<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Would this cause a conflict with MMM-RemoteControl]]></title><description><![CDATA[<p dir="auto">Ok, so right now I have 2 mirrors running in my house.  On one of the mirrors I can get the remote control function to work with no issue when I am in my house.  I just tried the other and its not working.  The config is the same on both, I copied/pasted to make sure.</p>
<p dir="auto">Yes I am using the proper IP of the 2nd mirror.  I get the can not get remote/html error.</p>
<p dir="auto">The only thing I can think of is on the 2nd mirror I have the VNC cloud service turned on as this is a gift mirror and I want to be able to access it remotely for changes etc.  If it doesn’t work because of this no biggie, I can add a usb keyboard &amp; mouse to the gift for shut down purposes.</p>
<p dir="auto">Everything else looks the same.  I guess I could turn off vnc cloud but I havent.</p>
<p dir="auto">Thanks in advance</p>
]]></description><link>https://forum.magicmirror.builders/topic/10436/would-this-cause-a-conflict-with-mmm-remotecontrol</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 02:29:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10436.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 May 2019 18:22:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Would this cause a conflict with MMM-RemoteControl on Sat, 25 May 2019 16:09:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ok got it.  Was just trying to figure out how to adjust screen brightness like I would with the app.  makes sense</p>
]]></description><link>https://forum.magicmirror.builders/post/57414</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57414</guid><dc:creator><![CDATA[motdog]]></dc:creator><pubDate>Sat, 25 May 2019 16:09:01 GMT</pubDate></item><item><title><![CDATA[Reply to Would this cause a conflict with MMM-RemoteControl on Fri, 24 May 2019 23:01:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/motdog" aria-label="Profile: motdog">@<bdi>motdog</bdi></a> right… the vnc connection take over ALL communications from the outside in…</p>
<p dir="auto">you should be able to use a vnc client on the local lan to connect to the pi… called direct connect</p>
<p dir="auto">but apps (like request TO remote-control) cannot go IN to the system except over vnc…(as I understand it)</p>
]]></description><link>https://forum.magicmirror.builders/post/57403</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57403</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 24 May 2019 23:01:42 GMT</pubDate></item><item><title><![CDATA[Reply to Would this cause a conflict with MMM-RemoteControl on Fri, 24 May 2019 22:36:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> the thing is before I set it up for a cloud connection for me to access it remotely, I could access it via MMM-Remote-Control as it was in my home.  When I established the cloud connection with VNC, remote quit working. Get the get error</p>
]]></description><link>https://forum.magicmirror.builders/post/57402</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57402</guid><dc:creator><![CDATA[motdog]]></dc:creator><pubDate>Fri, 24 May 2019 22:36:34 GMT</pubDate></item><item><title><![CDATA[Reply to Would this cause a conflict with MMM-RemoteControl on Fri, 24 May 2019 14:15:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/motdog" aria-label="Profile: motdog">@<bdi>motdog</bdi></a> everything I see says the vnc connection requires a vnc client… local or remote<br />
(and once u establish the vnc server, that connection requires the client, no direct connections anymore)…</p>
<p dir="auto"><a href="https://www.realvnc.com/en/connect/docs/raspberry-pi.html#raspberry-pi-connect-direct" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.realvnc.com/en/connect/docs/raspberry-pi.html#raspberry-pi-connect-direct</a></p>
<p dir="auto">realvnc is the product for pi…</p>
<p dir="auto"><a href="https://www.realvnc.com/en/raspberrypi/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.realvnc.com/en/raspberrypi/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/57385</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57385</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 24 May 2019 14:15:21 GMT</pubDate></item><item><title><![CDATA[Reply to Would this cause a conflict with MMM-RemoteControl on Fri, 24 May 2019 02:59:31 GMT]]></title><description><![CDATA[<p dir="auto">I can access it via cloud service now that it’s on their wifi but they can’t get remote to get past the get error.</p>
]]></description><link>https://forum.magicmirror.builders/post/57367</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57367</guid><dc:creator><![CDATA[motdog]]></dc:creator><pubDate>Fri, 24 May 2019 02:59:31 GMT</pubDate></item><item><title><![CDATA[Reply to Would this cause a conflict with MMM-RemoteControl on Sun, 12 May 2019 00:45:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> it was the same IP address that I used before installing VNC cloud. Even if I’m not accessing the mirror through VNC the error occurs.  I did go into VNC on the mirror, went to settings and disabled accept cloud connections. Still no luck.</p>
<p dir="auto">I was wanting to make it easier to shut down for moving the mirror but me having remote access is more important so I can troubleshoot.</p>
]]></description><link>https://forum.magicmirror.builders/post/56955</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56955</guid><dc:creator><![CDATA[motdog]]></dc:creator><pubDate>Sun, 12 May 2019 00:45:48 GMT</pubDate></item><item><title><![CDATA[Reply to Would this cause a conflict with MMM-RemoteControl on Sat, 11 May 2019 23:08:02 GMT]]></title><description><![CDATA[<p dir="auto">what ip address are u trying to use, I think remotely or locally?</p>
<p dir="auto">if locally (on the house wifi), then VNC cloud will cause a problem you will have to use the vnc address, go out to the cloud and back in…</p>
]]></description><link>https://forum.magicmirror.builders/post/56953</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/56953</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 11 May 2019 23:08:02 GMT</pubDate></item></channel></rss>
