<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem: npm install &amp;&amp; npm start]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I’m new to Raspberry and coding… :/<br />
So of yours I have some troubles.</p>
<p dir="auto">The automatic installations mode wouldn work out, so I tried manuell mode.</p>
<p dir="auto">Can you tell me what I need to chance or which information do need?</p>
<p dir="auto">Here’s the code:</p>
<pre><code>pi@raspberrypi:~/MagicMirror $ npm install &amp;&amp; npm start
npm WARN engine grunt-jsonlint@1.1.0: wanted: {"node":"&gt;=4.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine grunt-eslint@19.0.0: wanted: {"node":"&gt;=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine request@2.79.0: wanted: {"node":"&gt;= 4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine eslint@3.10.2: wanted: {"node":"&gt;=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine stylelint@7.6.0: wanted: {"node":"&gt;=4.2.1"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine form-data@2.1.2: wanted: {"node":"&gt;= 0.12"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine hawk@3.1.3: wanted: {"node":"&gt;=0.10.32"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine deep-extend@0.4.1: wanted: {"node":"&gt;=0.12.0","iojs":"&gt;=1.0.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine cryptiles@2.0.5: wanted: {"node":"&gt;=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine boom@2.10.1: wanted: {"node":"&gt;=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine hoek@2.16.3: wanted: {"node":"&gt;=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
&gt; electron-prebuilt@1.4.8 postinstall /home/pi/MagicMirror/node_modules/electron-prebuilt
&gt; node install.js
npm WARN engine cosmiconfig@2.1.0: wanted: {"node":"&gt;=0.12"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine string-width@2.0.0: wanted: {"node":"&gt;=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine get-stdin@5.0.1: wanted: {"node":"&gt;=0.12.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine postcss@5.2.6: wanted: {"node":"&gt;=0.12"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine strip-bom@3.0.0: wanted: {"node":"&gt;=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine shelljs@0.7.5: wanted: {"node":"&gt;=0.11.0","iojs":"*"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN engine is-fullwidth-code-point@2.0.0: wanted: {"node":"&gt;=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
npm WARN deprecated node-uuid@1.4.7: use uuid module instead
npm WARN engine co@4.6.0: wanted: {"iojs":"&gt;= 1.0.0","node":"&gt;= 0.12.0"} (current: {"node":"0.10.29","npm":"1.4.21"})
&gt; magicmirror@2.0.0 prepublish /home/pi/MagicMirror
&gt; npm run snyk-protect
&gt; magicmirror@2.0.0 snyk-protect /home/pi/MagicMirror
&gt; snyk protect
Successfully applied Snyk patches
npm ERR! peerinvalid The package grunt does not satisfy its siblings' peerDependencies requirements!
npm ERR! peerinvalid Peer grunt-eslint@19.0.0 wants grunt@&gt;=0.4.0
npm ERR! peerinvalid Peer grunt-yamllint@0.2.0 wants grunt@~0.4.0
npm ERR! System Linux 4.4.21-v7+
npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install"
npm ERR! cwd /home/pi/MagicMirror
npm ERR! node -v v0.10.29
npm ERR! npm -v 1.4.21
npm ERR! code EPEERINVALID
npm ERR!
npm ERR! not ok code 0
<p dir="auto">Thanks alot</p>
]]></description><link>https://forum.magicmirror.builders/topic/1046/problem-npm-install-npm-start</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 22:36:16 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1046.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 23 Nov 2016 19:33:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem: npm install &amp;&amp; npm start on Thu, 24 Nov 2016 10:34:36 GMT]]></title><description><![CDATA[<p dir="auto">Today I reinstalled my Pi.<br />
This time with Noob style, but with the image itself.</p>
<p dir="auto">After that, the automatic MagicMirror installation worked finde. Everything was updated correctly. Yesterday it didn’t work at all.<br />
Also I had the problem that google clalenders would not show up in the Magic Mirror.<br />
Today everything works fine.</p>
<p dir="auto">Maybe there is a problem with Noob installation?!</p>
]]></description><link>https://forum.magicmirror.builders/post/8440</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8440</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Thu, 24 Nov 2016 10:34:36 GMT</pubDate></item><item><title><![CDATA[Reply to Problem: npm install &amp;&amp; npm start on Wed, 23 Nov 2016 23:35:08 GMT]]></title><description><![CDATA[<p dir="auto">great! That worked out.<br />
Thanks alot</p>
<p dir="auto">I was trying it that way</p>
<pre><code>wget https://nodejs.org/dist/v4.0.0/node-v4.0.0-linux-armv7l.tar.gz
tar -xvf node-v4.0.0-linux-armv7l.tar.gz
cd node-v4.0.0-linux-armv7l
<p dir="auto">Just for the latest version…</p>
<p dir="auto">But okay…</p>
<p dir="auto">Now I need to install npm as you said in your first post?</p>
<p dir="auto">Edit:<br />
I think it works now. At least the screen pops up.<br />
Just the weather forecast isn’t working right now.</p>
<p dir="auto">Can you have look at the code if everythin is correct so far?</p>
npm WARN prepublish-on-install As of npm@5, `prepublish` scripts will run only for `npm publish`.
