<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[windows remote desktop doesn't show same screen as on hdmi]]></title><description><![CDATA[<p dir="auto">Hi<br />
I’m using tightvncserver on my pi.<br />
Connected to the pi is a hdmi monitor.</p>
<p dir="auto">When I connect via windows remote desktop to the pi, I don’t see the same screen as it is shown on hdmi.</p>
<p dir="auto">How can I fix this?</p>
<p dir="auto">thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/1068/windows-remote-desktop-doesn-t-show-same-screen-as-on-hdmi</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 13:59:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1068.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Nov 2016 03:29:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to windows remote desktop doesn't show same screen as on hdmi on Sun, 27 Nov 2016 11:41:15 GMT]]></title><description><![CDATA[<p dir="auto">Thnaks, that makes it a lot easier ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/8561</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8561</guid><dc:creator><![CDATA[Jeff]]></dc:creator><pubDate>Sun, 27 Nov 2016 11:41:15 GMT</pubDate></item><item><title><![CDATA[Reply to windows remote desktop doesn't show same screen as on hdmi on Sun, 27 Nov 2016 10:11:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jeff" aria-label="Profile: Jeff">@<bdi>Jeff</bdi></a></p>
<p dir="auto">Hi,</p>
<p dir="auto">you don’t need to login with VNC or RemoteDesktop.<br />
Just type in your desktop browser the adress of your MM2 with the right port number, for example like this <a href="http://192.123.123.12:8080/" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.123.123.12:8080/</a> (8080 is the standard port) and the you see your MM2.<br />
It works without problems in the same network.<br />
If you want to use it from a external network, u must install port forwarding at your router.</p>
<p dir="auto">Good luck</p>
]]></description><link>https://forum.magicmirror.builders/post/8551</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8551</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Sun, 27 Nov 2016 10:11:45 GMT</pubDate></item></channel></rss>
