<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-GoogleMapsTraffic has impact on other modules]]></title><description><![CDATA[<p dir="auto">Dear community*,</p>
<p dir="auto">I am a beginner and got MMM-GoogleMapsTraffic module running with no problem. But using it it has an impact on other modules. For example MMM-mvgmunich ist not working as long as I disable MMM-GoogleMapsTraffic.</p>
<p dir="auto">Does any of you programmers out there an answer why this happens?</p>
<p dir="auto">*Excuse my bad English since I am from Germany</p>
]]></description><link>https://forum.magicmirror.builders/topic/10637/mmm-googlemapstraffic-has-impact-on-other-modules</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 09:56:47 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10637.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Jun 2019 06:21:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Fri, 05 Jul 2019 11:14:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedoorsfanatic" aria-label="Profile: thedoorsfanatic">@<bdi>thedoorsfanatic</bdi></a> Ne sorry, da habe ich gerade keine Lösung. Aber ist das nicht eine Konfigurationssache? Also dort wo du das Modul in MagicMirror einbindest?</p>
]]></description><link>https://forum.magicmirror.builders/post/58553</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58553</guid><dc:creator><![CDATA[nischi]]></dc:creator><pubDate>Fri, 05 Jul 2019 11:14:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Fri, 05 Jul 2019 10:25:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nischi" aria-label="Profile: nischi">@<bdi>nischi</bdi></a><br />
Das mit dem git pull hat nicht funktioniert, vielleicht weil man das Modul in mvgmunich umbenannt werden muss?</p>
<p dir="auto">Wenn ich die aktuelle Version klone, werden meine maxentries Werte ignoriert, also nur noch drei anstatt wie bei mir vorher sechs Abfahrten angezeigt.</p>
<p dir="auto">Hast du hierfür auch einen Lösungsansatz?</p>
]]></description><link>https://forum.magicmirror.builders/post/58551</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58551</guid><dc:creator><![CDATA[thedoorsfanatic]]></dc:creator><pubDate>Fri, 05 Jul 2019 10:25:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Thu, 27 Jun 2019 14:07:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sardauker" aria-label="Profile: sardauker">@<bdi>sardauker</bdi></a> if you have both enabled, and open the developers windows, with ctrl-shift-i, and select the console tab,. and scroll up… are there any errors?  (usually red text)…</p>
<p dir="auto">this sounds like a variable name collision</p>
]]></description><link>https://forum.magicmirror.builders/post/58315</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58315</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 27 Jun 2019 14:07:21 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Thu, 27 Jun 2019 14:02:21 GMT]]></title><description><![CDATA[<p dir="auto">AAAAnd I’ve found that the same problem happens with Mycommute.<br />
just to raise a flag.<br />
Commented the MMM-GoogleMpasTraffic and mycommute started working again.</p>
]]></description><link>https://forum.magicmirror.builders/post/58314</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58314</guid><dc:creator><![CDATA[sardauker]]></dc:creator><pubDate>Thu, 27 Jun 2019 14:02:21 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Thu, 27 Jun 2019 10:41:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedoorsfanatic" aria-label="Profile: thedoorsfanatic">@<bdi>thedoorsfanatic</bdi></a><br />
Genau 👍</p>
]]></description><link>https://forum.magicmirror.builders/post/58302</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58302</guid><dc:creator><![CDATA[nischi]]></dc:creator><pubDate>Thu, 27 Jun 2019 10:41:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Thu, 27 Jun 2019 07:02:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nischi" aria-label="Profile: nischi">@<bdi>nischi</bdi></a><br />
Coole Sache!<br />
Sorry, bin Neuling, ich muss dann einen Git Pull machen, oder?</p>
]]></description><link>https://forum.magicmirror.builders/post/58297</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58297</guid><dc:creator><![CDATA[thedoorsfanatic]]></dc:creator><pubDate>Thu, 27 Jun 2019 07:02:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Thu, 27 Jun 2019 06:08:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedoorsfanatic" aria-label="Profile: thedoorsfanatic">@<bdi>thedoorsfanatic</bdi></a></p>