npm WARN prepublish-on-install (In npm@4 and previous versions, it also runs for `npm install`.)
npm WARN prepublish-on-install See the deprecation note in `npm help scripts` for more information.
&gt; snyk protect
npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
&gt; magicmirror@2.0.0 start /home/pi/MagicMirror
&gt; electron js/electron.js
Loading config ...
Loading module helpers ...
All module helpers loaded.
Starting server op port 8080 ...
Server started ...
Starting module: newsfeed
Sockets connected &amp; modules started ...
Launching application.
Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
pi@raspberrypi:~/MagicMirror $ ^C
pi@raspberrypi:~/MagicMirror $ sudo npm install &amp;&amp; npm start
npm WARN lifecycle magicmirror@2.0.0~prepublish: cannot run in wd %s %s (wd=%s) magicmirror@2.0.0 npm run snyk-protect /home/pi/MagicMirror
Loading config ...
Server started ...
Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000</code></pre>
]]></description><link>https://forum.magicmirror.builders/post/8424</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8424</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Wed, 23 Nov 2016 23:35:08 GMT</pubDate></item><item><title><![CDATA[Reply to Problem: npm install &amp;&amp; npm start on Wed, 23 Nov 2016 22:28:03 GMT]]></title><description><![CDATA[<p dir="auto">Oh snap, @strawberry-3-141 is right. Of course, I meant, that your nide version is too old. Did you try to update/install node via <code>apt</code>? Try <code>apt-get update &amp;&amp; apt-get upgrade</code> or <code>apt-get install nodejs</code> and see, if it helps.</p>
<p dir="auto">If it doesn’t work, follow the instructions here, to install a recent version of node: <a href="https://nodejs.org/en/download/package-manager/#debian-and-ubuntu-based-linux-distributions" target="_blank" rel="noopener noreferrer nofollow ugc">https://nodejs.org/en/download/package-manager/#debian-and-ubuntu-based-linux-distributions</a></p>
]]></description><link>https://forum.magicmirror.builders/post/8422</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8422</guid><dc:creator><![CDATA[Beh]]></dc:creator><pubDate>Wed, 23 Nov 2016 22:28:03 GMT</pubDate></item><item><title><![CDATA[Reply to Problem: npm install &amp;&amp; npm start on Wed, 23 Nov 2016 21:21:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a></p>
<p dir="auto">Can you tell me the right code, please?<br />
I could try some versions, but I don’t want mess everything up.</p>
<p dir="auto">I tied:</p>
<pre><code>pi@raspberrypi:~ $ sudo npm cache clean -f
npm WARN npm npm does not support Node.js v0.10.29
npm WARN npm You should probably upgrade to a newer version of node as we
npm WARN npm can't make any promises that npm will work with this version.
npm WARN npm You can find the latest version at https://nodejs.org/
npm WARN using --force I sure hope you know what you are doing.
