<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Calendar does not appear]]></title><description><![CDATA[<p dir="auto">Hey everyone,</p>
<p dir="auto">I’m trying to fix an issue with my outlook calendar.<br />
I’ve got the <code>.ics</code> link and put it into the <code>config.js</code>, everything fine.</p>
<p dir="auto">But when I start the mirror it only says:<br />
<code>Loading...</code></p>
<p dir="auto">Other <code>.ics</code> (google, holidays…) works fine for me, it’s only this one that refuses.</p>
<p dir="auto">Is there any known problem with the outlook-calendar?</p>
<p dir="auto">Thanks,<br />
ehNorm</p>
]]></description><link>https://forum.magicmirror.builders/topic/106/calendar-does-not-appear</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 16:22:33 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/106.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 May 2016 15:26:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Calendar does not appear on Tue, 24 May 2016 21:41:11 GMT]]></title><description><![CDATA[<pre><code>Kalender-0 (out): No helper found for module: alert.
Kalender-0 (out): No helper found for module: clock.
Kalender-0 (out): Initializing new module helper ...
Kalender-0 (out): No helper found for module: currentweather.
Kalender-0 (out): No helper found for module: weatherforecast.
Kalender-0 (out): All module helpers loaded.
Kalender-0 (out): Starting server op port 8080 ...
Kalender-0 (out): Server started ...
Kalender-0 (out): Connecting socket for: calendar
Kalender-0 (out): Starting node helper for: calendar
Kalender-0 (out): Connecting socket for: newsfeed
Kalender-0 (out): Starting module: newsfeed
Kalender-0 (out): Sockets connected &amp; modules started ...
Kalender-0 (out): Launching application.
Kalender-0 (out): Create new calendar fetcher for url: webcals://sharing.calendar.live.com/calendar/private/SOME-NUMBERS/calendar.ics - Interval: 300000
Kalender-0 (out): Create new news fetcher for url: http://feeds.feedburner.com/blogspot/rkEL - Interval: 300000
Kalender-0 (out): Whoops! There was an uncaught exception...
Kalender-0 (out): MagicMirror will not quit, but it might be a good idea to chec        k why this happened. Maybe no internet connection?
Kalender-0 (out): If you think this really is an issue, please open an issue on        GitHub: https://github.com/MichMich/MagicMirror/issues
Kalender-0 (err): { [Error: listen EADDRINUSE :::8080]
Kalender-0 (err):   code: 'EADDRINUSE',
Kalender-0 (err):   errno: 'EADDRINUSE',
Kalender-0 (err):   syscall: 'listen',
Kalender-0 (err):   address: '::',
Kalender-0 (err):   port: 8080 }
Kalender-0 (err): /usr/bin/unclutter: someone created a sub-window to my sub-win        dow! giving up
Kalender-0 (err): X Error of failed request:  BadWindow (invalid Window paramete        r)
Kalender-0 (err):   Major opcode of failed request:  20 (X_GetProperty)
Kalender-0 (err):   Resource id in failed request:  0x2000001
Kalender-0 (err):   Serial number of failed request:  46
Kalender-0 (err):   Current serial number in output stream:  46
Kalender-0 (err): { [Error: getaddrinfo EAI_AGAIN feeds.feedburner.com:80]
Kalender-0 (err):   code: 'EAI_AGAIN',
Kalender-0 (err):   errno: 'EAI_AGAIN',
Kalender-0 (err):   syscall: 'getaddrinfo',
Kalender-0 (err):   hostname: 'feeds.feedburner.com',
Kalender-0 (err):   host: 'feeds.feedburner.com',
Kalender-0 (err):   port: 80 }
<p dir="auto">That way?</p>
<hr />
<p dir="auto"><strong>Note from admin:</strong> Please use Markdown on code and shell output snippets so it is easier to read!</p>
]]></description><link>https://forum.magicmirror.builders/post/1019</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1019</guid><dc:creator><![CDATA[ehNorm]]></dc:creator><pubDate>Tue, 24 May 2016 21:41:11 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar does not appear on Mon, 23 May 2016 17:43:04 GMT]]></title><description><![CDATA[<p dir="auto">Rather then opening the log files in an editor (nano), can you just run <code>'pm2 logs &lt;YOUR_PROCESS_NAME&gt;'</code> then highlight and paste what you see into a new post (with the proper markdown)? It’s a bit hard to decipher what’s being shown in that text file you uploaded.</p>
]]></description><link>https://forum.magicmirror.builders/post/982</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/982</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Mon, 23 May 2016 17:43:04 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar does not appear on Mon, 23 May 2016 09:43:18 GMT]]></title><description><![CDATA[<p dir="auto">Okay, I didn’t use pm2 but I installed it and I added the log files.</p>
<p dir="auto">I can’t see any error for the calendar…</p>
<p dir="auto"><a href="/uploads/files/1463996586451-pm2-info.txt">0_1463996547833_pm2 info.txt</a></p>
]]></description><link>https://forum.magicmirror.builders/post/980</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/980</guid><dc:creator><![CDATA[ehNorm]]></dc:creator><pubDate>Mon, 23 May 2016 09:43:18 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar does not appear on Mon, 23 May 2016 08:54:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ehnorm" aria-label="Profile: ehNorm">@<bdi>ehNorm</bdi></a></p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/86/how-to-troubleshoot">It’s all right here.</a></p>
]]></description><link>https://forum.magicmirror.builders/post/978</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/978</guid><dc:creator><![CDATA[jtyle6]]></dc:creator><pubDate>Mon, 23 May 2016 08:54:14 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar does not appear on Mon, 23 May 2016 08:26:56 GMT]]></title><description><![CDATA[<p dir="auto">Hey,</p>
<p dir="auto">sorry what do you mean by checking the console output?<br />
When should I check it and how?</p>
<p dir="auto">Many thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/977</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/977</guid><dc:creator><![CDATA[ehNorm]]></dc:creator><pubDate>Mon, 23 May 2016 08:26:56 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar does not appear on Tue, 17 May 2016 19:58:04 GMT]]></title><description><![CDATA[<p dir="auto">Can you check the console output, see if it’s throwing an error?</p>
]]></description><link>https://forum.magicmirror.builders/post/759</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/759</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Tue, 17 May 2016 19:58:04 GMT</pubDate></item></channel></rss>
