<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[write events to Calendar on MM]]></title><description><![CDATA[<p dir="auto">Hello @all,</p>
<p dir="auto">Is it possible to enter a calendar event? directly on the mirror (touchscreen).<br />
for example in Google Calendar? or I should another software?</p>
]]></description><link>https://forum.magicmirror.builders/topic/10440/write-events-to-calendar-on-mm</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 12:52:30 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10440.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 12 May 2019 11:13:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to write events to Calendar on MM on Mon, 30 Nov 2020 13:56:24 GMT]]></title><description><![CDATA[<p dir="auto">Thank you, I have already ordered a microphone and speaker and that is the next module I was going to try.</p>
]]></description><link>https://forum.magicmirror.builders/post/85312</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85312</guid><dc:creator><![CDATA[Dropzone1969]]></dc:creator><pubDate>Mon, 30 Nov 2020 13:56:24 GMT</pubDate></item><item><title><![CDATA[Reply to write events to Calendar on MM on Mon, 30 Nov 2020 14:10:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dropzone1969" aria-label="Profile: Dropzone1969">@<bdi>Dropzone1969</bdi></a> u can speak to add(change, and delete) a calendar entry in both GA  and Alexa</p>
]]></description><link>https://forum.magicmirror.builders/post/85310</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85310</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 30 Nov 2020 14:10:39 GMT</pubDate></item><item><title><![CDATA[Reply to write events to Calendar on MM on Mon, 30 Nov 2020 13:12:33 GMT]]></title><description><![CDATA[<p dir="auto">If it is a Google calendar would using a Google assistant module work?</p>
]]></description><link>https://forum.magicmirror.builders/post/85308</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85308</guid><dc:creator><![CDATA[Dropzone1969]]></dc:creator><pubDate>Mon, 30 Nov 2020 13:12:33 GMT</pubDate></item><item><title><![CDATA[Reply to write events to Calendar on MM on Sun, 25 Oct 2020 12:14:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerrylein" aria-label="Profile: Jerrylein">@<bdi>Jerrylein</bdi></a> I am not aware of any modules that allow you to type on the mirror.</p>
]]></description><link>https://forum.magicmirror.builders/post/83934</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83934</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 25 Oct 2020 12:14:57 GMT</pubDate></item><item><title><![CDATA[Reply to write events to Calendar on MM on Sun, 25 Oct 2020 10:22:21 GMT]]></title><description><![CDATA[<p dir="auto">Hm… one year later and I find no Modul for input Calendar Events or ToDo-Lists…</p>
]]></description><link>https://forum.magicmirror.builders/post/83928</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/83928</guid><dc:creator><![CDATA[Jerrylein]]></dc:creator><pubDate>Sun, 25 Oct 2020 10:22:21 GMT</pubDate></item></channel></rss>
