<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error Installing MMM-Keybindings]]></title><description><![CDATA[<p dir="auto">’m trying to install but get an error with node-pre-gyp install --fallback-to-build</p>
<p dir="auto">node v8.10.0<br />
npm v3.5.2</p>
<p dir="auto">I can not go to node 10.x as I’m running in old Macbook Pro which although has 64bit processor runs in 32bit mode</p>
<p dir="auto">first warnings I see:<br />
node-pre-gyp WARN Using request for node-pre-gyp https download<br />
node-pre-gyp WARN Pre-built binaries not installable for udev@0.5.0 and node@8.16.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)<br />
node-pre-gyp WARN Hit error Invalid URI “https:///node-v57-linux-ia32.tar.gz”</p>
<p dir="auto">Any help appreciated</p>
]]></description><link>https://forum.magicmirror.builders/topic/10353/error-installing-mmm-keybindings</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 22:06:10 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10353.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 Apr 2019 03:55:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error Installing MMM-Keybindings on Fri, 24 May 2019 13:59:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jcmarin" aria-label="Profile: JcMarin">@<bdi>JcMarin</bdi></a> nice debugging!!!..  thanks for the update… others will find this useful.</p>
]]></description><link>https://forum.magicmirror.builders/post/57384</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57384</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 24 May 2019 13:59:06 GMT</pubDate></item><item><title><![CDATA[Reply to Error Installing MMM-Keybindings on Thu, 23 May 2019 16:42:03 GMT]]></title><description><![CDATA[<p dir="auto">SOLVED</p>
<p dir="auto">I finally figured out why MMM-Keybindings was not seeing the remote, after looking at some logs from pm2 I saw some errors reporting no permission to open /dev/input/btremote (which points to /dev/input/event6)</p>
<p dir="auto">After further troubleshooting, I saw that the MM process in PM2 for some reason was not running as root</p>
<p dir="auto">I recreated the pm2 startup script <code> pm2 startup</code> and that fixed the permissions and now MMM-Keybindings sees the remote clicks no problem.</p>
<p dir="auto">thought to post in case this could help someone with same problem</p>
]]></description><link>https://forum.magicmirror.builders/post/57352</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57352</guid><dc:creator><![CDATA[JcMarin]]></dc:creator><pubDate>Thu, 23 May 2019 16:42:03 GMT</pubDate></item><item><title><![CDATA[Reply to Error Installing MMM-Keybindings on Wed, 01 May 2019 04:36:03 GMT]]></title><description><![CDATA[<p dir="auto">Yes, this is an Apple Metalic Remote (model A-1294) and receiver is the embedded MacBook Pro IR Receiver (old MacBook Pro 15" Core 2 Duo 2.33 - late 2006)</p>
<p dir="auto">For now, I have worked around MMM-Keybindings not seeing the remote keys by installing lirc and using irxevent to send Keys to MMM-Keybindings</p>
<p dir="auto">This is the config I was trying:<br />
module: “MMM-KeyBindings”,<br />
config: {<br />
enabledKeyStates: [“KEY_PRESSED”, “KEY_LONGPRESSED”],<br />
evdev: { enabled: true, eventPath: “/dev/input/btremote”},<br />
enableKeyboard: true,<br />
KeyMap: {<br />
Home: “KEY_HOMEPAGE”,<br />
Enter: “KEY_ENTER”,<br />
ArrowLeft: “KEY_LEFT”,<br />
ArrowRight: “KEY_RIGHT”,<br />
ArrowUp: “KEY_VOLUMEUP”,<br />
ArrowDown: “KEY_VOLUMEDOWN”,<br />
Menu: “KEY_MENU”,<br />
MediaPlayPause: “KEY_PLAYPAUSE”,<br />
MediaNextTrack: “KEY_FORWARD”,<br />
MediaPreviousTrack: “KEY_BACK”,<br />
Return: “KEY_BACKS”<br />
},<br />
actions: [{<br />
key: “ArrowUp”,<br />
state: “KEY_PRESSED”,<br />
instance: “SERVER”,<br />
mode: “DEFAULT”,<br />
notification: “REMOTE_ACTION”,<br />
payload: { action: “TOGGLE”, module: “module_2_clock”},<br />
}]<br />
}</p>
<p dir="auto">btremote is pointing to /dev/input/event6 and as I said evtest does see the remote</p>
<p dir="auto">I also tried ir-keytables but although I can force it to look at the event6 dev there is no /dev/rc directory and it gives an error</p>
<p dir="auto">I guess lirc is not a bad solution while combining it with MMM_Keybindings, little more work and things to configure but I could not get it to work directly</p>
]]></description><link>https://forum.magicmirror.builders/post/56580</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56580</guid><dc:creator><![CDATA[JcMarin]]></dc:creator><pubDate>Wed, 01 May 2019 04:36:03 GMT</pubDate></item><item><title><![CDATA[Reply to Error Installing MMM-Keybindings on Mon, 29 Apr 2019 20:54:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jcmarin" aria-label="Profile: JcMarin">@<bdi>JcMarin</bdi></a> said in <a href="/post/56549">Error Installing MMM-Keybindings</a>:</p>