pi@raspberrypi:~ $</code></pre>
]]></description><link>https://forum.magicmirror.builders/post/8420</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8420</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Wed, 23 Nov 2016 21:21:36 GMT</pubDate></item><item><title><![CDATA[Reply to Problem: npm install &amp;&amp; npm start on Wed, 23 Nov 2016 20:52:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jeff" aria-label="Profile: Jeff">@<bdi>Jeff</bdi></a> as the error tells you have to upgrade first node in order to update npm, you’re running node 0.10 there is already version 7.x</p>
]]></description><link>https://forum.magicmirror.builders/post/8416</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8416</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Wed, 23 Nov 2016 20:52:35 GMT</pubDate></item><item><title><![CDATA[Reply to Problem: npm install &amp;&amp; npm start on Wed, 23 Nov 2016 20:46:38 GMT]]></title><description><![CDATA[<p dir="auto">I tried it again, if you find anything in my code… let me know?</p>
<p dir="auto">I’m not sure where to install npm… in the MagicMirror folder or above?</p>
<pre><code>pi@raspberrypi:~/MagicMirror $ cd
pi@raspberrypi:~ $ sudo npm install npm@latest -g
/usr/local/bin/npm -&gt; /usr/local/lib/node_modules/npm/bin/npm-cli.js
npm@4.0.2 /usr/local/lib/node_modules/npm
pi@raspberrypi:~ $ npm updte
Usage: npm &lt;command&gt;
where &lt;command&gt; is one of:
    add-user, adduser, apihelp, author, bin, bugs, c, cache,
    completion, config, ddp, dedupe, deprecate, docs, edit,
    explore, faq, find, find-dupes, get, help, help-search,
    home, i, info, init, install, isntall, issues, la, link,
    list, ll, ln, login, ls, outdated, owner, pack, prefix,
    prune, publish, r, rb, rebuild, remove, repo, restart, rm,
    root, run-script, s, se, search, set, show, shrinkwrap,
    star, stars, start, stop, submodule, t, tag, test, tst, un,
    uninstall, unlink, unpublish, unstar, up, update, v,
    version, view, whoami
npm &lt;cmd&gt; -h     quick help on &lt;cmd&gt;
npm -l           display full usage info
npm faq          commonly asked questions
npm help &lt;term&gt;  search for help on &lt;term&gt;
npm help npm     involved overview
Specify configs in the ini-formatted file:
    /home/pi/.npmrc
or on the command line via: npm &lt;command&gt; --key value
Config info can be viewed via: npm help config
npm@1.4.21 /usr/share/npm
pi@raspberrypi:~ $ sudo npm update
pi@raspberrypi:~ $ npm install
npm ERR! install Couldn't read dependencies
npm ERR! package.json ENOENT, open '/home/pi/package.json'
npm ERR! package.json This is most likely not a problem with npm itself.
npm ERR! package.json npm can't find a package.json file in your current directory.
npm ERR! path /home/pi/package.json
npm ERR! code ENOPACKAGEJSON
npm ERR! errno 34
npm ERR!
npm ERR!     /home/pi/npm-debug.log
npm WARN enoent ENOENT, open '/home/pi/package.json'
npm WARN pi No description
npm WARN pi No repository field.
npm WARN pi No README data
npm WARN pi No license field.
pi@raspberrypi:~ $ cd MagicMirror
&gt; snyk protect
npm ERR!
pi@raspberrypi:~ $ npm update
pi@raspberrypi:~/MagicMirror $ npm update
plur@1.0.0 node_modules/time-grunt/node_modules/pretty-ms/node_modules/plur
resolve-from@1.0.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/require-uncached/node_modules/resolve-from
speedometer@0.1.4 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/nugget/node_modules/progress-stream/node_modules/speedometer
has-flag@1.0.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/postcss/node_modules/supports-color/node_modules/has-flag
supports-color@2.0.0 node_modules/time-grunt/node_modules/chalk/node_modules/supports-color
array-differ@1.0.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/multimatch/node_modules/array-differ
get-stdin@4.0.1 node_modules/grunt/node_modules/dateformat/node_modules/get-stdin
debug@0.7.4 node_modules/electron-prebuilt/node_modules/extract-zip/node_modules/debug
