<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fresh Installation stuck at node ./download-chromedriver.js]]></title><description><![CDATA[<p dir="auto">Today I’ve followed <a href="https://forum.magicmirror.builders/topic/236/complete-setup-tutorial">this</a> tutorial in order to make a new install of Raspbian Stretch and MagicMirror.</p>
<p dir="auto">No matter if I install MagicMirror with the automated script or I execute the commands manually following the <a href="https://github.com/MichMich/MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">manual</a>, every time I get stuck at the following step:</p>
<pre><code>pi@magicmirror:~/MagicMirror $ npm install &amp;&amp; npm start
npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
&gt; electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
&gt; node ./download-chromedriver.js
<p dir="auto">Even after over an hour of waiting, the process won’t continue.</p>
<p dir="auto">Any help is appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/topic/10405/fresh-installation-stuck-at-node-download-chromedriver-js</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 21:57:32 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10405.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 May 2019 18:54:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fresh Installation stuck at node ./download-chromedriver.js on Thu, 09 May 2019 13:03:59 GMT]]></title><description><![CDATA[<p dir="auto">Reason: Downloding electron takes for ages as the download was below 1kb/s.<br />
Solution: Executing the following command using a faster chinese mirror:</p>
<pre><code>ELECTRON_MIRROR=http://npm.taobao.org/mirrors/electron/ npm install --prefix ~/MagicMirror electron --save-dev
]]></description><link>https://forum.magicmirror.builders/post/56855</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56855</guid><dc:creator><![CDATA[codac]]></dc:creator><pubDate>Thu, 09 May 2019 13:03:59 GMT</pubDate></item></channel></rss>
