<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Raspberry Pi issue]]></title><description><![CDATA[<p dir="auto">My raspberry pi shut down and won’t start back up again. I think it may be an issue with the SD card. How do I re-download the stuff to the sd card. when I went to the card two things showed up ,Recovery and Boot. I didn’t know what to do. Any help would be much appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/topic/10323/raspberry-pi-issue</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 06:41:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10323.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 20 Apr 2019 20:03:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Raspberry Pi issue on Tue, 23 Apr 2019 01:15:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bandnerd1002" aria-label="Profile: BandNerd1002">@<bdi>BandNerd1002</bdi></a> -  Not to worry. First, let’s get your <code>config.js</code> off of your SD card.</p>
<p dir="auto">Using the Windows File Explorer, browse through the boot drive and look for the <code>config.js</code> file. Copy that to your computer. (if it turns out that you can’t find this file, no worries. We’ll recreate it later).</p>
<p dir="auto">If you were able to backup your <code>config.js</code> file, great! If not, no big deal. At this point, I suggest you follow the <a href="https://forum.magicmirror.builders/topic/236/complete-setup-tutorial">Complete Setup Tutorial</a>. It will walk you through prepping your SD card and getting your Magic Mirror reinstalled.</p>
<p dir="auto">A couple things to note about the tutorial:</p>
<ul>
<li>It’s Raspian Stretch now. Download the full version with the recommended software.</li>
<li>The command to clear out some installed &amp; unnecessary software will fail due to some of the listed software not being included. Try running the command one application at a time and skipping the ones that aren’t found.</li>
</ul>
<p dir="auto">Once you have your mirror back up and running, you can copy your <code>config.js</code> file back to your Raspberry Pi. Then you just have to re-clone and re-build all of the modules you had downloaded.</p>
]]></description><link>https://forum.magicmirror.builders/post/56320</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56320</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Tue, 23 Apr 2019 01:15:19 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry Pi issue on Mon, 22 Apr 2019 23:28:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bandnerd1002" aria-label="Profile: BandNerd1002">@<bdi>BandNerd1002</bdi></a> without another Linux based system u can’t do anything. So just download noobs or Ubuntu.</p>
]]></description><link>https://forum.magicmirror.builders/post/56317</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56317</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 22 Apr 2019 23:28:14 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry Pi issue on Mon, 22 Apr 2019 21:34:13 GMT]]></title><description><![CDATA[<p dir="auto">there are 2 things showing up when i put the SD card into the computer. Recovery and boot. I am confused on if I just download the noobs or if i have to do something to thies files first.</p>
]]></description><link>https://forum.magicmirror.builders/post/56316</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56316</guid><dc:creator><![CDATA[BandNerd1002]]></dc:creator><pubDate>Mon, 22 Apr 2019 21:34:13 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry Pi issue on Mon, 22 Apr 2019 21:31:58 GMT]]></title><description><![CDATA[<p dir="auto">The first time it came pre installed and downloaded on the sd card. it was pre formatted and whatnot.</p>
]]></description><link>https://forum.magicmirror.builders/post/56314</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56314</guid><dc:creator><![CDATA[BandNerd1002]]></dc:creator><pubDate>Mon, 22 Apr 2019 21:31:58 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry Pi issue on Sun, 21 Apr 2019 00:19:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bandnerd1002" aria-label="Profile: BandNerd1002">@<bdi>BandNerd1002</bdi></a> what did u do the 1st time?</p>
<p dir="auto"><a href="https://thepi.io/how-to-install-raspbian-on-the-raspberry-pi" target="_blank" rel="noopener noreferrer nofollow ugc">https://thepi.io/how-to-install-raspbian-on-the-raspberry-pi</a></p>
<p dir="auto">And<br />
<a href="https://linuxhint.com/install-ubuntu-on-raspberry-pi/" target="_blank" rel="noopener noreferrer nofollow ugc">https://linuxhint.com/install-ubuntu-on-raspberry-pi/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/56232</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56232</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 21 Apr 2019 00:19:25 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry Pi issue on Sun, 21 Apr 2019 00:10:46 GMT]]></title><description><![CDATA[<p dir="auto">how do I install format And install the sd card?</p>
]]></description><link>https://forum.magicmirror.builders/post/56231</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56231</guid><dc:creator><![CDATA[BandNerd1002]]></dc:creator><pubDate>Sun, 21 Apr 2019 00:10:46 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry Pi issue on Sat, 20 Apr 2019 23:51:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bandnerd1002" aria-label="Profile: BandNerd1002">@<bdi>BandNerd1002</bdi></a> do u have another Linux machine around? U might be able to recover with fsck.   If not then u will have to start over, fomat the SD card, install the os image (usually w etcher) again, then boot and start by installing mm again…</p>
]]></description><link>https://forum.magicmirror.builders/post/56229</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56229</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 20 Apr 2019 23:51:12 GMT</pubDate></item></channel></rss>
