<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SMB Working Photo Frame&#x2F;Slideshow Module]]></title><description><![CDATA[<p dir="auto">Newb here. I’m looking for a slideshow or photo frame module that works with SMB or a Mount drive.  Anyone know of one that I can check out?  Or, is this something that I would need to sit down and write through?  Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/10320/smb-working-photo-frame-slideshow-module</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 19:14:18 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10320.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 20 Apr 2019 15:00:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SMB Working Photo Frame&#x2F;Slideshow Module on Sat, 20 Apr 2019 16:51:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ninjaepisode" aria-label="Profile: NinjaEpisode">@<bdi>NinjaEpisode</bdi></a> I use MMM-ImagesPhotos from a mounted samba folder.   I had to make a link from the module uploads folder to the mount. But it works fine.</p>
<p dir="auto">See the ln command.</p>
<p dir="auto">The module doesn’t know the images are not local</p>
<p dir="auto">Note that modules can’t see anything above the modules folder without this kind of help</p>
]]></description><link>https://forum.magicmirror.builders/post/56218</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56218</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 20 Apr 2019 16:51:59 GMT</pubDate></item></channel></rss>
