<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Third Party modules does not work]]></title><description><![CDATA[<p dir="auto">Hello guys,<br />
I have got a little problem, after countless tries I managed to do npm install &amp;&amp; npm start (before on Rpi 2 B+ worked only serveronly - electron and node needed to be installed manually, do not know why) and “everything” works fine… except 3rd party modules.</p>
<p dir="auto">Tried a lot of them but every time I add some in config and reload MM , screen stays black, when I remove 3rd party module from config it works like a charm…and I am positive that in config I typed everything right.</p>
<p dir="auto">Does anyone know where is the problem? :)</p>
<p dir="auto">Thank you very much!</p>
]]></description><link>https://forum.magicmirror.builders/topic/1052/third-party-modules-does-not-work</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 20:28:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1052.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 24 Nov 2016 11:45:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Third Party modules does not work on Sun, 11 Dec 2016 19:55:54 GMT]]></title><description><![CDATA[<p dir="auto">It´s working now! Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/9204</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9204</guid><dc:creator><![CDATA[nem1]]></dc:creator><pubDate>Sun, 11 Dec 2016 19:55:54 GMT</pubDate></item><item><title><![CDATA[Reply to Third Party modules does not work on Sun, 11 Dec 2016 19:09:44 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for this advice. The module for public transports is working correnctly now! But I still have problems with the soccer module. It still shows “loading”. Any ideas? Maybe the syntax in the last line with leagues: … ???</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/9203</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9203</guid><dc:creator><![CDATA[nem1]]></dc:creator><pubDate>Sun, 11 Dec 2016 19:09:44 GMT</pubDate></item><item><title><![CDATA[Reply to Third Party modules does not work on Sun, 11 Dec 2016 18:29:42 GMT]]></title><description><![CDATA[<p dir="auto">Did you reboot your raspberry pi or the mirror process?</p>
]]></description><link>https://forum.magicmirror.builders/post/9200</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9200</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Sun, 11 Dec 2016 18:29:42 GMT</pubDate></item><item><title><![CDATA[Reply to Third Party modules does not work on Sun, 11 Dec 2016 18:28:07 GMT]]></title><description><![CDATA[<p dir="auto">Hey guys,</p>
<p dir="auto">I also have a problem with 3rd party modules.</p>
<p dir="auto">I tried to add MMM-PublicTransportBerlin and MMM-soccer, but both are not working. After adding the modules the mirror shows just “loading” at the given position. Both modules are installed in: /MagicMirror/modules/ in seperated folders.</p>
<p dir="auto">Here you can see my entries in the config to the mentioned modules:</p>
<p dir="auto">{<br />
module: ‘MMM-PublicTransportBerlin’,<br />
position: ‘top_right’,<br />
config: {<br />
stationId: 9100003,<br />
hidden: false,<br />
ignoredStations: [9100003,2342,1337],<br />
excludedTransportationTypes: ‘bus,suburban,subway’,<br />
delay: 10,<br />
interval: 120000,<br />
departureMinutes: 10,<br />
maxDepartures: 15,<br />
marqueeLongDirections: true,<br />
showColoredLineSymbols: true,<br />
useColorForRealtimeInfo: true,<br />
showTableHeadersAsSymbols: true,<br />
maxUnreachableDepartures: 3,<br />
maxReachableDepartures: 7,<br />
fadeUnreachableDepartures: true,<br />
fadeReachableDepartures: true,<br />
fadePointForReachableDepartures: 0.25<br />
}<br />
},</p>
module: ‘MMM-soccer’,<br />
position: ‘bottom_right’,<br />
config: {<br />
api_key: ‘my key’,<br />
colored: ‘false’,<br />
show: ‘GERMANY’,<br />
leagues: ‘{“GERMANY”:430}’<br />
}<br />
},</p>
<p dir="auto">Would be great if anybody can help! All default modules are working correctly.</p>
]]></description><link>https://forum.magicmirror.builders/post/9198</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9198</guid><dc:creator><![CDATA[nem1]]></dc:creator><pubDate>Sun, 11 Dec 2016 18:28:07 GMT</pubDate></item><item><title><![CDATA[Reply to Third Party modules does not work on Tue, 29 Nov 2016 12:31:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/indigomejor" aria-label="Profile: indigomejor">@<bdi>indigomejor</bdi></a><br />
glad to see it was such a simple thing. Enjoy your mirror</p>
]]></description><link>https://forum.magicmirror.builders/post/8673</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8673</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Tue, 29 Nov 2016 12:31:44 GMT</pubDate></item><item><title><![CDATA[Reply to Third Party modules does not work on Tue, 29 Nov 2016 08:18:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a> Yes, it was folder problem, my bad, I just wanted to have some order in it :)<br />
Thank you guys for help!</p>
<p dir="auto">For future mirrores with same problem, always put 3rd party modules in …/MagicMirror/modules (NOT in default) :)</p>
]]></description><link>https://forum.magicmirror.builders/post/8659</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8659</guid><dc:creator><![CDATA[indigomejor]]></dc:creator><pubDate>Tue, 29 Nov 2016 08:18:10 GMT</pubDate></item><item><title><![CDATA[Reply to Third Party modules does not work on Thu, 24 Nov 2016 13:56:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/indigomejor" aria-label="Profile: indigomejor">@<bdi>indigomejor</bdi></a> said in <a href="/post/8445">Third Party modules does not work</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a> I think I installed them in modules/default folder, that should be the problem maybe</p>
<p dir="auto">I guess so. I just moved one of my modules on my test laptop into the default subfolder and my screen stays black, just as you described.<br />
I moved it back to the modules folder, restarted the mirror and the module is shown</p>
]]></description><link>https://forum.magicmirror.builders/post/8446</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8446</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Thu, 24 Nov 2016 13:56:41 GMT</pubDate></item><item><title><![CDATA[Reply to Third Party modules does not work on Thu, 24 Nov 2016 13:28:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a> I think I installed them in modules/default folder, that should be the problem maybe</p>
]]></description><link>https://forum.magicmirror.builders/post/8445</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8445</guid><dc:creator><![CDATA[indigomejor]]></dc:creator><pubDate>Thu, 24 Nov 2016 13:28:29 GMT</pubDate></item><item><title><![CDATA[Reply to Third Party modules does not work on Thu, 24 Nov 2016 13:26:06 GMT]]></title><description><![CDATA[<p dir="auto">Are you sure the third party modules are installed in their own folder in MagicMirror/modules ?</p>
]]></description><link>https://forum.magicmirror.builders/post/8444</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8444</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Thu, 24 Nov 2016 13:26:06 GMT</pubDate></item><item><title><![CDATA[Reply to Third Party modules does not work on Thu, 24 Nov 2016 13:25:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/indigomejor" aria-label="Profile: indigomejor">@<bdi>indigomejor</bdi></a> Please check the installation notes of the modules again, and see if there are any steps you might have overlooked. Also you can have a look at the output of the server (i.e. <code>pm2 logs mm</code> if you are using the <code>pm2</code> method), and check for errors there, and post them here (remove confidential information first!).</p>
]]></description><link>https://forum.magicmirror.builders/post/8443</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8443</guid><dc:creator><![CDATA[Jopyth]]></dc:creator><pubDate>Thu, 24 Nov 2016 13:25:59 GMT</pubDate></item></channel></rss>