ms@0.7.1 node_modules/express/node_modules/send/node_modules/ms
css-color-names@0.0.3 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/pipetteur/node_modules/synesthesia/node_modules/css-color-names
path-to-regexp@0.1.7 node_modules/express/node_modules/path-to-regexp
punycode@1.3.2 node_modules/snyk/node_modules/url/node_modules/punycode
punycode@1.4.1 node_modules/request/node_modules/tough-cookie/node_modules/punycode
after@0.8.1 node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/after
is-arrayish@0.2.1 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/cosmiconfig/node_modules/parse-json/node_modules/error-ex/node_modules/is-arrayish
throttleit@0.0.2 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/nugget/node_modules/throttleit
map-obj@1.0.1 node_modules/grunt/node_modules/dateformat/node_modules/meow/node_modules/map-obj
array-flatten@1.1.1 node_modules/express/node_modules/array-flatten
isarray@0.0.1 node_modules/socket.io/node_modules/has-binary/node_modules/isarray
strip-json-comments@1.0.4 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/rc/node_modules/strip-json-comments
assert-plus@0.2.0 node_modules/request/node_modules/http-signature/node_modules/assert-plus
foreachasync@3.0.0 node_modules/walk/node_modules/foreachasync
debug@2.2.0 node_modules/express/node_modules/send/node_modules/debug
npm WARN unmet dependency /home/pi/MagicMirror/node_modules/snyk/node_modules/snyk-policy requires es6-promise@'^3.1.2' but will load
npm WARN unmet dependency undefined,
npm WARN unmet dependency which is version undefined
npm WARN unmet dependency /home/pi/MagicMirror/node_modules/snyk/node_modules/snyk-resolve-deps requires es6-promise@'^3.0.2' but will load
undefsafe@0.0.3 node_modules/snyk/node_modules/undefsafe
eventemitter2@0.4.14 node_modules/grunt/node_modules/eventemitter2
supports-color@2.0.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/chalk/node_modules/supports-color
component-emitter@1.1.2 node_modules/socket.io/node_modules/socket.io-parser/node_modules/component-emitter
extsprintf@1.0.2 node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/extsprintf
minimist@0.0.8 node_modules/grunt-eslint/node_modules/eslint/node_modules/mkdirp/node_modules/minimist
caller-path@0.1.0 node_modules/grunt-eslint/node_modules/eslint/node_modules/require-uncached/node_modules/caller-path
└── callsites@0.2.0
isarray@0.0.1 node_modules/socket.io/node_modules/socket.io-parser/node_modules/isarray
strip-json-comments@1.0.4 node_modules/grunt-eslint/node_modules/eslint/node_modules/strip-json-comments
estraverse@4.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/esrecurse/node_modules/estraverse
map-obj@1.0.1 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/meow/node_modules/map-obj
camelcase-keys@2.1.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/meow/node_modules/camelcase-keys
└── camelcase@2.1.1
pluralize@1.2.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/pluralize
rimraf@2.2.8 node_modules/grunt/node_modules/rimraf
supports-color@2.0.0 node_modules/grunt-eslint/node_modules/chalk/node_modules/supports-color
after@0.8.1 node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/after
chalk@0.4.0 node_modules/grunt-jsonlint/node_modules/jsonlint/node_modules/nomnom/node_modules/chalk
├── has-color@0.1.7
├── ansi-styles@1.0.0
└── strip-ansi@0.1.1
underscore@1.6.0 node_modules/grunt-jsonlint/node_modules/jsonlint/node_modules/nomnom/node_modules/underscore
ipaddr.js@1.1.1 node_modules/express/node_modules/proxy-addr/node_modules/ipaddr.js
npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/postcss-reporter requires chalk@'^1.0.0' but will load
npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/postcss-reporter requires log-symbols@'^1.0.2' but will load
npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/postcss-reporter requires postcss@'^5.0.0' but will load
color-diff@0.1.7 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/color-diff
