<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-GooglePhotos latest update June 26 failed to launch]]></title><description><![CDATA[<p dir="auto">Latest update on June 26. Below is the pm2 logs mm</p>
<p dir="auto">0|mm       | Launching application.</p>
<p dir="auto">/home/pi/.pm2/logs/mm-error-0.log last 15 lines:<br />
0|mm       |     at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)<br />
0|mm       |     at Module.load (internal/modules/cjs/loader.js:620:32)<br />
0|mm       | { Error: Cannot find module ‘open’<br />
0|mm       |     at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)<br />
0|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)<br />
0|mm       |     at Function.Module._load (internal/modules/cjs/loader.js:528:25)<br />
0|mm       |     at Module.require (internal/modules/cjs/loader.js:658:17)<br />
0|mm       |     at require (internal/modules/cjs/helpers.js:20:18)<br />
0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-GooglePhotos/auth.js:6:13)<br />
0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-GooglePhotos/auth.js:120:3)<br />
0|mm       |     at Module._compile (internal/modules/cjs/loader.js:711:30)<br />
0|mm       |     at Module.load (internal/modules/cjs/loader.js:620:32) code: ‘MODULE_NOT_FOUND’ }<br />
0|mm       | /proc/self/exe: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /proc/self/exe)<br />
0|mm       | ATTENTION: default value of option force_s3tc_enable overridden by environment.</p>
<p dir="auto">^C<br />
pi@rpiMM:~/MagicMirror $<br />
pi@rpiMM:~/MagicMirror $ cd modules/</p>
]]></description><link>https://forum.magicmirror.builders/topic/10672/mmm-googlephotos-latest-update-june-26-failed-to-launch</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 23:36:49 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10672.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 27 Jun 2019 01:18:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-GooglePhotos latest update June 26 failed to launch on Sun, 30 Jun 2019 00:59:17 GMT]]></title><description><![CDATA[<p dir="auto">it works. thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/58354</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58354</guid><dc:creator><![CDATA[nagaculun]]></dc:creator><pubDate>Sun, 30 Jun 2019 00:59:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GooglePhotos latest update June 26 failed to launch on Thu, 27 Jun 2019 04:38:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nagaculun" aria-label="Profile: nagaculun">@<bdi>nagaculun</bdi></a><br />
do ‘npm install’ on Mmm-googlephotos directory and try again</p>
]]></description><link>https://forum.magicmirror.builders/post/58291</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58291</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 27 Jun 2019 04:38:06 GMT</pubDate></item></channel></rss>
