<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Hotword Snowboy install problem]]></title><description><![CDATA[<p dir="auto">Hello</p>
<p dir="auto">installed MM from scratch. All modules are install OK but with MMM-Hotword i got the Snowboy error.<br />
I tried all tips from the MMM-Hotword readme <a href="https://github.com/eouia/MMM-Hotword" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/eouia/MMM-Hotword</a><br />
but i got always this error at the end .</p>
<pre><code>5492 warn MMM-Hotword@1.1.0 No repository field.
5493 verbose stack Error: snowboy@1.3.1 install: `node-pre-gyp install --fallback-to-build`
5493 verbose stack Exit status 1
5493 verbose stack     at EventEmitter.&lt;anonymous&gt; (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
5493 verbose stack     at EventEmitter.emit (events.js:189:13)
5493 verbose stack     at ChildProcess.&lt;anonymous&gt; (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
5493 verbose stack     at ChildProcess.emit (events.js:189:13)
5493 verbose stack     at maybeClose (internal/child_process.js:970:16)
5493 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
5494 verbose pkgid snowboy@1.3.1
5495 verbose cwd /home/pi/MagicMirror/modules/MMM-Hotword
5496 verbose Linux 4.14.98-v7+
5497 verbose argv "/usr/bin/node" "/usr/bin/npm" "install"
5498 verbose node v10.15.3
5499 verbose npm  v6.4.1
5500 error code ELIFECYCLE
5501 error errno 1
5502 error snowboy@1.3.1 install: `node-pre-gyp install --fallback-to-build`
5502 error Exit status 1
5503 error Failed at the snowboy@1.3.1 install script.
5503 error This is probably not a problem with npm. There is likely additional logging output above.
5504 verbose exit [ 1, true ]
Any help ?
]]></description><link>https://forum.magicmirror.builders/topic/10428/mmm-hotword-snowboy-install-problem</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 04:18:22 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10428.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 May 2019 14:10:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Hotword Snowboy install problem on Fri, 10 May 2019 21:05:08 GMT]]></title><description><![CDATA[<p dir="auto">@Sean  Great  !  Thank you</p>
]]></description><link>https://forum.magicmirror.builders/post/56923</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56923</guid><dc:creator><![CDATA[Lowis]]></dc:creator><pubDate>Fri, 10 May 2019 21:05:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword Snowboy install problem on Fri, 10 May 2019 20:33:01 GMT]]></title><description><![CDATA[<p dir="auto">I’ll release new version of MMM-Hotword in a few days.  (I wish it could be this Sunday). Installer will be included. Wait a while.</p>
]]></description><link>https://forum.magicmirror.builders/post/56920</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56920</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 10 May 2019 20:33:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword Snowboy install problem on Fri, 10 May 2019 17:48:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lowis" aria-label="Profile: Lowis">@<bdi>Lowis</bdi></a> including the electron-rebuild?</p>
]]></description><link>https://forum.magicmirror.builders/post/56910</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56910</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 10 May 2019 17:48:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword Snowboy install problem on Fri, 10 May 2019 17:33:18 GMT]]></title><description><![CDATA[<p dir="auto">i followed all steps and issues in the Troubleshooting section from MMM-Hotword.</p>
<p dir="auto">no luck</p>
]]></description><link>https://forum.magicmirror.builders/post/56909</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56909</guid><dc:creator><![CDATA[Lowis]]></dc:creator><pubDate>Fri, 10 May 2019 17:33:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Hotword Snowboy install problem on Fri, 10 May 2019 15:46:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lowis" aria-label="Profile: Lowis">@<bdi>Lowis</bdi></a> follow the rest of the instructions for MMM-Hotword</p>
]]></description><link>https://forum.magicmirror.builders/post/56907</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56907</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 10 May 2019 15:46:42 GMT</pubDate></item></channel></rss>
