<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Ornate Awesomeness]]></title><description><![CDATA[<p dir="auto">This has been a really fun project!  I saw the first version a while back and wanted to make one.  Christmas is coming up, so this is my girlfriend’s present!</p>
<p dir="auto">I found the frame in a thrift store for $20.  Seeing the frame made me jump on the project.  That thing is incredible…plastic…but incredible…</p>
<p dir="auto">For the glass, I look around a lot and compared pictures and whatnot and decided to go with actual smart mirror glass from <a href="http://www.twowaymirrors.com/" target="_blank" rel="noopener noreferrer nofollow ugc">Two Way Mirrors.</a>  I’m really happy with the reflection/allowance ratio.  It looks great!  That being said, the glass was the most expensive part of the project.</p>
<p dir="auto">I sourced a 32" TV from a pawn shop.  Well, two of them.  Ever opened up an LED TV?  Yeah…maybe don’t.  The first one became a great set of LED strips and some sweet thin speakers for another project.  Second one I pulled off everything I could while keeping the housing intact, and it made it to the finish line.</p>
<p dir="auto">I lucked out with the frame having preexisting holes that the old glass was mounted with.  I created a set of rails to use the holes, then built a wall on those rails to secure a backing to.</p>
<p dir="auto"><img src="https://c7.staticflickr.com/6/5821/31144709126_27dffe9867_z.jpg" alt="Back Frame" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://c7.staticflickr.com/6/5642/30813051390_0f1e0fd4d8_z.jpg" alt="Back Frame 2" class=" img-fluid img-markdown" /></p>
<p dir="auto">The light wood shows through the glass, as well as the TV logo and vol/ch button text, so I ended up painting the front of the wood black and masking the logo/text with electrical tape.</p>
<p dir="auto"><img src="https://c6.staticflickr.com/6/5668/31066011981_87c9c3df24_z.jpg" alt="Front" class=" img-fluid img-markdown" /></p>
<p dir="auto">I added fans into the side of the backing I made to get airflow into the TV.  They are kind of noisy, so I might flip them out with silent ones before I give it to her.</p>
<p dir="auto"><img src="https://c5.staticflickr.com/6/5603/31144726276_1e1979bc24_z.jpg" alt="Fans" class=" img-fluid img-markdown" /></p>
<p dir="auto">This thing is a beast and hard to carry around, so I installed some handles for the top and bottom of the frame.  That worked really well!</p>
<p dir="auto"><img src="https://c4.staticflickr.com/6/5655/31180466115_f402dc28b6_z.jpg" alt="Handles" class=" img-fluid img-markdown" /></p>
<p dir="auto">Here is everything inside.  I opted for a RPi case with a fan because it will be locked in there.  I haven’t seen issues with temperature yet, but I haven’t had it running for extended periods yet.  I ran power connectors for the fans through a protoboard, but I’m sure that could have been tidied up a bit with direct wiring.</p>
<p dir="auto"><img src="https://c4.staticflickr.com/6/5712/31180472995_174633e584_z.jpg" alt="Inside" class=" img-fluid img-markdown" /></p>
<p dir="auto">I put a PIR sensor at the base of the frame.  The TV I have in currently doesn’t support sleep mode, so I’m still working through how that will actually function when the dust settles.</p>
<p dir="auto"><img src="https://c8.staticflickr.com/6/5513/31066036431_939023694a_z.jpg" alt="PIR Sensor" class=" img-fluid img-markdown" /></p>
<p dir="auto">Here it is closed up from the back.  I drilled holes for the existing TV mounts.  I think that will be the way to hang this.  I thought about a French cleat too, but not sure yet.  Also kicking around the idea of building an easel for it!</p>
<p dir="auto"><img src="https://c8.staticflickr.com/6/5496/31180468175_0c025ae918_z.jpg" alt="Back Side" class=" img-fluid img-markdown" /></p>
<p dir="auto">Here it is turned on!  The only visible module you can’t see is an iframe in the middle of the screen that points to a page on my personal website.  That way I can push randomness to it remotely, which is either creepy or fun.</p>
<p dir="auto"><img src="https://c7.staticflickr.com/6/5682/30813080590_f6b236e599_z.jpg" alt="Front Side" class=" img-fluid img-markdown" /></p>
<p dir="auto">Current Modules:</p>
<ul>
<li>Time/date</li>
<li>Google Calendar</li>
<li>MMM-forecast-io</li>
<li>Compliments</li>
<li>News Feed</li>
<li>WatchDog</li>
<li>MMM-Remote-Control</li>
