<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM_MotionEye   Error because its MIME type (&#x27;text&#x2F;html&#x27;) is not executable]]></title><description><![CDATA[<p dir="auto">I get the following error message when starting MM2</p>
<p dir="auto">“Refused to execute script from ‘<a href="http://localhost:8080/modules/MMM_MotionEye//MMM_MotionEye.js" target="_blank" rel="noopener noreferrer nofollow ugc">http://localhost:8080/modules/MMM_MotionEye//MMM_MotionEye.js</a>’ because its MIME type (‘text/html’) is not executable, and strict MIME type checking is enabled.”, source: <a href="http://localhost:8080/" target="_blank" rel="noopener noreferrer nofollow ugc">http://localhost:8080/</a> (0)</p>
<p dir="auto">All other modules start Ok</p>
<p dir="auto">Running On Raspberry PI2,  Raspbian GNU/Linux 9 (stretch)</p>
<p dir="auto">Any idea how to correct this?</p>
]]></description><link>https://forum.magicmirror.builders/topic/10539/mmm_motioneye-error-because-its-mime-type-text-html-is-not-executable</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 23:08:08 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10539.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 May 2019 04:00:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM_MotionEye   Error because its MIME type (&#x27;text&#x2F;html&#x27;) is not executable on Sun, 02 Jun 2019 13:24:46 GMT]]></title><description><![CDATA[<p dir="auto">I’m glad you got it resolved. In the future, please post requests for help in the troubleshooting section of the forum. This area is for showing off new modules.</p>
]]></description><link>https://forum.magicmirror.builders/post/57633</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57633</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Sun, 02 Jun 2019 13:24:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM_MotionEye   Error because its MIME type (&#x27;text&#x2F;html&#x27;) is not executable on Sat, 01 Jun 2019 00:38:27 GMT]]></title><description><![CDATA[<p dir="auto">See i still can’t type.</p>
<p dir="auto">it should read   “Thx for your help, I fixed it” and not read  “Thx for your help, I fixed”</p>
]]></description><link>https://forum.magicmirror.builders/post/57615</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57615</guid><dc:creator><![CDATA[dssdss]]></dc:creator><pubDate>Sat, 01 Jun 2019 00:38:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM_MotionEye   Error because its MIME type (&#x27;text&#x2F;html&#x27;) is not executable on Sat, 01 Jun 2019 00:35:01 GMT]]></title><description><![CDATA[<p dir="auto">Thx for your help, I fixed. It was my bad typing causing the error.<br />
With all the changes i was making to get it to work i typed “_” instead of “-”</p>
<p dir="auto">Thx for your help</p>
]]></description><link>https://forum.magicmirror.builders/post/57614</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57614</guid><dc:creator><![CDATA[dssdss]]></dc:creator><pubDate>Sat, 01 Jun 2019 00:35:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM_MotionEye   Error because its MIME type (&#x27;text&#x2F;html&#x27;) is not executable on Fri, 31 May 2019 05:26:51 GMT]]></title><description><![CDATA[<p dir="auto">1st time I have installed the module.<br />
I have deleted and reconfigured it also 2 times with the same result.<br />
I also tried using Firefox-esr instead of Chromium  and get the same error<br />
This is the 1st time I am using MagicMirror2. I cloned the repository  last week and  default  Modules work.<br />
I also am using module MMM-Sort and it works ok<br />
I also tried a couple of other modules and I got the same error.<br />
From the research I have done most of it points to the webserver config but that is beyond me. Do you know the location of the webserver config file is and  I can try testing that with some of the info I found in my searches.</p>
<p dir="auto">{<br />
module: ‘MMM-MotionEye’,<br />
position: ‘bottom_right’,<br />
config: {<br />
url: “<a href="http://192.168.254.109:8081" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.254.109:8081</a>”,<br />
forcedRefreshInterval: 60000,<br />
width: 400px,<br />
debug: false<br />
}<br />
},</p>
<p dir="auto">thx</p>
]]></description><link>https://forum.magicmirror.builders/post/57596</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57596</guid><dc:creator><![CDATA[dssdss]]></dc:creator><pubDate>Fri, 31 May 2019 05:26:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM_MotionEye   Error because its MIME type (&#x27;text&#x2F;html&#x27;) is not executable on Fri, 31 May 2019 03:06:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dssdss" aria-label="Profile: dssdss">@<bdi>dssdss</bdi></a> - Please post your relevant portion of the <code>config.js</code>. Right now, it looks like you have an extra slash in your path to your module. (the “<code>MMM_MotionEye//MMM_MotionEye.js</code>” part of the error).  At a guess, I would say that your configuration file says something like <code>module: "MMM_MotionEye/"</code>, but I would want to look at it to be sure.</p>
<p dir="auto">Other questions: Has this module worked before for you? Did you see any errors during install?</p>
]]></description><link>https://forum.magicmirror.builders/post/57590</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57590</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Fri, 31 May 2019 03:06:59 GMT</pubDate></item></channel></rss>
