<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[This device is not allowed to access your mirror.]]></title><description><![CDATA[<pre><code>var config = {
	address: '0.0.0.0',
	port: 8080,
	ipwhitelist: [],
		    module: "MMM-Remote-Control",
                                              position: 'right',
                                             apiKey:  ' '
<p dir="auto">This is my config file but even If I whitelist every ip address I still can’t connect<br />
“Thisdevice is not allowed to access your mirror.<br />
Please check your config.js or config.js.sample to change this.”</p>
<p dir="auto">Any ideas?</p>
<p dir="auto">Pi 3b+ and mobile hotspot btw</p>
]]></description><link>https://forum.magicmirror.builders/topic/10329/this-device-is-not-allowed-to-access-your-mirror</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 23:46:22 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10329.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 22 Apr 2019 15:33:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to This device is not allowed to access your mirror. on Tue, 23 Apr 2019 16:48:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dxfan227" aria-label="Profile: dxfan227">@<bdi>dxfan227</bdi></a> that shouldn’t matter.<br />
The message the OP posted comes from server.js after checking the ipWhitelist config variable</p>
]]></description><link>https://forum.magicmirror.builders/post/56354</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56354</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 23 Apr 2019 16:48:12 GMT</pubDate></item><item><title><![CDATA[Reply to This device is not allowed to access your mirror. on Tue, 23 Apr 2019 16:35:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  Ok</p>
<p dir="auto">Perhapes the config is missing the part I bolded here? :</p>
<p dir="auto"><strong>modules: [</strong></p>
<p dir="auto">{<br />
module: “MMM-Remote-Control”,<br />
config: {<br />
position: ‘right’,<br />
apiKey:  ’ ’</p>
<p dir="auto">},<br />
<strong>]</strong></p>
]]></description><link>https://forum.magicmirror.builders/post/56353</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56353</guid><dc:creator><![CDATA[dxfan227]]></dc:creator><pubDate>Tue, 23 Apr 2019 16:35:45 GMT</pubDate></item><item><title><![CDATA[Reply to This device is not allowed to access your mirror. on Tue, 23 Apr 2019 15:20:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dxfan227" aria-label="Profile: dxfan227">@<bdi>dxfan227</bdi></a> not for the base framework, and most of the default modules.   (Weather needs one)</p>
]]></description><link>https://forum.magicmirror.builders/post/56351</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56351</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 23 Apr 2019 15:20:09 GMT</pubDate></item><item><title><![CDATA[Reply to This device is not allowed to access your mirror. on Tue, 23 Apr 2019 15:08:32 GMT]]></title><description><![CDATA[<p dir="auto">is an api key required to run properly?</p>
]]></description><link>https://forum.magicmirror.builders/post/56350</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56350</guid><dc:creator><![CDATA[dxfan227]]></dc:creator><pubDate>Tue, 23 Apr 2019 15:08:32 GMT</pubDate></item><item><title><![CDATA[Reply to This device is not allowed to access your mirror. on Tue, 23 Apr 2019 14:30:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/julia" aria-label="Profile: Julia">@<bdi>Julia</bdi></a> note that the strings in config are case sensitive, it should be</p>
<p dir="auto">ipWhitelist</p>
<p dir="auto">not</p>
<p dir="auto">ipwhitelist</p>
]]></description><link>https://forum.magicmirror.builders/post/56346</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56346</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 23 Apr 2019 14:30:27 GMT</pubDate></item><item><title><![CDATA[Reply to This device is not allowed to access your mirror. on Tue, 23 Apr 2019 10:17:44 GMT]]></title><description><![CDATA[<p dir="auto">The error is on my phone. Replacing the ‘0.0.0.0’ value with my Pi’s ip address makes no difference. I still get the same message.</p>
]]></description><link>https://forum.magicmirror.builders/post/56338</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56338</guid><dc:creator><![CDATA[Julia]]></dc:creator><pubDate>Tue, 23 Apr 2019 10:17:44 GMT</pubDate></item><item><title><![CDATA[Reply to This device is not allowed to access your mirror. on Tue, 23 Apr 2019 01:19:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/julia" aria-label="Profile: Julia">@<bdi>Julia</bdi></a> - Where are you receiving that error message? Are you getting that on your mobile device trying to use the configuration app? Or is that on the mirror itself?</p>
<p dir="auto">I would try replacing the <code>'0.0.0.0'</code> value with your Pi’s IP address.</p>
]]></description><link>https://forum.magicmirror.builders/post/56321</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56321</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Tue, 23 Apr 2019 01:19:23 GMT</pubDate></item><item><title><![CDATA[Reply to This device is not allowed to access your mirror. on Mon, 22 Apr 2019 15:52:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I am trying to connect my laptop. What do you mean by “Is it using remote-control apis?”?</p>
]]></description><link>https://forum.magicmirror.builders/post/56299</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56299</guid><dc:creator><![CDATA[Julia]]></dc:creator><pubDate>Mon, 22 Apr 2019 15:52:07 GMT</pubDate></item><item><title><![CDATA[Reply to This device is not allowed to access your mirror. on Mon, 22 Apr 2019 15:44:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/julia" aria-label="Profile: Julia">@<bdi>Julia</bdi></a> what device is trying to connect?</p>
<p dir="auto">Is it using remote-control apis?</p>
]]></description><link>https://forum.magicmirror.builders/post/56298</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56298</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 22 Apr 2019 15:44:52 GMT</pubDate></item></channel></rss>