<li>MMM-PIR-Sensor (will probably pull due to the previously referenced issues)</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/topic/1040/ornate-awesomeness</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 20:32:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1040.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 22 Nov 2016 19:14:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Ornate Awesomeness on Mon, 23 Oct 2017 20:45:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phrazelle" aria-label="Profile: phrazelle">@<bdi>phrazelle</bdi></a></p>
<p dir="auto">That frame is exquisite!</p>
<p dir="auto"><em>The search is on!</em></p>
]]></description><link>https://forum.magicmirror.builders/post/30064</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30064</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 23 Oct 2017 20:45:45 GMT</pubDate></item><item><title><![CDATA[Reply to Ornate Awesomeness on Mon, 23 Oct 2017 16:08:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fox" aria-label="Profile: fox">@<bdi>fox</bdi></a> That is the standard News Feed module. The larger font is the RSS feed title, and the smaller font is the description.</p>
]]></description><link>https://forum.magicmirror.builders/post/30053</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30053</guid><dc:creator><![CDATA[phrazelle]]></dc:creator><pubDate>Mon, 23 Oct 2017 16:08:48 GMT</pubDate></item><item><title><![CDATA[Reply to Ornate Awesomeness on Mon, 23 Oct 2017 14:56:54 GMT]]></title><description><![CDATA[<p dir="auto">What is this for a news feed in the bottom bar?<br />
Because it shows small and bigger fonts…</p>
]]></description><link>https://forum.magicmirror.builders/post/30048</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30048</guid><dc:creator><![CDATA[fox]]></dc:creator><pubDate>Mon, 23 Oct 2017 14:56:54 GMT</pubDate></item><item><title><![CDATA[Reply to Ornate Awesomeness on Mon, 19 Dec 2016 17:29:56 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the kudos!</p>
<p dir="auto">Here is an updated module that fixed the referenced PIR Sensor issue:<br />
<a href="https://github.com/phrazelle/mm-pir-hide-all" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/phrazelle/mm-pir-hide-all</a></p>
]]></description><link>https://forum.magicmirror.builders/post/9574</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9574</guid><dc:creator><![CDATA[phrazelle]]></dc:creator><pubDate>Mon, 19 Dec 2016 17:29:56 GMT</pubDate></item><item><title><![CDATA[Reply to Ornate Awesomeness on Wed, 23 Nov 2016 20:59:03 GMT]]></title><description><![CDATA[<p dir="auto">Ah thanks @strawberry-3-141… I know, that I read about in a few times ago</p>
]]></description><link>https://forum.magicmirror.builders/post/8418</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8418</guid><dc:creator><![CDATA[ostfilinchen]]></dc:creator><pubDate>Wed, 23 Nov 2016 20:59:03 GMT</pubDate></item><item><title><![CDATA[Reply to Ornate Awesomeness on Wed, 23 Nov 2016 20:53:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ostfilinchen" aria-label="Profile: ostfilinchen">@<bdi>ostfilinchen</bdi></a></p>
<p dir="auto">[card:MichMich/MMM-WatchDog]</p>
]]></description><link>https://forum.magicmirror.builders/post/8417</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8417</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Wed, 23 Nov 2016 20:53:57 GMT</pubDate></item><item><title><![CDATA[Reply to Ornate Awesomeness on Wed, 23 Nov 2016 20:42:36 GMT]]></title><description><![CDATA[<p dir="auto">Nice work. But… what is WatchDog…?</p>
]]></description><link>https://forum.magicmirror.builders/post/8414</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8414</guid><dc:creator><![CDATA[ostfilinchen]]></dc:creator><pubDate>Wed, 23 Nov 2016 20:42:36 GMT</pubDate></item><item><title><![CDATA[Reply to Ornate Awesomeness on Wed, 23 Nov 2016 12:04:24 GMT]]></title><description><![CDATA[<p dir="auto">Fantastic work. Great job on sourcing the parts.</p>
]]></description><link>https://forum.magicmirror.builders/post/8393</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8393</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Wed, 23 Nov 2016 12:04:24 GMT</pubDate></item><item><title><![CDATA[Reply to Ornate Awesomeness on Tue, 22 Nov 2016 19:41:25 GMT]]></title><description><![CDATA[<p dir="auto">Wow, such a crazy frame. Well done!</p>
]]></description><link>https://forum.magicmirror.builders/post/8380</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8380</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Tue, 22 Nov 2016 19:41:25 GMT</pubDate></item></channel></rss>
