<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-AssistantMk2 terminating and not activating by voice after that.]]></title><description><![CDATA[<p dir="auto">G’day to all.<br />
I am having issues with MMM-AssistantMk2 whereby when I launch MagicMirror, the module appears to be working. It makes the “beep” sound from speakers, it initiates the default call (“brief today”) but just towards the conclusion it terminates. From here I am unable to activate any command via voice. I have to activate it via mound (via VNC Viewer). If I activate by mouse it ‘hears’ my command and interprets what I am saying onto the screen, however it fails to respond.</p>
<p dir="auto">I ran it through npm start dev and this was the error I could see:</p>
<pre><code>MMM-Hotword.js:261 Uncaught TypeError: Cannot set property 'className' of null
    at Class.status (MMM-Hotword.js:261)
    at Class.socketNotificationReceived (MMM-Hotword.js:170)
    at module.js:246
    at r.&lt;anonymous&gt; (socketclient.js:25)
    at r.emit (index.js:83)
    at r.onevent (index.js:83)
    at r.MMSocket.self.socket.onevent (socketclient.js:19)
    at r.onpacket (index.js:83)
    at r.&lt;anonymous&gt; (index.js:83)
<p dir="auto">Any assistance in this matter would be greatly appreciated.<br />
Regards,<br />
BJ Duncan</p>
]]></description><link>https://forum.magicmirror.builders/topic/10621/mmm-assistantmk2-terminating-and-not-activating-by-voice-after-that</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 20:05:36 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10621.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 Jun 2019 09:37:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-AssistantMk2 terminating and not activating by voice after that. on Mon, 17 Jun 2019 08:49:02 GMT]]></title><description><![CDATA[<p dir="auto">@Sean said in <a href="/post/58028">MMM-AssistantMk2 terminating and not activating by voice after that.</a>:</p>
<p dir="auto">mpg321</p>
<p dir="auto">Woo-Hoo! - Thank you so much @Sean - That worked for me. I just reinstalled (or maybe just installed) mpg321 and it is completing the whole sentence without any cutoff. #veryHapppy :-)</p>
<p dir="auto">The code I used was:</p>
<pre><code>sudo apt-get -y install mpg321
<p dir="auto">Thanks to all that contributed to this post and I hope it helps others out just as it helped me.</p>
<p dir="auto">Regards,<br />
BJ Duncan</p>
]]></description><link>https://forum.magicmirror.builders/post/58037</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58037</guid><dc:creator><![CDATA[BJ Duncan]]></dc:creator><pubDate>Mon, 17 Jun 2019 08:49:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AssistantMk2 terminating and not activating by voice after that. on Sun, 16 Jun 2019 19:34:45 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/ivanov_d" aria-label="Profile: Ivanov_d">@<bdi>Ivanov_d</bdi></a> I found that link the other day and did try those solutions. They didn’t work for me.</p>
<p dir="auto">However, I will try @Sean’s suggestion and will post back on the forum if it worked or not.</p>
<p dir="auto">Thanks to everyone for your assistance. Very much appreciated.</p>
BJ Duncan</p>
]]></description><link>https://forum.magicmirror.builders/post/58032</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58032</guid><dc:creator><![CDATA[BJ Duncan]]></dc:creator><pubDate>Sun, 16 Jun 2019 19:34:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AssistantMk2 terminating and not activating by voice after that. on Sun, 16 Jun 2019 16:26:20 GMT]]></title><description><![CDATA[<p dir="auto">Today, I’ve reported from one of users, he says old mpg321 could clip the last part of response. try to update it or reinstall or, at least try other play program.</p>
]]></description><link>https://forum.magicmirror.builders/post/58028</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58028</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 16 Jun 2019 16:26:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AssistantMk2 terminating and not activating by voice after that. on Sun, 16 Jun 2019 15:20:13 GMT]]></title><description><![CDATA[<p dir="auto">This is a known issue and it is tracked in <a href="https://github.com/eouia/MMM-AssistantMk2/issues/161#issuecomment-496287957" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/eouia/MMM-AssistantMk2/issues/161#issuecomment-496287957</a></p>
<p dir="auto">You can try the various solutions proposed by the developer of the module. I have the same issue and I am waiting for a fix as well.</p>
]]></description><link>https://forum.magicmirror.builders/post/58022</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58022</guid><dc:creator><![CDATA[Ivanov_d]]></dc:creator><pubDate>Sun, 16 Jun 2019 15:20:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AssistantMk2 terminating and not activating by voice after that. on Sat, 15 Jun 2019 00:21:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bj-duncan" aria-label="Profile: BJ-Duncan">@<bdi>BJ-Duncan</bdi></a> no… he reworked the audio in V2 to behave better… but apparently hasn’t got it all working perfect yet…</p>
<p dir="auto">I noticed before similar for you… long answers worked, short were clipped</p>
