<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-MyWeather by martinkooij doesn't work...]]></title><description><![CDATA[<p dir="auto">Hi Guys,</p>
<p dir="auto">i just installed the module see in the description and started it with the example config.</p>
<p dir="auto">Now MagicMirror started with an Blackscreen and following errors…idk what to do. I updated and installed MM from scratch, but it doesnt work either.</p>
<p dir="auto">Please anyone help me before i go crazy ;)</p>
<p dir="auto">(Sorry for my bad english, last english lesson was about 6 years ago)</p>
<p dir="auto">Greetz</p>
<pre><code>&gt; magicmirror@2.7.1 start /home/pi/MagicMirror
&gt; sh run-start.sh
Starting MagicMirror: v2.7.1
Loading config ...
Loading module helpers ...
Module helper loaded: MMM-DWD-WarnWeather
Module helper loaded: MMM-Remote-Control
WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'rss-parser'
App threw an error during load
    at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
    at Function.Module._load (internal/modules/cjs/loader.js:528:25)
    at Module.require (internal/modules/cjs/loader.js:658:17)
    at require (internal/modules/cjs/helpers.js:20:18)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-MyWeather/node_helper.js:13:17)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-MyWeather/node_helper.js:153:3)
    at Module._compile (internal/modules/cjs/loader.js:711:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
    at Module.load (internal/modules/cjs/loader.js:620:32)
{ Error: Cannot find module 'rss-parser'
    at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
Launching application.
^CShutting down server...
Stopping module helper: updatenotification
Stopping module helper: MMM-DWD-WarnWeather
TypeError: Cannot convert undefined or null to object
    at Function.keys (&lt;anonymous&gt;)
    at Class.stop (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:70:20)
    at App.stop (/home/pi/MagicMirror/js/app.js:249:16)
    at App.app.on (/home/pi/MagicMirror/js/electron.js:109:7)
    at App.emit (events.js:182:13)
]]></description><link>https://forum.magicmirror.builders/topic/10295/mmm-myweather-by-martinkooij-doesn-t-work</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 03:05:07 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10295.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 16 Apr 2019 20:19:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-MyWeather by martinkooij doesn't work... on Wed, 17 Apr 2019 18:05:10 GMT]]></title><description><![CDATA[<p dir="auto">@Isid0r great… can u mark your issue resolved… thx</p>
]]></description><link>https://forum.magicmirror.builders/post/56091</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56091</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 17 Apr 2019 18:05:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyWeather by martinkooij doesn't work... on Wed, 17 Apr 2019 17:30:07 GMT]]></title><description><![CDATA[<p dir="auto">O M G…you saved my day!</p>
<p dir="auto">now everything works fine…thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/56090</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56090</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 17 Apr 2019 17:30:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MyWeather by martinkooij doesn't work... on Tue, 16 Apr 2019 21:33:18 GMT]]></title><description><![CDATA[<p dir="auto">the module u installed has another installation step that you missed…</p>
<p dir="auto">change to the module folder</p>
<pre><code>cd /home/pi/MagicMirror/modules/MMM-Remote-Control
<p dir="auto">then install its dependencies</p>
<pre><code>npm install
<p dir="auto">then try to run mirror again</p>
<p dir="auto">from the module readme</p>
<pre><code>Manual install
(1) Clone this repository in your modules folder, and install dependencies:
cd ~/MagicMirror/modules # adapt directory if you are using a different one
git clone https://github.com/Jopyth/MMM-Remote-Control.git
cd MMM-Remote-Control
npm install
]]></description><link>https://forum.magicmirror.builders/post/56042</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56042</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 16 Apr 2019 21:33:18 GMT</pubDate></item></channel></rss>