verror@1.3.6 node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/verror
supports-color@2.0.0 node_modules/grunt/node_modules/grunt-legacy-log/node_modules/grunt-legacy-log-utils/node_modules/chalk/node_modules/supports-color
camelcase-keys@2.1.0 node_modules/grunt/node_modules/dateformat/node_modules/meow/node_modules/camelcase-keys
└── camelcase@2.1.1
uuid@2.0.3 node_modules/snyk/node_modules/tempfile/node_modules/uuid
finalhandler@0.5.0 node_modules/express/node_modules/finalhandler
├── unpipe@1.0.0
└── statuses@1.3.1
supports-color@2.0.0 node_modules/snyk/node_modules/chalk/node_modules/supports-color
has-binary@0.1.6 node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/has-binary
└── isarray@0.0.1
qs@6.2.0 node_modules/express/node_modules/qs
async@0.9.2 node_modules/grunt-yamllint/node_modules/async
string-width@1.0.2 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/nugget/node_modules/single-line-log/node_modules/string-width
├── code-point-at@1.1.0
├── strip-ansi@3.0.1 (ansi-regex@2.0.0)
└── is-fullwidth-code-point@1.0.0 (number-is-nan@1.0.1)
figures@1.7.0 node_modules/time-grunt/node_modules/figures
├── escape-string-regexp@1.0.5
└── object-assign@4.1.0
chalk@0.5.1 node_modules/grunt-yamllint/node_modules/chalk
├── ansi-styles@1.1.0
├── supports-color@0.2.0
├── strip-ansi@0.3.0 (ansi-regex@0.2.1)
└── has-ansi@0.1.0 (ansi-regex@0.2.1)
path-exists@2.1.0 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/path-exists
└── pinkie-promise@2.0.1 (pinkie@2.0.4)
minimatch@3.0.2 node_modules/snyk/node_modules/snyk-recursive-readdir/node_modules/minimatch
└── brace-expansion@1.1.6 (balanced-match@0.4.2, concat-map@0.0.1)
snyk-module@1.7.0 node_modules/snyk/node_modules/snyk-module
├── hosted-git-info@2.1.5
└── validate-npm-package-name@2.2.2 (builtins@0.0.7)
async@1.5.2 node_modules/snyk/node_modules/hasbin/node_modules/async
debug@2.2.0 node_modules/express/node_modules/debug
└── ms@0.7.1
has-binary@0.1.6 node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/has-binary
└── isarray@0.0.1
doctrine@1.5.0 node_modules/grunt-eslint/node_modules/eslint/node_modules/doctrine
└── isarray@1.0.0
npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/es6-iterator requires d@'^0.1.1' but will load
npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/es6-set requires d@'~0.1.1' but will load
npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/es6-symbol requires d@'~0.1.1' but will load
npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/event-emitter requires d@'~0.1.1' but will load
d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/d
glob@7.0.6 node_modules/grunt/node_modules/glob
├── inherits@2.0.3
├── fs.realpath@1.0.0
├── inflight@1.0.6 (wrappy@1.0.2)
└── once@1.4.0 (wrappy@1.0.2)
mkdirp@0.5.0 node_modules/electron-prebuilt/node_modules/extract-zip/node_modules/mkdirp
└── minimist@0.0.8
esprima@2.7.3 node_modules/grunt-yamllint/node_modules/js-yaml/node_modules/esprima
yauzl@2.4.1 node_modules/electron-prebuilt/node_modules/extract-zip/node_modules/yauzl
└── fd-slicer@1.0.1 (pend@1.2.0)
es6-promise@3.3.1 node_modules/snyk/node_modules/snyk-try-require/node_modules/es6-promise
os-name@1.0.3 node_modules/snyk/node_modules/os-name
├── win-release@1.1.1
└── osx-release@1.1.0 (minimist@1.2.0)
yargs@1.3.3 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/yargs
redent@1.0.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/meow/node_modules/redent
├── strip-indent@1.0.1 (get-stdin@4.0.1)
└── indent-string@2.1.0 (repeating@2.0.1)
debug@2.2.0 node_modules/socket.io/node_modules/socket.io-parser/node_modules/debug
└── ms@0.7.1
readable-stream@1.1.14 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/css-rule-stream/node_modules/css-tokenize/node_modules/readable-stream
├── string_decoder@0.10.31
├── core-util-is@1.0.2
└── isarray@0.0.1
redent@1.0.0 node_modules/grunt/node_modules/dateformat/node_modules/meow/node_modules/redent
