<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[MMM-RTSP] Module is only showing half of the stream?]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">First of, thanks for a great module. I finally got it running with VLC.<br />
However, I have one issue that I just can´t solve.<br />
The module is only showing half of the picture/stream.</p>
<p dir="auto">When viewing the stream thru VLC it looks ok and from the info I can verify that the size is:<br />
640 x 360. And the stream thru VLC looks just fine.</p>
<p dir="auto">No matter how I try to tweak the config, this module has decided that it should be enough to show me the left part of the stream. I,e. 50% of the picture is gone?!</p>
<p dir="auto">Config as follow:</p>
<pre><code>module: "MMM-RTSPStream",
                       position: "middle_center",
                       header: "CAM",
                                           autoStart: true,
                                           rotateStreams: false,
                                           rotateStreamTimeout: 10,
                                           moduleWidth: 640,
                                           moduleHeight: 360,
                                           localPlayer: 'vlc',
                                           remotePlayer: 'none',
                                           showSnapWhenPaused: false,
                                           remoteSnaps: false,
                                           shutdownDelay: 12,
                                               stream1: {
        url: 'rtsp://USER:PASSWD@IP:10554/udp/av0_1',
        frameRate: 'undefined',
                                                               //    hdUrl: 'rtsp://USER:PASSWD@IP:10554/udp/av0_1',
        width: 'undefined',
        height: 'undefined',
<p dir="auto">I have tried setting the width and height in “stream1” to the same pixel… Same result… have also tried to doubble the width…  Same issue…</p>
<p dir="auto">What am I missing?!</p>
<p dir="auto">Ping: <a class="plugin-mentions-user plugin-mentions-a" href="/user/shbatm" aria-label="Profile: shbatm">@<bdi>shbatm</bdi></a></p>
<p dir="auto">BR<br />
Tilly</p>
]]></description><link>https://forum.magicmirror.builders/topic/10243/mmm-rtsp-module-is-only-showing-half-of-the-stream</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 12:41:18 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10243.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Apr 2019 11:43:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [MMM-RTSP] Module is only showing half of the stream? on Thu, 22 Apr 2021 20:34:58 GMT]]></title><description><![CDATA[<p dir="auto">Hello everybody,</p>
<p dir="auto">i have the same problem. The stream works, but the right quarter of the picture is black. I´ve got problem is only when i rotate the display vertical.<br />
Is there anybody, who had solved such a problem?</p>
<p dir="auto">Best regards<br />
Richard_Fish</p>
]]></description><link>https://forum.magicmirror.builders/post/90962</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90962</guid><dc:creator><![CDATA[Richard_Fish]]></dc:creator><pubDate>Thu, 22 Apr 2021 20:34:58 GMT</pubDate></item></channel></rss>
