<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pir on off but with a webcam?]]></title><description><![CDATA[<p dir="auto">Was wondering if ther is a pir type module but ) can be used with a webcam? If so any recommendations on a bran/model. Wanted to also set up the assistant module and wonder if a webcam with a mic can be used to kill two birds with one stone?</p>
]]></description><link>https://forum.magicmirror.builders/topic/10257/pir-on-off-but-with-a-webcam</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 12:17:48 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10257.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 10 Apr 2019 01:34:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pir on off but with a webcam? on Wed, 10 Apr 2019 03:37:03 GMT]]></title><description><![CDATA[<p dir="auto">MMM-SleepWake does all the MM stuff to turn of hdmi or monitors if you can (I have to hide modules as my TV’s wont’ turn off)</p>
<p dir="auto">Motion is the thing that reads the webcam and signals events to MMM-SleepWake.<br />
i didn’t want to write code to manage a few hundred different webcams… and settings and … u name it.<br />
motion does all that…<br />
(and if u want video snapshots or little recorded sequences… all handled, or emailed, or…)</p>
<p dir="auto">I do not know on the camera behind the mirror… that would be something to test out the sensitivity</p>
<p dir="auto">I started with the webcam as motion detection, cause the 1st mirror app was voice based, so needed a mic…</p>
]]></description><link>https://forum.magicmirror.builders/post/55712</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55712</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 10 Apr 2019 03:37:03 GMT</pubDate></item><item><title><![CDATA[Reply to Pir on off but with a webcam? on Wed, 10 Apr 2019 02:54:44 GMT]]></title><description><![CDATA[<p dir="auto">why do you need the mmm sleep wake with the motion program?</p>
<p dir="auto">Also would this work through a two way mirror?</p>
]]></description><link>https://forum.magicmirror.builders/post/55711</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55711</guid><dc:creator><![CDATA[dxfan227]]></dc:creator><pubDate>Wed, 10 Apr 2019 02:54:44 GMT</pubDate></item><item><title><![CDATA[Reply to Pir on off but with a webcam? on Wed, 10 Apr 2019 02:05:46 GMT]]></title><description><![CDATA[<p dir="auto">The answer is yes.</p>
<p dir="auto">I use the motion GitHub project to signal motion, and my MMM-SleepWake module to wake/sleep</p>
<p dir="auto">MMM-Hotword and MMM-AssistantMk2 can give you some control.</p>
]]></description><link>https://forum.magicmirror.builders/post/55709</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55709</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 10 Apr 2019 02:05:46 GMT</pubDate></item></channel></rss>