through2@0.6.5 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/ldjson-stream/node_modules/through2
├── xtend@4.0.1
└── readable-stream@1.0.34 (isarray@0.0.1, string_decoder@0.10.31, inherits@2.0.3, core-util-is@1.0.2)
source-map@0.4.4 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/source-map
└── amdefine@1.0.1
write@0.2.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/file-entry-cache/node_modules/flat-cache/node_modules/write
└── mkdirp@0.5.1 (minimist@0.0.8)
postcss-less@0.14.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/postcss-less
readable-stream@2.0.6 node_modules/grunt-eslint/node_modules/eslint/node_modules/concat-stream/node_modules/readable-stream
├── process-nextick-args@1.0.7
├── util-deprecate@1.0.2
├── isarray@1.0.0
└── core-util-is@1.0.2
globby@5.0.0 node_modules/grunt-eslint/node_modules/eslint/node_modules/file-entry-cache/node_modules/flat-cache/node_modules/del/node_modules/globby
├── arrify@1.0.1
├── object-assign@4.1.0
├── array-union@1.0.2 (array-uniq@1.0.3)
└── glob@7.1.1 (path-is-absolute@1.0.1, inherits@2.0.3, fs.realpath@1.0.0, inflight@1.0.6, once@1.4.0, minimatch@3.0.3)
async@1.5.2 node_modules/grunt/node_modules/grunt-legacy-util/node_modules/async
npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt/node_modules/grunt-cli/node_modules/findup-sync requires glob@'~5.0.0' but will load
npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt/node_modules/glob,
npm WARN unmet dependency which is version 7.0.6
findup-sync@0.3.0 node_modules/grunt/node_modules/grunt-cli/node_modules/findup-sync
└── glob@5.0.15 (path-is-absolute@1.0.1, inherits@2.0.3, inflight@1.0.6, once@1.4.0, minimatch@3.0.3)
configstore@1.4.0 node_modules/snyk/node_modules/configstore
├── os-tmpdir@1.0.2
├── graceful-fs@4.1.11
├── xdg-basedir@2.0.0 (os-homedir@1.0.2)
├── write-file-atomic@1.2.0 (imurmurhash@0.1.4, slide@1.1.6)
├── osenv@0.1.3 (os-homedir@1.0.2)
├── uuid@2.0.3
through2@0.6.5 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/css-rule-stream/node_modules/through2
├── xtend@4.0.1
└── readable-stream@1.0.34 (inherits@2.0.3, isarray@0.0.1, string_decoder@0.10.31, core-util-is@1.0.2)
findup-sync@0.3.0 node_modules/grunt/node_modules/findup-sync
└── glob@5.0.15 (inherits@2.0.3, once@1.4.0, inflight@1.0.6)
read-pkg-up@1.0.1 node_modules/grunt/node_modules/dateformat/node_modules/meow/node_modules/read-pkg-up
├── find-up@1.1.2 (path-exists@2.1.0, pinkie-promise@2.0.1)
└── read-pkg@1.1.0 (path-type@1.1.0, load-json-file@1.1.0)
coffee-script@1.10.0 node_modules/grunt/node_modules/coffee-script
underscore.string@3.2.3 node_modules/grunt/node_modules/grunt-legacy-util/node_modules/underscore.string
concat-stream@1.5.0 node_modules/electron-prebuilt/node_modules/extract-zip/node_modules/concat-stream
├── inherits@2.0.3
├── typedarray@0.0.6
└── readable-stream@2.0.6 (process-nextick-args@1.0.7, util-deprecate@1.0.2, string_decoder@0.10.31, isarray@1.0.0, core-util-is@1.0.2)
read-pkg-up@1.0.1 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/meow/node_modules/read-pkg-up
esprima@2.7.3 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/cosmiconfig/node_modules/js-yaml/node_modules/esprima
es6-promise@3.3.1 node_modules/snyk/node_modules/es6-promise
yargs@3.32.0 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/yargs
├── decamelize@1.2.0
├── y18n@3.2.1
├── camelcase@2.1.1
├── window-size@0.1.4
├── os-locale@1.4.0 (lcid@1.0.0)
├── string-width@1.0.2 (code-point-at@1.1.0, is-fullwidth-code-point@1.0.0, strip-ansi@3.0.1)
└── cliui@3.2.0 (wrap-ansi@2.0.0, strip-ansi@3.0.1)
duplexer2@0.0.2 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/duplexer2
└── readable-stream@1.1.14 (isarray@0.0.1, string_decoder@0.10.31, inherits@2.0.3, core-util-is@1.0.2)
JSONStream@0.8.4 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/jsonfilter/node_modules/JSONStream
├── through@2.3.8
└── jsonparse@0.0.5
npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-weak-map/node_modules/es6-iterator requires d@'^0.1.1' but will load
