<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Issue when I start the mirror]]></title><description><![CDATA[<p dir="auto">I have that error  and a black screen when i start the mirror. I have already tried <code>npm rebuild</code>  but it doesn’t work. Anyone can help me ?</p>
<pre><code>Starting MagicMirror: v2.7.1
Loading config ...
Loading module helpers ...
Check MagicMirror version for node helper 'MMM-GoogleBirthdaysProvider' - Minimum version:  2.6.0 - Current version: 2.7.1
Version is ok!
Module helper loaded: MMM-GoogleBirthdaysProvider
Module helper loaded: MMM-NowPlayingOnSpotify
Module helper loaded: MMM-AVStock
Module helper loaded: mmm-hue-lights
Module helper loaded: MMM-Formula1
Module helper loaded: MMM-nasaastropic
Module helper loaded: MMM-Remote-Control
No helper found for module: MMM-Carousel.
No helper found for module: MMM-chromecast.
Module helper loaded: MMM-Screencast
Module helper loaded: MMM-Instagram
Module helper loaded: MMM-TweetsByTimelineOrList
No helper found for module: MMM-Snow.
WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
Expected directory: electron-v3.0-linux-arm-glibc
Found: [electron-v2.0-linux-arm-glibc, node-v59-linux-arm-glibc]
This problem can often be fixed by running "npm rebuild" on the current system
Original error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node'
Version is ok!
App threw an error during load
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:63:3)
    at Module._compile (internal/modules/cjs/loader.js:711:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
    at Module.load (internal/modules/cjs/loader.js:620:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
    at Function.Module._load (internal/modules/cjs/loader.js:551:3)
    at Module.require (internal/modules/cjs/loader.js:658:17)
    at require (internal/modules/cjs/helpers.js:20:18)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12)
{ Error: Failed to load gRPC binary module because it was not installed for the current system
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12) code: 'MODULE_NOT_FOUND' }
Launching application.
]]></description><link>https://forum.magicmirror.builders/topic/10196/issue-when-i-start-the-mirror</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 14:41:22 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10196.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Apr 2019 19:36:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Issue when I start the mirror on Tue, 02 Apr 2019 20:19:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/sonicgoose" aria-label="Profile: sonicgoose">@<bdi>sonicgoose</bdi></a> Ok thank you, I will do it</p>
]]></description><link>https://forum.magicmirror.builders/post/55309</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55309</guid><dc:creator><![CDATA[Vit73520]]></dc:creator><pubDate>Tue, 02 Apr 2019 20:19:09 GMT</pubDate></item><item><title><![CDATA[Reply to Issue when I start the mirror on Tue, 02 Apr 2019 19:45:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sonicgoose" aria-label="Profile: sonicgoose">@<bdi>sonicgoose</bdi></a> yes, both</p>
]]></description><link>https://forum.magicmirror.builders/post/55307</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55307</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Apr 2019 19:45:32 GMT</pubDate></item><item><title><![CDATA[Reply to Issue when I start the mirror on Tue, 02 Apr 2019 19:42:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/vit73520" aria-label="Profile: Vit73520">@<bdi>Vit73520</bdi></a> Do the same for MMM-Hotword if you’re using it, with the snowboy node module.</p>
]]></description><link>https://forum.magicmirror.builders/post/55306</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55306</guid><dc:creator><![CDATA[sonicgoose]]></dc:creator><pubDate>Tue, 02 Apr 2019 19:42:20 GMT</pubDate></item><item><title><![CDATA[Reply to Issue when I start the mirror on Tue, 02 Apr 2019 19:40:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vit73520" aria-label="Profile: Vit73520">@<bdi>Vit73520</bdi></a> there are instructions in the assistant install about how to get rid of this.</p>
<p dir="auto">I had to erase node_modules<br />
Change package.json electron version to 3.0.13 and npm install, and then use electron-rebuild to make it work</p>
]]></description><link>https://forum.magicmirror.builders/post/55305</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55305</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Apr 2019 19:40:56 GMT</pubDate></item></channel></rss>
