<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[trouble using CSS to make a picture bigger]]></title><description><![CDATA[<p dir="auto">I have the MMM-Comic module installed and working on my mirror as shown here <a href="https://github.com/cowboysdude/MMM-Comic" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/cowboysdude/MMM-Comic</a>.  Everything works great. But as he mentioned in the Repo that the comics may be too small. Which they were. So on i go to changing the custom.css files as he mentions. that works great. BUT now as all this was done in landscape mode on my mirror. I decided to rotate my display by changing the config.txt file of my Pi. Now the comic photo does not change in size no matter what i do. The module is in the lower_third region, and have also tried middle_center. Any suggestions on being able to see the comic?</p>
]]></description><link>https://forum.magicmirror.builders/topic/10433/trouble-using-css-to-make-a-picture-bigger</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 14:19:00 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10433.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 May 2019 02:58:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to trouble using CSS to make a picture bigger on Sun, 12 May 2019 19:33:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/saljoke" aria-label="Profile: saljoke">@<bdi>saljoke</bdi></a><br />
i actually was able to go to the module itself. I adjusted the .css file inside the module folder. It seems to work so far with no issues.</p>
]]></description><link>https://forum.magicmirror.builders/post/56973</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56973</guid><dc:creator><![CDATA[fnooah]]></dc:creator><pubDate>Sun, 12 May 2019 19:33:01 GMT</pubDate></item><item><title><![CDATA[Reply to trouble using CSS to make a picture bigger on Sat, 11 May 2019 11:16:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fnooah" aria-label="Profile: fnooah">@<bdi>fnooah</bdi></a><br />
Hello<br />
You can try to use transform and scale on CSS to make it bigger.</p>
]]></description><link>https://forum.magicmirror.builders/post/56935</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56935</guid><dc:creator><![CDATA[saljoke]]></dc:creator><pubDate>Sat, 11 May 2019 11:16:12 GMT</pubDate></item></channel></rss>
