<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Alerts not showing?]]></title><description><![CDATA[<p dir="auto">I’ve never seen the default alert module show anything and just wondering if its working. The documentation supposedly says it shows a default message on startup but I don’t see it?</p>
<p dir="auto">My config.js just has the module name as shown in the example config.</p>
]]></description><link>https://forum.magicmirror.builders/topic/1020/alerts-not-showing</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 03:30:45 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1020.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 19 Nov 2016 13:45:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Alerts not showing? on Sun, 20 Nov 2016 15:51:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clumsy_ninja" aria-label="Profile: clumsy_ninja">@<bdi>clumsy_ninja</bdi></a> Yup documentation is wrong there, the default is <code>false</code>. Edit: made a PR to correct this.</p>
]]></description><link>https://forum.magicmirror.builders/post/8273</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8273</guid><dc:creator><![CDATA[Jopyth]]></dc:creator><pubDate>Sun, 20 Nov 2016 15:51:10 GMT</pubDate></item><item><title><![CDATA[Reply to Alerts not showing? on Sun, 20 Nov 2016 08:07:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jopyth" aria-label="Profile: Jopyth">@<bdi>Jopyth</bdi></a> said in <a href="/post/8232">Alerts not showing?</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clumsy_ninja" aria-label="Profile: clumsy_ninja">@<bdi>clumsy_ninja</bdi></a> Have look at the documentation: You need to set welcome_message in the config (a string).</p>
<p dir="auto">The documentation says it has a default value so I didn’t enter one. I manually entered a startup message and it showed so all good. Thanks.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a> Is this a documentation error that should be corrected? or not working properly?</p>
]]></description><link>https://forum.magicmirror.builders/post/8251</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8251</guid><dc:creator><![CDATA[clumsy_ninja]]></dc:creator><pubDate>Sun, 20 Nov 2016 08:07:57 GMT</pubDate></item><item><title><![CDATA[Reply to Alerts not showing? on Sat, 19 Nov 2016 15:15:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clumsy_ninja" aria-label="Profile: clumsy_ninja">@<bdi>clumsy_ninja</bdi></a> Have look at the <a href="https://github.com/MichMich/MagicMirror/tree/master/modules/default/alert" target="_blank" rel="noopener noreferrer nofollow ugc">documentation</a>: You need to set <code>welcome_message</code> in the config (a string).</p>
]]></description><link>https://forum.magicmirror.builders/post/8232</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8232</guid><dc:creator><![CDATA[Jopyth]]></dc:creator><pubDate>Sat, 19 Nov 2016 15:15:41 GMT</pubDate></item></channel></rss>
