<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[No sound from my RPi 3 B.]]></title><description><![CDATA[<p dir="auto">Thanks in advance. I’ve been searching the forum and have not found an solution for this. Currently I am running a Raspberry Pi 3 B. I have MM loaded and some modules loaded. I have a HDMI to DVI cable attached going to my monitor. Any help is appreciated.</p>
<p dir="auto">Thanks,<br />
Bill</p>
]]></description><link>https://forum.magicmirror.builders/topic/10285/no-sound-from-my-rpi-3-b</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Jul 2026 15:20:22 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10285.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 16 Apr 2019 00:42:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to No sound from my RPi 3 B. on Fri, 19 Apr 2019 01:10:23 GMT]]></title><description><![CDATA[<p dir="auto">I have sound! Thanks for all the help. What I did, after I read some the links provided, I decided to format another SD card and reload all my programs and I got sound. Then I compared the two SD card files and found that the original card had a file called AIY Project Voice, this program overwrote some of the files and change the parameters for output,  apparently my grandson downloaded it thinking he was helping. Now all is good and I’ve learned a lot with every ones help. Thanks again.</p>
]]></description><link>https://forum.magicmirror.builders/post/56174</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56174</guid><dc:creator><![CDATA[BillW]]></dc:creator><pubDate>Fri, 19 Apr 2019 01:10:23 GMT</pubDate></item><item><title><![CDATA[Reply to No sound from my RPi 3 B. on Wed, 17 Apr 2019 02:28:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/billw" aria-label="Profile: BillW">@<bdi>BillW</bdi></a></p>
<p dir="auto">Just to add to what <a class="plugin-mentions-user plugin-mentions-a" href="/user/bhepler" aria-label="Profile: bhepler">@<bdi>bhepler</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  are suggesting about posting code on the forum;</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners">https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners</a></p>
]]></description><link>https://forum.magicmirror.builders/post/56055</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56055</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Wed, 17 Apr 2019 02:28:32 GMT</pubDate></item><item><title><![CDATA[Reply to No sound from my RPi 3 B. on Wed, 17 Apr 2019 02:02:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/billw" aria-label="Profile: BillW">@<bdi>BillW</bdi></a> - You can find the <a href="https://commonmark.org/help/" target="_blank" rel="noopener noreferrer nofollow ugc">markdown commands at this link</a>. Please use them to post code, file contents and commands.</p>
]]></description><link>https://forum.magicmirror.builders/post/56048</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56048</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Wed, 17 Apr 2019 02:02:53 GMT</pubDate></item><item><title><![CDATA[Reply to No sound from my RPi 3 B. on Wed, 17 Apr 2019 01:20:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/billw" aria-label="Profile: BillW">@<bdi>BillW</bdi></a> edit your previous post.</p>
<p dir="auto">In front of the content you pasted in, on a separate line, put three backtics</p>
<p dir="auto">Then go to the end of the content you pasted, add a new line and put three backtics there.  Submit your post update</p>
]]></description><link>https://forum.magicmirror.builders/post/56047</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56047</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 17 Apr 2019 01:20:51 GMT</pubDate></item><item><title><![CDATA[Reply to No sound from my RPi 3 B. on Wed, 17 Apr 2019 00:13:12 GMT]]></title><description><![CDATA[<p dir="auto">My knowledge of this is very limited, I don’t understand where you want me to put the markdown at?</p>
]]></description><link>https://forum.magicmirror.builders/post/56044</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56044</guid><dc:creator><![CDATA[BillW]]></dc:creator><pubDate>Wed, 17 Apr 2019 00:13:12 GMT</pubDate></item><item><title><![CDATA[Reply to No sound from my RPi 3 B. on Tue, 16 Apr 2019 03:33:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/billw" aria-label="Profile: BillW">@<bdi>BillW</bdi></a> use the markdown 3 backticks before and after… key to the left of number 1</p>
<p dir="auto">you can edit it… pound sign makes large font</p>
<p dir="auto">my device doesn’t have an analog audio port</p>
]]></description><link>https://forum.magicmirror.builders/post/55977</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55977</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 16 Apr 2019 03:33:09 GMT</pubDate></item><item><title><![CDATA[Reply to No sound from my RPi 3 B. on Tue, 16 Apr 2019 02:45:27 GMT]]></title><description><![CDATA[<p dir="auto">Ok, tried all three but no luck, not sure what to do next. Here’s a copy of my config file if that may help</p>
<h1>For more options and information see</h1>
<h1><a href="http://rpf.io/configtxt" target="_blank" rel="noopener noreferrer nofollow ugc">http://rpf.io/configtxt</a></h1>
<h1>Some settings may impact device functionality. See link above for details</h1>
<h1>uncomment if you get no picture on HDMI for a default “safe” mode</h1>
<p dir="auto">#hdmi_safe=1</p>
<h1>uncomment this if your display has a black border of unused pixels visible</h1>
<h1>and your display can output without overscan</h1>
<p dir="auto">#disable_overscan=1</p>
<h1>uncomment the following to adjust overscan. Use positive numbers if console</h1>
<h1>goes off screen, and negative if there is too much border</h1>
<p dir="auto">#overscan_left=16<br />
#overscan_right=16<br />
#overscan_top=16<br />
#overscan_bottom=16</p>
