<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[default clock size?]]></title><description><![CDATA[<p dir="auto">Noob question: how can i make the default clock bigger?</p>
]]></description><link>https://forum.magicmirror.builders/topic/10582/default-clock-size</link><generator>RSS for Node</generator><lastBuildDate>Fri, 04 Sep 2026 20:43:07 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10582.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 07 Jun 2019 04:33:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to default clock size? on Fri, 07 Jun 2019 18:32:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/costascontis" aria-label="Profile: costascontis">@<bdi>costascontis</bdi></a> said in <a href="/post/57756">default clock size?</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a> thnx mate,but if i use transform: scale all the module goes left and off screen like this:</p>
<p dir="auto">Ahh, okey</p>
<p dir="auto">add</p>
<pre><code>transform-origin: top left;
<p dir="auto">under transform: scale</p>
<p dir="auto">Or to change font sizes.</p>
<pre><code>
.clock .time {
 font-size: 100px;
.clock .date {
 font-size: 30px;
]]></description><link>https://forum.magicmirror.builders/post/57759</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57759</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Fri, 07 Jun 2019 18:32:08 GMT</pubDate></item><item><title><![CDATA[Reply to default clock size? on Fri, 07 Jun 2019 16:54:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a> thnx mate,but if i use transform: scale all the module goes left and off screen like this:<br />
<img src="/assets/uploads/files/1559926471241-screenshot-15.png" alt="0_1559926469988_Screenshot (15).png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/57756</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57756</guid><dc:creator><![CDATA[costascontis]]></dc:creator><pubDate>Fri, 07 Jun 2019 16:54:34 GMT</pubDate></item><item><title><![CDATA[Reply to default clock size? on Fri, 07 Jun 2019 14:47:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/costascontis" aria-label="Profile: costascontis">@<bdi>costascontis</bdi></a></p>
<p dir="auto">try adding this to your custom.css file</p>
<pre><code>
.clock {
transform: scale(1.2);
<p dir="auto">Or if you want more control you could change the font size itself, but the above will scale the entire module.</p>
]]></description><link>https://forum.magicmirror.builders/post/57755</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57755</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Fri, 07 Jun 2019 14:47:23 GMT</pubDate></item><item><title><![CDATA[Reply to default clock size? on Fri, 07 Jun 2019 09:53:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedoorsfanatic" aria-label="Profile: thedoorsfanatic">@<bdi>thedoorsfanatic</bdi></a> i use the digital one,i just want it little bigger in size so my old eyes can see it from some distance :)</p>
]]></description><link>https://forum.magicmirror.builders/post/57750</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57750</guid><dc:creator><![CDATA[costascontis]]></dc:creator><pubDate>Fri, 07 Jun 2019 09:53:14 GMT</pubDate></item><item><title><![CDATA[Reply to default clock size? on Fri, 07 Jun 2019 09:16:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/costascontis" aria-label="Profile: costascontis">@<bdi>costascontis</bdi></a><br />
Are you using the digital or analog displayType?<br />
There is a setting for the analogSize where you can use a number as pixel size</p>
]]></description><link>https://forum.magicmirror.builders/post/57747</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57747</guid><dc:creator><![CDATA[thedoorsfanatic]]></dc:creator><pubDate>Fri, 07 Jun 2019 09:16:29 GMT</pubDate></item></channel></rss>