<p dir="auto">Die Änderung am Modul wurden akzeptiert und sind in der neuen Version drin.</p>
<p dir="auto"><a href="https://github.com/mrVragec/MMM-mvgmunich/pull/26" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/mrVragec/MMM-mvgmunich/pull/26</a></p>
]]></description><link>https://forum.magicmirror.builders/post/58295</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58295</guid><dc:creator><![CDATA[nischi]]></dc:creator><pubDate>Thu, 27 Jun 2019 06:08:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Mon, 24 Jun 2019 08:06:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedoorsfanatic" aria-label="Profile: thedoorsfanatic">@<bdi>thedoorsfanatic</bdi></a><br />
Leider ist auch nach einer Stunde die Situation nicht anders.<br />
Wenn du die Config mit mir durchgehen willst, würde mir das sehr helfen.<br />
über PN?</p>
]]></description><link>https://forum.magicmirror.builders/post/58167</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58167</guid><dc:creator><![CDATA[spitzlbergerj]]></dc:creator><pubDate>Mon, 24 Jun 2019 08:06:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Mon, 24 Jun 2019 07:05:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spitzlbergerj" aria-label="Profile: spitzlbergerj">@<bdi>spitzlbergerj</bdi></a><br />
Evtl. dauert es noch etwas.<br />
Ansonsten können wir gerne mal die config vergleichen. Ich bin aber ziemlicher Anfänger. Ich kann mich nicht erinnern, dass ich etwas an der API eingestellt hätte.</p>
]]></description><link>https://forum.magicmirror.builders/post/58166</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58166</guid><dc:creator><![CDATA[thedoorsfanatic]]></dc:creator><pubDate>Mon, 24 Jun 2019 07:05:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Mon, 24 Jun 2019 06:59:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedoorsfanatic" aria-label="Profile: thedoorsfanatic">@<bdi>thedoorsfanatic</bdi></a><br />
ok, war für dieses Projekt nicht aktiviert. Ist es jetzt seit ein paar Minuten.<br />
Leider funktioniert es immer noch nicht. Gleicher Effekt wie vorher.</p>
]]></description><link>https://forum.magicmirror.builders/post/58165</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58165</guid><dc:creator><![CDATA[spitzlbergerj]]></dc:creator><pubDate>Mon, 24 Jun 2019 06:59:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Mon, 24 Jun 2019 06:17:56 GMT]]></title><description><![CDATA[<p dir="auto">eigentlich ja, aber ich kontrolliere das gleich nochmal</p>
]]></description><link>https://forum.magicmirror.builders/post/58161</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58161</guid><dc:creator><![CDATA[spitzlbergerj]]></dc:creator><pubDate>Mon, 24 Jun 2019 06:17:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Mon, 24 Jun 2019 06:12:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spitzlbergerj" aria-label="Profile: spitzlbergerj">@<bdi>spitzlbergerj</bdi></a><br />
Hast du dein Rechnungskonto eingerichtet?</p>
]]></description><link>https://forum.magicmirror.builders/post/58160</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58160</guid><dc:creator><![CDATA[thedoorsfanatic]]></dc:creator><pubDate>Mon, 24 Jun 2019 06:12:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Mon, 24 Jun 2019 05:25:14 GMT]]></title><description><![CDATA[<p dir="auto">Hi ihr beiden,</p>
<p dir="auto">Vielen Dank, das hilft auch mir.</p>
<p dir="auto">Wie habt ihr denn das mit dem API Key gelöst? Bei mir kommt immer die “Google-nicht-mehr-kostenlos-Anzeige” “Google Maps kann … nicht richtig geladen werden”.</p>
<p dir="auto">Der Key ist eingerichtet und eingeschränkt auf API und eine lokale IP-Adresse (wie in der Doku bei Google dargestellt). Anscheinend mach ich dennoch etwas falsch …</p>
<p dir="auto">Wäre für eine Tipp dankbar!</p>
<p dir="auto">Viele Grüße</p>
<p dir="auto">Sepp</p>
]]></description><link>https://forum.magicmirror.builders/post/58159</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58159</guid><dc:creator><![CDATA[spitzlbergerj]]></dc:creator><pubDate>Mon, 24 Jun 2019 05:25:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Sat, 22 Jun 2019 19:33:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedoorsfanatic" aria-label="Profile: thedoorsfanatic">@<bdi>thedoorsfanatic</bdi></a></p>
