<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[At my Wits end! Overscan/Underscan. Nothing changes]]></title><description><![CDATA[<p dir="auto">Hi Folks<br />
I have played around with this for hours on end. I have the Raspi up and running and have got MagicMirror installed. But for the love of money I can’t get the screen to stop overflowing past the edge of the monitor. The image I can see if too big for the screen i am using.<br />
In Raspi Configuration I have tried Underscan both Enabled and Disabled.<br />
In the config file i have tried allsorts of combinations of the following code…</p>
<pre><code>disable_overscan=1
overscan_left=39
overscan_right=39
overscan_top=25
overscan_bottom=23
framebuffer_width=1920
framebuffer_height=1080
hdmi_group=1
hdmi_mode=16
<p dir="auto">Whether disabled or not, positive or negative values nothing makes any difference the the results I get.<br />
Its like a setting somewhere is overriding any of these settings.<br />
Can someone please take pity of a guy whose gonna rip his hair out anytime soon.<br />
Best Regards</p>
]]></description><link>https://forum.magicmirror.builders/topic/10534/at-my-wits-end-overscan-underscan-nothing-changes</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 17:18:32 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10534.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 May 2019 17:48:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to At my Wits end! Overscan/Underscan. Nothing changes on Thu, 30 May 2019 21:18:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jonogee" aria-label="Profile: JonoGee">@<bdi>JonoGee</bdi></a></p>
<p dir="auto">Did you ever touch the <code>/boot/config.txt</code>file ?<br />
Or only did the config using <code>$ sudo raspi-config</code> or via the GUI ?<br />
It can be you selected <code>Overscan</code> there.</p>
<p dir="auto">Can you also show the output of this command ?</p>
<pre><code>$ cat /boot/config.txt | grep -v '^#' | egrep 'overscan|framebuffer|hdmi|dtoverlay'
]]></description><link>https://forum.magicmirror.builders/post/57585</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57585</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Thu, 30 May 2019 21:18:44 GMT</pubDate></item><item><title><![CDATA[Reply to At my Wits end! Overscan/Underscan. Nothing changes on Thu, 30 May 2019 21:10:49 GMT]]></title><description><![CDATA[<p dir="auto">Any other device, PC, DVD Player, PS4, what ever i plug it its fine. Raspi homepage. spilling outside screen area.</p>
]]></description><link>https://forum.magicmirror.builders/post/57584</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57584</guid><dc:creator><![CDATA[JonoGee]]></dc:creator><pubDate>Thu, 30 May 2019 21:10:49 GMT</pubDate></item><item><title><![CDATA[Reply to At my Wits end! Overscan/Underscan. Nothing changes on Thu, 30 May 2019 20:54:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cirdan" aria-label="Profile: cirdan">@<bdi>cirdan</bdi></a> It was displaying fine with a black border actually during the Raspi setup and I ticked something during setup and its been like this since.</p>
]]></description><link>https://forum.magicmirror.builders/post/57583</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57583</guid><dc:creator><![CDATA[JonoGee]]></dc:creator><pubDate>Thu, 30 May 2019 20:54:07 GMT</pubDate></item><item><title><![CDATA[Reply to At my Wits end! Overscan/Underscan. Nothing changes on Thu, 30 May 2019 19:27:49 GMT]]></title><description><![CDATA[<p dir="auto">Sometimes you can fix/set overscan in the menu of the  monitor, may be this helps?</p>
]]></description><link>https://forum.magicmirror.builders/post/57581</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57581</guid><dc:creator><![CDATA[cirdan]]></dc:creator><pubDate>Thu, 30 May 2019 19:27:49 GMT</pubDate></item><item><title><![CDATA[Reply to At my Wits end! Overscan/Underscan. Nothing changes on Thu, 30 May 2019 17:59:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jonogee" aria-label="Profile: JonoGee">@<bdi>JonoGee</bdi></a> said in <a href="/post/57578">At my Wits end! Overscan/Underscan. Nothing changes</a>:</p>
<p dir="auto">I am not sure where i should be putting…</p>
<p dir="auto">They are not config entries.<br />
Just execute those commands from the command-line.</p>
