<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wish i never updated to 2.7.1 Black Screen!]]></title><description><![CDATA[<p dir="auto">I have no clue what happened to this during the git pull all i get is a black screen i really don’t want to install everything from scratch it was working good before apart from the electron memory leak, i take it that electron was autoMagically installed with the latest MM version. Help Please, see log</p>
<pre><code>pi@raspberrypi:~ $ npm start dev
npm ERR! path /home/pi/package.json
npm ERR! code ENOENT
npm ERR! errno -2
npm ERR! syscall open
npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
npm ERR! enoent This is related to npm not being able to find a file.
npm ERR! enoent
npm ERR!     /home/pi/.npm/_logs/2019-04-02T20_51_53_518Z-debug.log
<p dir="auto">Debug Log Below</p>
<pre><code>0 info it worked if it ends with ok
1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start', 'dev' ]
2 info using npm@6.4.1
3 info using node@v10.15.3
4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
5 verbose stack Error: ENOENT: no such file or directory, open '/home/pi/package.json'
6 verbose cwd /home/pi
7 verbose Linux 4.14.98-v7+
8 verbose argv "/usr/bin/node" "/usr/bin/npm" "start" "dev"
9 verbose node v10.15.3
10 verbose npm  v6.4.1
11 error path /home/pi/package.json
12 error code ENOENT
13 error errno -2
14 error syscall open
15 error enoent ENOENT: no such file or directory, open '/home/pi/package.json'
16 error enoent This is related to npm not being able to find a file.
17 verbose exit [ -2, true ]
]]></description><link>https://forum.magicmirror.builders/topic/10197/wish-i-never-updated-to-2-7-1-black-screen</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 21:12:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10197.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Apr 2019 21:03:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wish i never updated to 2.7.1 Black Screen! on Wed, 03 Apr 2019 03:24:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dazza120" aria-label="Profile: dazza120">@<bdi>dazza120</bdi></a> could u mark your issues solved… thx</p>
]]></description><link>https://forum.magicmirror.builders/post/55348</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55348</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 03 Apr 2019 03:24:20 GMT</pubDate></item><item><title><![CDATA[Reply to Wish i never updated to 2.7.1 Black Screen! on Wed, 03 Apr 2019 01:27:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dazza120" aria-label="Profile: dazza120">@<bdi>dazza120</bdi></a> glad u r working ok</p>
]]></description><link>https://forum.magicmirror.builders/post/55338</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55338</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 03 Apr 2019 01:27:07 GMT</pubDate></item><item><title><![CDATA[Reply to Wish i never updated to 2.7.1 Black Screen! on Wed, 03 Apr 2019 01:26:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks for your help I’m sorted now apart from Calendar not coming up with dates, I saved the config so it was just a case of re downloading everything again :(</p>
]]></description><link>https://forum.magicmirror.builders/post/55337</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55337</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Wed, 03 Apr 2019 01:26:20 GMT</pubDate></item><item><title><![CDATA[Reply to Wish i never updated to 2.7.1 Black Screen! on Wed, 03 Apr 2019 00:50:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dazza120" aria-label="Profile: dazza120">@<bdi>dazza120</bdi></a> edit the MM/package.json<br />
what version is there??   should say 2.8-develop</p>
<p dir="auto">also  show me the results of git remote -v<br />
is your git copy of a fork you might have made?</p>
]]></description><link>https://forum.magicmirror.builders/post/55335</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55335</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 03 Apr 2019 00:50:14 GMT</pubDate></item><item><title><![CDATA[Reply to Wish i never updated to 2.7.1 Black Screen! on Wed, 03 Apr 2019 00:11:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Yeah it isn’t installing the new MM it says its on the latest version 2.6.0 not 2.7.1 I get to this HEAD is now at b508a62 Merge pull request #1632 from MichMich/fix-2.7.1  and then when i do git pull it says its already on the latest :(</p>
]]></description><link>https://forum.magicmirror.builders/post/55331</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55331</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Wed, 03 Apr 2019 00:11:37 GMT</pubDate></item><item><title><![CDATA[Reply to Wish i never updated to 2.7.1 Black Screen! on Tue, 02 Apr 2019 23:55:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dazza120" aria-label="Profile: dazza120">@<bdi>dazza120</bdi></a>   git reset hard blows you back to the last time u did a git pull</p>
<p dir="auto">then u do a git pull to get the latest<br />
then npm install<br />
then npm install in any module folder that has a  package.json file</p>
<p dir="auto">snowboy (MMM-voice and MMM-Hotword) is a pain in the rear…<br />
usually requires a special command (electron-rebuild) to rebuild some part at the new electron level…<br />
see instructions in MMM-Hotword</p>