]]></description><link>https://forum.magicmirror.builders/post/57986</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57986</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 15 Jun 2019 00:21:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AssistantMk2 terminating and not activating by voice after that. on Fri, 14 Jun 2019 23:23:09 GMT]]></title><description><![CDATA[<p dir="auto">So I have been testing random things and I have noticed that if I ask it to tell me a joke, it actually completes that request. If I ask it for any type of information (eg. weather, time, who invented the telephone etc) that’s when it cuts off.</p>
<p dir="auto">Could it be something to do with sending a request online?</p>
]]></description><link>https://forum.magicmirror.builders/post/57985</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57985</guid><dc:creator><![CDATA[BJ Duncan]]></dc:creator><pubDate>Fri, 14 Jun 2019 23:23:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AssistantMk2 terminating and not activating by voice after that. on Fri, 14 Jun 2019 23:20:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Is there some setting I need to adjust to allow it to complete the request? Have I inadvertently changed a default setting somewhere?</p>
]]></description><link>https://forum.magicmirror.builders/post/57984</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57984</guid><dc:creator><![CDATA[BJ Duncan]]></dc:creator><pubDate>Fri, 14 Jun 2019 23:20:38 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AssistantMk2 terminating and not activating by voice after that. on Fri, 14 Jun 2019 23:16:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bj-duncan" aria-label="Profile: BJ-Duncan">@<bdi>BJ-Duncan</bdi></a> thats funny… it used to chop off the beginning of the reply… !</p>
]]></description><link>https://forum.magicmirror.builders/post/57983</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57983</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 14 Jun 2019 23:16:50 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AssistantMk2 terminating and not activating by voice after that. on Fri, 14 Jun 2019 23:07:11 GMT]]></title><description><![CDATA[<p dir="auto">So I’m almost there now. I realised that I had the incorrect data within my config.js file as I used the configuration for <a href="https://github.com/eouia/MMM-AssistantMk2/wiki/Configuration#with-mmm-hotwordv1-using-usb-mic-plughw1" target="_blank" rel="noopener noreferrer nofollow ugc">v1</a> rather than <a href="https://github.com/eouia/MMM-AssistantMk2/wiki/Configuration#with-mmm-hotwordv2" target="_blank" rel="noopener noreferrer nofollow ugc">v2</a>. I also added the same position as the MMM-AssistantMk2 with the config.js (thanks to @Sean for that ;-) )</p>
<p dir="auto">My only issue now is that it still seems to terminate before completing the return request.<br />
E.g.<br />
Me: “Smart Mirror, what is the time?”<br />
(OSD: “what is the time?”)<br />
AssistantMk2: “The time is 8” - terminates<br />
(OSD: returns back to original icon immediately after termination.)<br />
– no ererors appear when I run this in dev mode –</p>
<p dir="auto">This occurs after each attempt regardless of the actual question. Could there possibly be a conflict with another module? Has anyone else come across this issue?</p>
BJ Duncan</p>
]]></description><link>https://forum.magicmirror.builders/post/57982</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57982</guid><dc:creator><![CDATA[BJ Duncan]]></dc:creator><pubDate>Fri, 14 Jun 2019 23:07:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AssistantMk2 terminating and not activating by voice after that. on Fri, 14 Jun 2019 22:51:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/blee1997" aria-label="Profile: blee1997">@<bdi>blee1997</bdi></a> - It would not acknowledge or activate when I say “smart mirror”, “hey google” or anything. I am not even sure how to set that actual activating word/s. I assumed the default was “smart mirror”. But if I click the icon with the mouse it will listen to anything and interpret anything I say including the above mentioned words.</p>
<p dir="auto">@Sean - Looking through the config.js it doesn’t appear to have position, so I will give that a go also.</p>
<p dir="auto">Thanks for replying and I will keep at it and will reply once I have a solution.</p>
BJ Duncan</p>
]]></description><link>https://forum.magicmirror.builders/post/57981</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57981</guid><dc:creator><![CDATA[BJ Duncan]]></dc:creator><pubDate>Fri, 14 Jun 2019 22:51:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AssistantMk2 terminating and not activating by voice after that. on Fri, 14 Jun 2019 20:12:30 GMT]]></title><description><![CDATA[<p dir="auto">you might have not assigned the position of hotword module.</p>
]]></description><link>https://forum.magicmirror.builders/post/57980</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57980</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 14 Jun 2019 20:12:30 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AssistantMk2 terminating and not activating by voice after that. on Fri, 14 Jun 2019 19:44:27 GMT]]></title><description><![CDATA[<p dir="auto">Would this error only occur when saying the Activation word or would it time out after 10-15 seconds and show you the error. I also encountered a similar error message but not sure on what is happening either.</p>
]]></description><link>https://forum.magicmirror.builders/post/57979</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57979</guid><dc:creator><![CDATA[blee1997]]></dc:creator><pubDate>Fri, 14 Jun 2019 19:44:27 GMT</pubDate></item></channel></rss>