<h1>uncomment to force a console size. By default it will be display’s size minus</h1>
<h1>overscan.</h1>
<p dir="auto">#framebuffer_width=1280<br />
#framebuffer_height=720</p>
<h1>uncomment if hdmi display is not detected and composite is being output</h1>
<p dir="auto">#hdmi_force_hotplug=1</p>
<h1>uncomment to force a specific HDMI mode (this will force VGA)</h1>
<p dir="auto">#hdmi_group=1<br />
#hdmi_mode=1</p>
<h1>uncomment to force a HDMI mode rather than DVI. This can make audio work in</h1>
<h1>DMT (computer monitor) modes</h1>
<p dir="auto">#hdmi_drive=2</p>
<h1>uncomment to increase signal to HDMI, if you have interference, blanking, or</h1>
<h1>no display</h1>
<p dir="auto">#config_hdmi_boost=4</p>
<h1>uncomment for composite PAL</h1>
<p dir="auto">#sdtv_mode=2</p>
<p dir="auto">#uncomment to overclock the arm. 700 MHz is the default.<br />
#arm_freq=800</p>
<h1>Uncomment some or all of these to enable the optional hardware interfaces</h1>
<p dir="auto">#dtparam=i2c_arm=on<br />
#dtparam=i2s=on<br />
#dtparam=spi=on</p>
<h1>Uncomment this to enable the lirc-rpi module</h1>
<p dir="auto">#dtoverlay=lirc-rpi</p>
<h1>Additional overlays and parameters are documented /boot/overlays/README</h1>
<h1>Enable audio (loads snd_bcm2835)</h1>
<p dir="auto">#dtparam=audio=on<br />
[pi0]<br />
dtoverlay=dwc2<br />
[all]<br />
start_x=1<br />
gpu_mem=128<br />
dtoverlay=googlevoicehat-soundcard<br />
display_rotate=1</p>
<p dir="auto">Sorry for the large font, not well verse with the editing portion of this forum.</p>
]]></description><link>https://forum.magicmirror.builders/post/55976</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55976</guid><dc:creator><![CDATA[BillW]]></dc:creator><pubDate>Tue, 16 Apr 2019 02:45:27 GMT</pubDate></item><item><title><![CDATA[Reply to No sound from my RPi 3 B. on Tue, 16 Apr 2019 02:22:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/billw" aria-label="Profile: BillW">@<bdi>BillW</bdi></a> this one too</p>
<p dir="auto"><a href="https://www.cb-net.co.uk/linux/getting-analogue-sound-working-raspberry-pi-3b-raspbian-stretch/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.cb-net.co.uk/linux/getting-analogue-sound-working-raspberry-pi-3b-raspbian-stretch/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/55974</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55974</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 16 Apr 2019 02:22:32 GMT</pubDate></item><item><title><![CDATA[Reply to No sound from my RPi 3 B. on Tue, 16 Apr 2019 01:54:58 GMT]]></title><description><![CDATA[<p dir="auto">I’ll follow the link and check it out, then I’ll let you know what I did. Thanks for the guidance.</p>
]]></description><link>https://forum.magicmirror.builders/post/55973</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55973</guid><dc:creator><![CDATA[BillW]]></dc:creator><pubDate>Tue, 16 Apr 2019 01:54:58 GMT</pubDate></item><item><title><![CDATA[Reply to No sound from my RPi 3 B. on Tue, 16 Apr 2019 01:52:44 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://www.raspberrypi.org/documentation/configuration/audio-config.md" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/documentation/configuration/audio-config.md</a></p>
<p dir="auto">Sound is going out the HDMI cable</p>
]]></description><link>https://forum.magicmirror.builders/post/55972</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55972</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 16 Apr 2019 01:52:44 GMT</pubDate></item><item><title><![CDATA[Reply to No sound from my RPi 3 B. on Tue, 16 Apr 2019 01:51:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> No</p>
]]></description><link>https://forum.magicmirror.builders/post/55971</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55971</guid><dc:creator><![CDATA[BillW]]></dc:creator><pubDate>Tue, 16 Apr 2019 01:51:20 GMT</pubDate></item><item><title><![CDATA[Reply to No sound from my RPi 3 B. on Tue, 16 Apr 2019 01:50:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> do system sounds work?</p>
]]></description><link>https://forum.magicmirror.builders/post/55970</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55970</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 16 Apr 2019 01:50:56 GMT</pubDate></item><item><title><![CDATA[Reply to No sound from my RPi 3 B. on Tue, 16 Apr 2019 01:50:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/billw" aria-label="Profile: BillW">@<bdi>BillW</bdi></a> did the earphones work?</p>
]]></description><link>https://forum.magicmirror.builders/post/55969</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55969</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 16 Apr 2019 01:50:37 GMT</pubDate></item><item><title><![CDATA[Reply to No sound from my RPi 3 B. on Tue, 16 Apr 2019 01:45:12 GMT]]></title><description><![CDATA[<p dir="auto">I should have included in my first post, but I did attach a separate cable for sound to speakers, but that didn’t work so I tried earphones to make sure. Thanks for confirming that for me. Any other suggestions?</p>
]]></description><link>https://forum.magicmirror.builders/post/55968</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55968</guid><dc:creator><![CDATA[BillW]]></dc:creator><pubDate>Tue, 16 Apr 2019 01:45:12 GMT</pubDate></item><item><title><![CDATA[Reply to No sound from my RPi 3 B. on Tue, 16 Apr 2019 00:52:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/billw" aria-label="Profile: BillW">@<bdi>BillW</bdi></a> dvi does not carry sound  so you would need a separate cable</p>
<p dir="auto">My main computer has dvi, monitor is HDMI. Uses sep cable to monitor</p>
]]></description><link>https://forum.magicmirror.builders/post/55966</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55966</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 16 Apr 2019 00:52:12 GMT</pubDate></item></channel></rss>
