<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Screencast do not work with Pifiberry DAC+]]></title><description><![CDATA[<p dir="auto">I installed the module “MMM-Screencast” and tested it with the jack output of the Raspberry Pi3b +. It works perfectly.</p>
<p dir="auto">Now the sound is very bad, so I installed the Pifiberry DAC +.</p>
<p dir="auto">Only change:<br />
under /boot/config.txt the line</p>
<h1>dtparam = audio = on</h1>
<p dir="auto">commented out and<br />
dtoverlay = hifiberry-dacplus<br />
inserted.</p>
<p dir="auto">Now a file<br />
/etc/asound.conf<br />
created with the following content:</p>
<p dir="auto">pcm.! default {<br />
type hw card 0<br />
}<br />
ctl! default<br />
}</p>
<p dir="auto">Then a restart. now the sound comes over the pifiberry. Everything works fine with the Spotify module. But MMM-Screencast is no longer playing Youtube videos: ((</p>
<p dir="auto">Does one have an idea why it could be? or an alternative to stream Youtube videos ???</p>
]]></description><link>https://forum.magicmirror.builders/topic/10542/mmm-screencast-do-not-work-with-pifiberry-dac</link><generator>RSS for Node</generator><lastBuildDate>Sat, 15 Aug 2026 12:48:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10542.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 May 2019 10:40:22 GMT</pubDate><ttl>60</ttl></channel></rss>
