<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New to Pi and MM Needing Help]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">First off I want to apologize as I’m sure there are tons of these posts, but I am asking for help. I am 2 weeks new to Pi (Arduino user). I want to build out my MM, but am hitting major hurdles. As I understand it, I configure the clock in file clock.js (all I did was change the hour format) and since the “clock” module is in the main config.js file it should show up. Well, all I can see if the calendar and news feed. The compliments, clock, and weather are all gone. I haven’t removed anything from the main config.js file so all these should be there. I have been Googling around and just can’t seem to find something to point out where my error is. I think I know what I am doing, but let’s be honest I’m too new for that. I know this is a completely newbie question, but all help is appreciated. Thanks in advance.</p>
<p dir="auto">Chris</p>
]]></description><link>https://forum.magicmirror.builders/topic/10464/new-to-pi-and-mm-needing-help</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 17:48:55 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10464.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 May 2019 03:56:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New to Pi and MM Needing Help on Fri, 17 May 2019 04:46:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  - thank you! I wound up reinstalling it and it seems to be taking my edits. I appreciate the help!</p>
]]></description><link>https://forum.magicmirror.builders/post/57107</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57107</guid><dc:creator><![CDATA[CMcKay]]></dc:creator><pubDate>Fri, 17 May 2019 04:46:49 GMT</pubDate></item><item><title><![CDATA[Reply to New to Pi and MM Needing Help on Fri, 17 May 2019 04:27:39 GMT]]></title><description><![CDATA[<p dir="auto">you don’t change the clock.js u change the css or the config.js…</p>
<p dir="auto">anyhow… open the developers window, ctrl-shift-i, and find the console tab,<br />
scroll up to find any errors (usually red text)…</p>
<p dir="auto">also can put clock into the filter box</p>
]]></description><link>https://forum.magicmirror.builders/post/57106</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57106</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 17 May 2019 04:27:39 GMT</pubDate></item></channel></rss>