<p dir="auto">Bin froh wenn ich dir helfen konnte. 👍</p>
]]></description><link>https://forum.magicmirror.builders/post/58145</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58145</guid><dc:creator><![CDATA[nischi]]></dc:creator><pubDate>Sat, 22 Jun 2019 19:33:38 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Sun, 23 Jun 2019 13:14:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nischi" aria-label="Profile: nischi">@<bdi>nischi</bdi></a></p>
<p dir="auto">Genau das scheint es gewesen zu sein, jetzt funktionieren tatsächlich beide Module gleichzeitig. Merci für die Mühe und das prompte Feedback!</p>
<p dir="auto">English:<br />
That was probably it, both modules work now simultaneously. Thanks so much for the effort!</p>
<p dir="auto"><img src="/assets/uploads/files/1561295678006-unbenannt-1.png" alt="0_1561295678869_unbenannt (1).png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/58137</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58137</guid><dc:creator><![CDATA[thedoorsfanatic]]></dc:creator><pubDate>Sun, 23 Jun 2019 13:14:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Fri, 21 Jun 2019 15:12:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedoorsfanatic" aria-label="Profile: thedoorsfanatic">@<bdi>thedoorsfanatic</bdi></a><br />
Ich glaube ich habe den Fehler gefunden:<br />
<p dir="auto">Ich habe das beim Modul angepasst, eventuell nimmt es der Entwickler ja dann in eine neue Version. Aber wenn du das einfach bei dir korrigieren willst musst du eine Datei anpassen (Zeile löschen).</p>
<p dir="auto">Lösche einfach das console.log in der Datei mvgmunich.js wie hier:<br />
<a href="https://github.com/mrVragec/MMM-mvgmunich/pull/26/files#diff-854ac3b937be8e5d18df1230031cf3ecL201" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/mrVragec/MMM-mvgmunich/pull/26/files#diff-854ac3b937be8e5d18df1230031cf3ecL201</a></p>
]]></description><link>https://forum.magicmirror.builders/post/58124</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58124</guid><dc:creator><![CDATA[nischi]]></dc:creator><pubDate>Fri, 21 Jun 2019 15:12:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Fri, 21 Jun 2019 04:16:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedoorsfanatic" aria-label="Profile: thedoorsfanatic">@<bdi>thedoorsfanatic</bdi></a><br />
Ich habe zwei drei ideen an was es liegen könnte, muss das zuhause mal kurz testen.</p>
]]></description><link>https://forum.magicmirror.builders/post/58113</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58113</guid><dc:creator><![CDATA[nischi]]></dc:creator><pubDate>Fri, 21 Jun 2019 04:16:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Wed, 19 Jun 2019 11:58:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nischi" aria-label="Profile: nischi">@<bdi>nischi</bdi></a><br />
Das Modul MMM-mvgmunich lädt keine Stationen mehr, solange GoogleMapsTraffic aktiviert ist. Erst nach der Deaktivierung läuft es wieder ganz normal. Andere scheinen auch Probleme zu haben (z.B. <a href="https://forum.magicmirror.builders/topic/8689/mmm-googlemapstraffic-breaks-mmm-keybindings">https://forum.magicmirror.builders/topic/8689/mmm-googlemapstraffic-breaks-mmm-keybindings</a>) und da ich keine Ahnung von Programmierung habe, habe ich mich an dieses Forum gewendet. Der Entwickler reagiert jedenfalls nicht auf mein Issue (<a href="https://github.com/vicmora/MMM-GoogleMapsTraffic/issues/30" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/vicmora/MMM-GoogleMapsTraffic/issues/30</a>)</p>
<p dir="auto">Irgendeine Idee? Würde nämlich gerne beide Module benutzen …</p>
<p dir="auto">Danke!</p>
]]></description><link>https://forum.magicmirror.builders/post/58072</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58072</guid><dc:creator><![CDATA[thedoorsfanatic]]></dc:creator><pubDate>Wed, 19 Jun 2019 11:58:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic has impact on other modules on Wed, 19 Jun 2019 11:24:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedoorsfanatic" aria-label="Profile: thedoorsfanatic">@<bdi>thedoorsfanatic</bdi></a><br />
Was genau meinst du mit es geht nicht? Wird gar nichts angezeigt?</p>
]]></description><link>https://forum.magicmirror.builders/post/58071</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58071</guid><dc:creator><![CDATA[nischi]]></dc:creator><pubDate>Wed, 19 Jun 2019 11:24:05 GMT</pubDate></item></channel></rss>