]]></description><link>https://forum.magicmirror.builders/post/55330</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55330</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Apr 2019 23:55:25 GMT</pubDate></item><item><title><![CDATA[Reply to Wish i never updated to 2.7.1 Black Screen! on Tue, 02 Apr 2019 23:35:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Hi yes i done that but for some reason its stayed on 2.6.0 and said that was the latest version is there anyway to push it to install the latest version i have done git hard rest but dont know where to go form there.</p>
]]></description><link>https://forum.magicmirror.builders/post/55329</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55329</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Tue, 02 Apr 2019 23:35:57 GMT</pubDate></item><item><title><![CDATA[Reply to Wish i never updated to 2.7.1 Black Screen! on Tue, 02 Apr 2019 23:26:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dazza120" aria-label="Profile: dazza120">@<bdi>dazza120</bdi></a> ok, just want to check again…</p>
<p dir="auto">after doing the git pull in the MM folder<br />
you then<br />
did npm install  while in the MM folder, right?  you must</p>
<p dir="auto">as you have MMM-voice installed<br />
u need to do npm install there too</p>
]]></description><link>https://forum.magicmirror.builders/post/55328</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55328</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Apr 2019 23:26:02 GMT</pubDate></item><item><title><![CDATA[Reply to Wish i never updated to 2.7.1 Black Screen! on Tue, 02 Apr 2019 23:15:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> right thanks here it is</p>
<pre><code>pi@raspberrypi:~/MagicMirror $ npm start &amp;
[1] 1486
&gt; magicmirror@2.6.0 start /home/pi/MagicMirror
&gt; sh run-start.sh
Starting MagicMirror: v2.6.0
Loading config ...
Loading module helpers ...
No helper found for module: MMM-pages.
No helper found for module: MMM-page-indicator.
Module helper loaded: MMM-Remote-Control-Repository
WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'lmtool'
App threw an error during load
    at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
    at Function.Module._load (internal/modules/cjs/loader.js:528:25)
    at Module.require (internal/modules/cjs/loader.js:658:17)
    at require (internal/modules/cjs/helpers.js:20:18)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:32:16)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-voice/node_helper.js:373:3)
    at Module._compile (internal/modules/cjs/loader.js:711:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
    at Module.load (internal/modules/cjs/loader.js:620:32)
{ Error: Cannot find module 'lmtool'
    at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
Launching application.
]]></description><link>https://forum.magicmirror.builders/post/55327</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55327</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Tue, 02 Apr 2019 23:15:06 GMT</pubDate></item><item><title><![CDATA[Reply to Wish i never updated to 2.7.1 Black Screen! on Tue, 02 Apr 2019 22:51:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dazza120" aria-label="Profile: dazza120">@<bdi>dazza120</bdi></a> said in <a href="/post/55323">Wish i never updated to 2.7.1 Black Screen!</a>:</p>
<p dir="auto">pi@raspberrypi</p>
<p dir="auto">but u have to start in MagicMirror folder</p>
<p dir="auto">cd ~/MagicMirror<br />
npm start &amp;</p>
]]></description><link>https://forum.magicmirror.builders/post/55325</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55325</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Apr 2019 22:51:25 GMT</pubDate></item><item><title><![CDATA[Reply to Wish i never updated to 2.7.1 Black Screen! on Tue, 02 Apr 2019 22:39:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> this is what i get</p>
<pre><code>npm start &amp;
[1] 1352
pi@raspberrypi:~ $ npm ERR! path /home/pi/package.json
npm ERR! errno -2
npm ERR! enoent
npm ERR!     /home/pi/.npm/_logs/2019-04-02T22_38_46_083Z-debug.log
]]></description><link>https://forum.magicmirror.builders/post/55323</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55323</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Tue, 02 Apr 2019 22:39:25 GMT</pubDate></item><item><title><![CDATA[Reply to Wish i never updated to 2.7.1 Black Screen! on Tue, 02 Apr 2019 22:35:28 GMT]]></title><description><![CDATA[<p dir="auto">hue-lights doesn’t have a package.json, so no npm install there</p>
<p dir="auto">npm WARN MMM-pages No repository field.<br />
npm WARN MMM-pages No license field.</p>
<p dir="auto">package.json doesn’t have some typically useful fields… no problems</p>
<p dir="auto">so, one thing to try also is</p>
<p dir="auto">npm start &amp;</p>
<p dir="auto">which will start MM AND give u back the terminal window…</p>
<p dir="auto">I get lots of messages as things start up there…</p>
]]></description><link>https://forum.magicmirror.builders/post/55322</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55322</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Apr 2019 22:35:28 GMT</pubDate></item><item><title><![CDATA[Reply to Wish i never updated to 2.7.1 Black Screen! on Tue, 02 Apr 2019 22:32:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> hi mate im getting this from MMM-pages</p>
<pre><code>npm WARN MMM-pages No repository field.
