<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM on Mac mini with motion to turn monitor off]]></title><description><![CDATA[<p dir="auto">I want to use my Mac Mini for my MM. Is there a way to implement motion detection with a cam and disable HDMI or monitor if no motion is capturing? I have this on my raspberry with motion and it works perfectly… this is for my one of the most important things! :smiling_face: thanks for any help…</p>
]]></description><link>https://forum.magicmirror.builders/topic/10335/mm-on-mac-mini-with-motion-to-turn-monitor-off</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 23:51:11 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10335.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 23 Apr 2019 11:06:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM on Mac mini with motion to turn monitor off on Tue, 23 Jul 2019 20:22:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stoffbeuteluwe" aria-label="Profile: Stoffbeuteluwe">@<bdi>Stoffbeuteluwe</bdi></a> yes…</p>
]]></description><link>https://forum.magicmirror.builders/post/59330</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59330</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 23 Jul 2019 20:22:03 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Mac mini with motion to turn monitor off on Tue, 23 Jul 2019 20:05:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> harmony hub can be a solution but not in my case because my tv fits exactly in the frame<br />
If you have space around your tv you can use it to turn Mac and tv on and off and it works with Alexa</p>
]]></description><link>https://forum.magicmirror.builders/post/59329</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59329</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Tue, 23 Jul 2019 20:05:23 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Mac mini with motion to turn monitor off on Tue, 23 Jul 2019 19:52:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> hide show the modules?</p>
]]></description><link>https://forum.magicmirror.builders/post/59328</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59328</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Tue, 23 Jul 2019 19:52:18 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Mac mini with motion to turn monitor off on Tue, 23 Jul 2019 19:48:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stoffbeuteluwe" aria-label="Profile: Stoffbeuteluwe">@<bdi>Stoffbeuteluwe</bdi></a> ok, mine doesn’t either. So sleepwake supports hide/show…</p>
]]></description><link>https://forum.magicmirror.builders/post/59327</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59327</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 23 Jul 2019 19:48:44 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Mac mini with motion to turn monitor off on Tue, 23 Jul 2019 19:48:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/trividar" aria-label="Profile: trividar">@<bdi>trividar</bdi></a> No sorry I can’t found a solution on Mac, I tried logitec hub, and Pulse eight …I’m not able to make it work tv on and off.</p>
]]></description><link>https://forum.magicmirror.builders/post/59325</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59325</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Tue, 23 Jul 2019 19:48:23 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Mac mini with motion to turn monitor off on Tue, 23 Jul 2019 13:24:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/trividar" aria-label="Profile: trividar">@<bdi>trividar</bdi></a> i just fixed MMM-SleepWake for mac…</p>
]]></description><link>https://forum.magicmirror.builders/post/59287</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59287</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 23 Jul 2019 13:24:38 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Mac mini with motion to turn monitor off on Tue, 23 Jul 2019 06:38:15 GMT]]></title><description><![CDATA[<p dir="auto">oooh I found something amazing from <a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> .<br />
I have to try it! Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> for that amazing work!</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/6376/macmirror">https://forum.magicmirror.builders/topic/6376/macmirror</a></p>
]]></description><link>https://forum.magicmirror.builders/post/59274</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59274</guid><dc:creator><![CDATA[trividar]]></dc:creator><pubDate>Tue, 23 Jul 2019 06:38:15 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Mac mini with motion to turn monitor off on Tue, 23 Jul 2019 06:11:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stoffbeuteluwe" aria-label="Profile: Stoffbeuteluwe">@<bdi>Stoffbeuteluwe</bdi></a> Sorry for my late answer! No, unfortunately not! I have tried so many things, but I am not able to make it work ;o( Have you tried it?</p>
]]></description><link>https://forum.magicmirror.builders/post/59270</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59270</guid><dc:creator><![CDATA[trividar]]></dc:creator><pubDate>Tue, 23 Jul 2019 06:11:13 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Mac mini with motion to turn monitor off on Sun, 16 Jun 2019 09:56:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/trividar" aria-label="Profile: trividar">@<bdi>trividar</bdi></a> did you solved the Problem with the motion on Mac mini?</p>
]]></description><link>https://forum.magicmirror.builders/post/58019</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58019</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Sun, 16 Jun 2019 09:56:30 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Mac mini with motion to turn monitor off on Wed, 24 Apr 2019 13:25:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dxfan227" aria-label="Profile: dxfan227">@<bdi>dxfan227</bdi></a> thank’s for your answer. I don’t know, is there a possibility to install motion on Mac osx and disable HDMI when motion is detected? Is motion compatible with os x?</p>
]]></description><link>https://forum.magicmirror.builders/post/56388</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56388</guid><dc:creator><![CDATA[trividar]]></dc:creator><pubDate>Wed, 24 Apr 2019 13:25:56 GMT</pubDate></item><item><title><![CDATA[Reply to MM on Mac mini with motion to turn monitor off on Tue, 23 Apr 2019 13:12:46 GMT]]></title><description><![CDATA[<p dir="auto">I don’t see why it would be any different from your rpi</p>
]]></description><link>https://forum.magicmirror.builders/post/56342</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56342</guid><dc:creator><![CDATA[dxfan227]]></dc:creator><pubDate>Tue, 23 Apr 2019 13:12:46 GMT</pubDate></item></channel></rss>