<p dir="auto">The config file entries in your first post, are they yours or just an example ?</p>
<p dir="auto">Let’s start with the tvservice commands.<br />
Please post the output, then we take it from there.</p>
<pre><code>$ tvservice -m CEA
$ tvservice -m DMT
$ tvservice -s
<p dir="auto">Not an expert on the topic, but who knows we straighten this out together :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/57580</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57580</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Thu, 30 May 2019 17:59:50 GMT</pubDate></item><item><title><![CDATA[Reply to At my Wits end! Overscan/Underscan. Nothing changes on Thu, 30 May 2019 17:06:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a><br />
Hi buddy,<br />
I tried disabling out all overscan settings etc. It didn’t make the slightest change, neither did…</p>
<pre><code>hdmi_group=1
hdmi_mode=16
$ tvservice -m DMT
<p dir="auto">I checked out those links and nothing I do at all makes any change whatsoever. I see no adjustment or anything. I’d be happy if i did then i could keep adjusting, rebooting, and re-adjust accordingly until it was right.</p>
<p dir="auto">THankyou for your time anyway trying to help me sort this. I really appreciate it.<br />
BR</p>
]]></description><link>https://forum.magicmirror.builders/post/57578</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57578</guid><dc:creator><![CDATA[JonoGee]]></dc:creator><pubDate>Thu, 30 May 2019 17:06:45 GMT</pubDate></item><item><title><![CDATA[Reply to At my Wits end! Overscan/Underscan. Nothing changes on Wed, 29 May 2019 20:32:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jonogee" aria-label="Profile: JonoGee">@<bdi>JonoGee</bdi></a></p>
<p dir="auto">See these URLs for details, if not known already:<br />
<a href="https://www.raspberrypi.org/documentation/configuration/hdmi-config.md" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/documentation/configuration/hdmi-config.md</a><br />
<a href="https://www.raspberrypi.org/documentation/configuration/config-txt/video.md" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/documentation/configuration/config-txt/video.md</a></p>
<p dir="auto">Can you try this ?</p>
$ tvservice -m DMT
<p dir="auto">This will give you the hdmi_group that can be used and the preferred hdmi_mode.</p>
hdmi_mode=16
<p dir="auto">This means CEA 1080p @60Hz.</p>
<p dir="auto">And what happens when you comment out disable_overscan and the overscan settings ?</p>
]]></description><link>https://forum.magicmirror.builders/post/57555</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57555</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Wed, 29 May 2019 20:32:21 GMT</pubDate></item><item><title><![CDATA[Reply to At my Wits end! Overscan/Underscan. Nothing changes on Wed, 29 May 2019 20:17:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jonogee" aria-label="Profile: JonoGee">@<bdi>JonoGee</bdi></a> ok… don’t have a solution myself, just trying to help others get clear idea of problem…  I searched and all the things I saw are the same as what you have done</p>
]]></description><link>https://forum.magicmirror.builders/post/57553</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57553</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 29 May 2019 20:17:42 GMT</pubDate></item><item><title><![CDATA[Reply to At my Wits end! Overscan/Underscan. Nothing changes on Wed, 29 May 2019 19:39:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> It is the Pi desktop that is too big mate. but equally makes the MM too big too when launched.</p>
]]></description><link>https://forum.magicmirror.builders/post/57548</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57548</guid><dc:creator><![CDATA[JonoGee]]></dc:creator><pubDate>Wed, 29 May 2019 19:39:20 GMT</pubDate></item><item><title><![CDATA[Reply to At my Wits end! Overscan/Underscan. Nothing changes on Wed, 29 May 2019 17:56:53 GMT]]></title><description><![CDATA[<p dir="auto">is this the pi desktop that is too big, or the MagicMirror UI ?</p>
]]></description><link>https://forum.magicmirror.builders/post/57543</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57543</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 29 May 2019 17:56:53 GMT</pubDate></item></channel></rss>