<p dir="auto">Apple IR Remote</p>
<p dir="auto">can u give more info on the remote? is this just a typical Apple tv remote?</p>
]]></description><link>https://forum.magicmirror.builders/post/56552</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56552</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 29 Apr 2019 20:54:36 GMT</pubDate></item><item><title><![CDATA[Reply to Error Installing MMM-Keybindings on Mon, 29 Apr 2019 19:37:08 GMT]]></title><description><![CDATA[<p dir="auto">So MMM-Keybinding is working for me now with Keyboard but does not work with the Apple IR Remote</p>
<p dir="auto">The remote is linked to /dev/input/event6 and evtest sees all the  keys which I have added to the Keymap in the config, but MMM-Keybindings does not see the event (I installed MMM-ViewNotifications to see what is detected)</p>
<p dir="auto">If I enable the keyboard MMM-Keybindings actually see some of the remotes keys but as keyboard input</p>
<p dir="auto">I also have tried to use ip-keytable to map other keyboard keys to the rremote but ip-keytable does NOT see the remote (/sys/class/rc/rc No such file or directory), looks like the remote is recognized as keyboard input but not actually an ir remote</p>
<p dir="auto">Anyonw has any experience with the Apple IR and how to use it in Magic Mirror?</p>
]]></description><link>https://forum.magicmirror.builders/post/56549</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56549</guid><dc:creator><![CDATA[JcMarin]]></dc:creator><pubDate>Mon, 29 Apr 2019 19:37:08 GMT</pubDate></item><item><title><![CDATA[Reply to Error Installing MMM-Keybindings on Fri, 26 Apr 2019 21:09:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jcmarin" aria-label="Profile: JcMarin">@<bdi>JcMarin</bdi></a> ctrl-shift-i  to open the developers window, select the console tab, and scroll up to find any errors, usually red text</p>
<p dir="auto">using the developers window and the source view, you can navigate thru the javascript, in the leftmost pane  to see it and also put program stops on instructions so that you can investigate module execution</p>
]]></description><link>https://forum.magicmirror.builders/post/56481</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56481</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 26 Apr 2019 21:09:26 GMT</pubDate></item><item><title><![CDATA[Reply to Error Installing MMM-Keybindings on Fri, 26 Apr 2019 17:17:31 GMT]]></title><description><![CDATA[<p dir="auto">Well I think that the module installed now, at least I’m not getting any errors with “npm install” but it’s not working after adding and configuring on my MM</p>
<p dir="auto">I’m using an Apple IR remote that is working under ubuntu fine (in dev/input/event8)</p>
<p dir="auto">whats the best way to troubleshoot this? how do I know if MM is getting the input and if MM-Keybinds is truly installed and working?</p>
]]></description><link>https://forum.magicmirror.builders/post/56479</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56479</guid><dc:creator><![CDATA[JcMarin]]></dc:creator><pubDate>Fri, 26 Apr 2019 17:17:31 GMT</pubDate></item><item><title><![CDATA[Reply to Error Installing MMM-Keybindings on Fri, 26 Apr 2019 04:52:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/56447">Error Installing MMM-Keybindings</a>:</p>
<p dir="auto">MMM-Hotword</p>
<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I think I made some progress, the main error was referencing libudev so I installed libudev-dev and that seems to have worked.</p>
<p dir="auto">Another error I found is in the <a href="http://postinstall.sh" target="_blank" rel="noopener noreferrer nofollow ugc">postinstall.sh</a> there is a version check of Electron but that was pointing to /home/pi/MagicMirror which is not my case as I’m not running on a Raspberry. I changed to my MM directory and that error cleared as well</p>
<p dir="auto">I will now check to see if the module is working and advice if its not</p>
]]></description><link>https://forum.magicmirror.builders/post/56449</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56449</guid><dc:creator><![CDATA[JcMarin]]></dc:creator><pubDate>Fri, 26 Apr 2019 04:52:19 GMT</pubDate></item><item><title><![CDATA[Reply to Error Installing MMM-Keybindings on Fri, 26 Apr 2019 03:59:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jcmarin" aria-label="Profile: JcMarin">@<bdi>JcMarin</bdi></a> I would look at the instructions in the MMM-Hotword readme  same problems. Best I’ve seen</p>
]]></description><link>https://forum.magicmirror.builders/post/56447</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56447</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 26 Apr 2019 03:59:52 GMT</pubDate></item></channel></rss>