audited 275 packages in 6.448s
found 0 vulnerabilities
<p dir="auto">and this from mmm-hue-lights and a couple of others</p>
<pre><code>npm WARN saveError ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
npm WARN modules No description
npm WARN modules No repository field.
npm WARN modules No README data
npm WARN modules No license field.
audited 1 package in 1.465s
]]></description><link>https://forum.magicmirror.builders/post/55321</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55321</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Tue, 02 Apr 2019 22:32:46 GMT</pubDate></item><item><title><![CDATA[Reply to Wish i never updated to 2.7.1 Black Screen! on Tue, 02 Apr 2019 22:16:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dazza120" aria-label="Profile: dazza120">@<bdi>dazza120</bdi></a> slow down</p>
<p dir="auto">What errors. Let’s work thru ut</p>
]]></description><link>https://forum.magicmirror.builders/post/55319</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55319</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Apr 2019 22:16:10 GMT</pubDate></item><item><title><![CDATA[Reply to Wish i never updated to 2.7.1 Black Screen! on Tue, 02 Apr 2019 22:13:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> done that some folders didn’t like that though kept coming up with errors, think I’m going to have to reinstall it from scratch :(</p>
]]></description><link>https://forum.magicmirror.builders/post/55317</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55317</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Tue, 02 Apr 2019 22:13:42 GMT</pubDate></item><item><title><![CDATA[Reply to Wish i never updated to 2.7.1 Black Screen! on Tue, 02 Apr 2019 22:00:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dazza120" aria-label="Profile: dazza120">@<bdi>dazza120</bdi></a> ok, after the git pull, u have to do npm install again in the mm folder</p>
<p dir="auto">Mm is short for MagicMirror</p>
]]></description><link>https://forum.magicmirror.builders/post/55315</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55315</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Apr 2019 22:00:44 GMT</pubDate></item><item><title><![CDATA[Reply to Wish i never updated to 2.7.1 Black Screen! on Tue, 02 Apr 2019 21:56:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> hi thanks but when I do that I’m greated with a white screen that says the dev screen has disconnected and would reload, the pi is just totally locked after that, only powering it down would can get it back to where I can use terminal again :(</p>
]]></description><link>https://forum.magicmirror.builders/post/55314</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55314</guid><dc:creator><![CDATA[dazza120]]></dc:creator><pubDate>Tue, 02 Apr 2019 21:56:45 GMT</pubDate></item><item><title><![CDATA[Reply to Wish i never updated to 2.7.1 Black Screen! on Tue, 02 Apr 2019 21:17:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dazza120" aria-label="Profile: dazza120">@<bdi>dazza120</bdi></a> said in <a href="/post/55311">Wish i never updated to 2.7.1 Black Screen!</a>:</p>
<p dir="auto">pi@raspberrypi:~ $ npm start dev</p>
<p dir="auto">you need to</p>
<pre><code>cd MagicMirror
<p dir="auto">THEN do the</p>
<pre><code>npm start dev
]]></description><link>https://forum.magicmirror.builders/post/55313</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55313</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Apr 2019 21:17:20 GMT</pubDate></item></channel></rss>
