<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Frame supplier in Germany]]></title><description><![CDATA[<p dir="auto">I made a frame on my own, but it does not look so good.<br />
Does anyone know a carpenter in Germany who could build the frame for a reasonably price?</p>
<p dir="auto">I want to attach the frame to the wall, it should be removable by using a screw and an eyelet attached to the mirror.<br />
the Display and the screen should be removable, in case the screen is not working anymore.</p>
<p dir="auto">Screen and Display have approximately the same size (the glass is a bit smaller but that should be fine when the frame has an overhang.</p>
<p dir="auto">I asked a few Carpenters near Düsseldorf, but did not get a reasonable response or quote.<br />
The last one made an offer of 950€ for the frame. But thats way to much.</p>
<p dir="auto">BTW: i asked the same guy a year ago, then he told me another price, but this offer was not written down by him, so now he “can’t remember anymore”</p>
]]></description><link>https://forum.magicmirror.builders/topic/1022/frame-supplier-in-germany</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 14:31:20 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1022.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 19 Nov 2016 17:19:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Frame supplier in Germany on Sat, 19 Nov 2016 20:23:48 GMT]]></title><description><![CDATA[<p dir="auto">Depending on what size you need, just check out IKEA’s picture frames. I use RIBBA 10x15cm frames for my small “wall projects” with arduinos, they have a few centimeters of space between the frame and the wall to put all the electronics. I don’t know if it’s thick enough for the average monitor to fit in, but you should give it a look. The problem is, since they are built to be cheap, that any frames over 40x70cm (i think) are built with a plexiglass front instead of real glass. That means they are not able to hold the weight of a glass two-way mirror without modification.</p>
]]></description><link>https://forum.magicmirror.builders/post/8240</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8240</guid><dc:creator><![CDATA[dbahn25]]></dc:creator><pubDate>Sat, 19 Nov 2016 20:23:48 GMT</pubDate></item><item><title><![CDATA[Reply to Frame supplier in Germany on Sat, 19 Nov 2016 17:39:32 GMT]]></title><description><![CDATA[<p dir="auto">What about a frame from aluminum?<br />
I got a mirror with aluminum frame from Ikea and asked a friend to shorten it on the size I need.<br />
He could keep the mirror glass and I’ve got my frame.</p>
]]></description><link>https://forum.magicmirror.builders/post/8239</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8239</guid><dc:creator><![CDATA[done]]></dc:creator><pubDate>Sat, 19 Nov 2016 17:39:32 GMT</pubDate></item></channel></rss>