d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-weak-map/node_modules/d
pretty-bytes@1.0.4 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/nugget/node_modules/pretty-bytes
├── get-stdin@4.0.1
└── meow@3.7.0 (decamelize@1.2.0, trim-newlines@1.0.0, map-obj@1.0.1, object-assign@4.1.0, camelcase-keys@2.1.0, loud-rejection@1.6.0, minimist@1.2.0, redent@1.0.0, normalize-package-data@2.3.5, read-pkg-up@1.0.1)
inquirer@0.12.0 node_modules/grunt-eslint/node_modules/eslint/node_modules/inquirer
├── ansi-escapes@1.4.0
├── ansi-regex@2.0.0
├── chalk@1.1.3 (escape-string-regexp@1.0.5, has-ansi@2.0.0, supports-color@2.0.0, ansi-styles@2.2.1)
├── through@2.3.8
├── figures@1.7.0 (object-assign@4.1.0, escape-string-regexp@1.0.5)
├── cli-cursor@1.0.2 (restore-cursor@1.0.1)
├── readline2@1.0.1 (mute-stream@0.0.5, code-point-at@1.1.0, is-fullwidth-code-point@1.0.0)
├── string-width@1.0.2 (code-point-at@1.1.0, is-fullwidth-code-point@1.0.0)
├── run-async@0.1.0 (once@1.4.0)
├── cli-width@2.1.0
└── rx-lite@3.1.2
through2@0.2.3 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/nugget/node_modules/progress-stream/node_modules/through2
├── xtend@2.1.2 (object-keys@0.4.0)
└── readable-stream@1.1.14 (isarray@0.0.1, inherits@2.0.3, string_decoder@0.10.31, core-util-is@1.0.2)
har-validator@2.0.6 node_modules/request/node_modules/har-validator
├── pinkie-promise@2.0.1 (pinkie@2.0.4)
├── commander@2.9.0 (graceful-readlink@1.0.1)
├── chalk@1.1.3 (escape-string-regexp@1.0.5, supports-color@2.0.0, ansi-styles@2.2.1, strip-ansi@3.0.1, has-ansi@2.0.0)
└── is-my-json-valid@2.15.0 (generate-function@2.0.0, jsonpointer@4.0.0, xtend@4.0.1, generate-object-property@1.2.0)
through2@0.6.5 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/jsonfilter/node_modules/through2
├── xtend@4.0.1
└── readable-stream@1.0.34 (isarray@0.0.1, inherits@2.0.3, string_decoder@0.10.31, core-util-is@1.0.2)
acorn@3.3.0 node_modules/grunt-eslint/node_modules/eslint/node_modules/espree/node_modules/acorn-jsx/node_modules/acorn
fs-extra@0.30.0 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/fs-extra
├── path-is-absolute@1.0.1
├── klaw@1.3.1
├── jsonfile@2.4.0
└── rimraf@2.5.4 (glob@7.1.1)
hawk@3.1.3 node_modules/request/node_modules/hawk
├── cryptiles@2.0.5
├── sntp@1.0.9
├── boom@2.10.1
└── hoek@2.16.3
es6-promise@3.3.1 node_modules/electron-prebuilt/node_modules/electron-download/node_modules/sumchecker/node_modules/es6-promise
update-notifier@0.5.0 node_modules/snyk/node_modules/update-notifier
├── is-npm@1.0.0
├── semver-diff@2.1.0
├── string-length@1.0.1 (strip-ansi@3.0.1)
├── repeating@1.1.3 (is-finite@1.0.2)
└── latest-version@1.0.1 (package-json@1.2.0)
npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt/node_modules/grunt-legacy-log/node_modules/grunt-legacy-log-utils requires lodash@'~4.3.0' but will load
npm WARN unmet dependency /home/pi/MagicMirror/node_modules/grunt/node_modules/grunt-legacy-log/node_modules/lodash,
npm WARN unmet dependency which is version 3.10.1
underscore.string@3.2.3 node_modules/grunt/node_modules/grunt-legacy-log/node_modules/underscore.string
split2@0.2.1 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/ldjson-stream/node_modules/split2
└── through2@0.6.5 (xtend@4.0.1, readable-stream@1.0.34)
through2@0.6.5 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/through2
├── xtend@4.0.1
esprima@2.7.3 node_modules/grunt-eslint/node_modules/eslint/node_modules/js-yaml/node_modules/esprima
duplexer2@0.0.2 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/doiuse/node_modules/css-rule-stream/node_modules/duplexer2
js-yaml@3.5.5 node_modules/grunt/node_modules/js-yaml
├── esprima@2.7.3
└── argparse@1.0.9 (sprintf-js@1.0.3)
nconf@0.7.2 node_modules/snyk/node_modules/snyk-config/node_modules/nconf
├── ini@1.3.4
├── async@0.9.2
└── yargs@3.15.0 (decamelize@1.2.0, camelcase@1.2.1, window-size@0.1.4, cliui@2.1.0)
snyk-policy@1.5.2 node_modules/snyk/node_modules/snyk-policy
