><description><![CDATA[<p dir="auto">Are u using chrome as the browser?<br />
This error has been reported there frequently.</p>
<p dir="auto">Search force_s3tc_enable in google</p>
]]></description><link>https://forum.magicmirror.builders/post/55303</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55303</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Apr 2019 23:09:57 GMT</pubDate></item><item><title><![CDATA[Reply to force_s3tc_enable overridden by environment. on Tue, 02 Apr 2019 18:06:07 GMT]]></title><description><![CDATA[<p dir="auto">Thanks i will try that and if solves that i will post it here :)</p>
<p dir="auto">there is one more issue npm lodash.update vulnerability. i don’t think so that those are connected to each other.</p>
]]></description><link>https://forum.magicmirror.builders/post/55301</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55301</guid><dc:creator><![CDATA[siddhartha]]></dc:creator><pubDate>Tue, 02 Apr 2019 18:06:07 GMT</pubDate></item><item><title><![CDATA[Reply to force_s3tc_enable overridden by environment. on Tue, 02 Apr 2019 18:02:52 GMT]]></title><description><![CDATA[<p dir="auto">Sorry, no idea.<br />
You could disable all modules (<code>disabled: true,</code>) and then enable them one by one (<code>disabled: false,</code>) until the issue appears.</p>
<p dir="auto">But also run <code>cd ~/MagicMirror; npm run config:check</code> to be sure you do not have a config issue.<br />
Perhaps the ATTENTION is not related to the config.</p>
]]></description><link>https://forum.magicmirror.builders/post/55300</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55300</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Tue, 02 Apr 2019 18:02:52 GMT</pubDate></item><item><title><![CDATA[Reply to force_s3tc_enable overridden by environment. on Tue, 02 Apr 2019 17:53:40 GMT]]></title><description><![CDATA[<p dir="auto">i get warning but my MM doesn’t start i have tried so many solutions. but still no effect. do you have any idea where should i look for those HTML or chromium files ?</p>
]]></description><link>https://forum.magicmirror.builders/post/55299</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55299</guid><dc:creator><![CDATA[siddhartha]]></dc:creator><pubDate>Tue, 02 Apr 2019 17:53:40 GMT</pubDate></item><item><title><![CDATA[Reply to force_s3tc_enable overridden by environment. on Tue, 02 Apr 2019 17:43:05 GMT]]></title><description><![CDATA[<p dir="auto">I get the warning too, but MM does start.<br />
There are several hits using google.<br />
Seems to be a Chromium and HTML syntax issue.</p>
]]></description><link>https://forum.magicmirror.builders/post/55298</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55298</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Tue, 02 Apr 2019 17:43:05 GMT</pubDate></item></channel></rss>