├── lodash.clonedeep@4.5.0
└── js-yaml@3.7.0 (esprima@2.7.3, argparse@1.0.9)
lodash@3.10.1 node_modules/grunt/node_modules/grunt-legacy-log/node_modules/lodash
table@3.8.3 node_modules/grunt-eslint/node_modules/eslint/node_modules/table
├── slice-ansi@0.0.4
├── ajv-keywords@1.1.1
├── string-width@2.0.0 (is-fullwidth-code-point@2.0.0, strip-ansi@3.0.1)
├── chalk@1.1.3 (escape-string-regexp@1.0.5, supports-color@2.0.0, ansi-styles@2.2.1, has-ansi@2.0.0, strip-ansi@3.0.1)
└── ajv@4.9.0 (co@4.6.0)
d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-weak-map/node_modules/es6-symbol/node_modules/d
└── es5-ext@0.10.12 (es6-iterator@2.0.0)
d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/es6-symbol/node_modules/d
lodash@4.3.0 node_modules/grunt/node_modules/grunt-legacy-util/node_modules/lodash
lodash@4.3.0 node_modules/grunt/node_modules/grunt-legacy-log/node_modules/grunt-legacy-log-utils/node_modules/lodash
postcss-reporter@1.4.1 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/stylehacks/node_modules/postcss-reporter
├── log-symbols@1.0.2
├── postcss@5.2.6 (supports-color@3.1.2, js-base64@2.1.9, source-map@0.5.6)
└── lodash@4.17.2
table@3.8.3 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/table
└── ajv@4.9.0 (co@4.6.0, json-stable-stringify@1.0.1)
postcss-reporter@1.4.1 node_modules/grunt-stylelint/node_modules/stylelint/node_modules/colorguard/node_modules/postcss-reporter
└── lodash@4.17.2
d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/event-emitter/node_modules/d
└── es5-ext@0.10.12 (es6-symbol@3.1.0, es6-iterator@2.0.0)
d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/es6-set/node_modules/d
snyk-resolve-deps@1.7.0 node_modules/snyk/node_modules/snyk-resolve-deps
├── ansicolors@0.3.2
├── lru-cache@4.0.1 (pseudomap@1.0.2, yallist@2.0.0)
├── minimist@1.2.0
├── clite@0.3.0 (lodash.defaults@4.2.0, lodash.mergewith@4.6.0, lodash.defaultsdeep@4.6.0, update-notifier@0.6.3, yargs@4.8.1)
└── lodash@4.17.2
d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-weak-map/node_modules/es6-iterator/node_modules/d
└── es5-ext@0.10.12 (es6-symbol@3.1.0)
d@0.1.1 node_modules/grunt-eslint/node_modules/eslint/node_modules/escope/node_modules/es6-map/node_modules/es6-iterator/node_modules/d
inquirer@1.0.3 node_modules/snyk/node_modules/inquirer
├── mute-stream@0.0.6
├── through@2.3.8
├── cli-width@2.1.0
├── run-async@2.2.0 (is-promise@2.1.0)
├── rx@4.1.0
└── lodash@4.17.2
&gt; snyk protect
npm ERR!
pi@raspberrypi:~/MagicMirror $</code></pre>
]]></description><link>https://forum.magicmirror.builders/post/8415</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8415</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Wed, 23 Nov 2016 20:46:38 GMT</pubDate></item><item><title><![CDATA[Reply to Problem: npm install &amp;&amp; npm start on Wed, 23 Nov 2016 20:22:51 GMT]]></title><description><![CDATA[<p dir="auto">Already made update and upgrade.<br />
Everything seems to be the newest version</p>
]]></description><link>https://forum.magicmirror.builders/post/8413</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8413</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Wed, 23 Nov 2016 20:22:51 GMT</pubDate></item><item><title><![CDATA[Reply to Problem: npm install &amp;&amp; npm start on Wed, 23 Nov 2016 20:17:51 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">it seems, that your installed version of <code>npm</code> is very old.<br />
You can update it with the command <code>npm install npm@latest -g</code></p>
<p dir="auto">I would recommend to update all the other packages as well. You can do that by:<br />
<code>npm update</code></p>
<p dir="auto">After that, run <code>npm install</code> again.</p>
]]></description><link>https://forum.magicmirror.builders/post/8412</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8412</guid><dc:creator><![CDATA[Beh]]></dc:creator><pubDate>Wed, 23 Nov 2016 20:17:51 GMT</pubDate></item></channel></rss>
