<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Need help for building magic mirror from scratch]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/8/introduce-yourself">Introduce yourself!</a><br />
hi…Hayyat Ali here…i m a student of BS computer science.Fantastic project I m interested to build a magic mirror for my semester project but really don’t know how should i start like from where to start???what’s the whole procedure of building this fantastic magic mirror…which operating system,which hardware should i use???plzzz guide me properly so that i will b able to build my own magic mirror and enhance my learning…eagerly waiting for your guidance and help…:slightly_smiling_face: :slightly_smiling_face:</p>
]]></description><link>https://forum.magicmirror.builders/topic/10693/need-help-for-building-magic-mirror-from-scratch</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Jul 2026 05:52:57 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10693.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 Jul 2019 14:10:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Need help for building magic mirror from scratch on Mon, 08 Jul 2019 06:33:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hayyatali" aria-label="Profile: HayyatAli">@<bdi>HayyatAli</bdi></a><br />
I’ve already built four or five magic mirrors now.  I always proceed the same way:</p>
<ul>
<li>Buying the Raspberry Pi, as <a class="plugin-mentions-user plugin-mentions-a" href="/user/nischi" aria-label="Profile: nischi">@<bdi>nischi</bdi></a> has already posted</li>
<li>Buy a monitor the size you want to install later.<br />
Please make sure that you get a monitor that switches to sleep mode without a signal on HDMI and does not switch to a completely green or blue screen for minutes before :-)</li>
<li>Installation of Raspian</li>
<li>Installing Magic Mirror<br />
(just follow the hint from <a class="plugin-mentions-user plugin-mentions-a" href="/user/nischi" aria-label="Profile: nischi">@<bdi>nischi</bdi></a> here)</li>
<li>Installation of additional components such as motion detectors or a button to reboot the Raspberry</li>
<li>then run the whole thing without wooden frame and mirror for a few days/weeks to detect bugs, try modules, detect incompatibilities, etc.</li>
<li>Construction of a frame from e.g. wood<br />
Then take measurements for the mirror glass.</li>
<li>Purchase of a spy mirror</li>
<li>Assembly of components</li>
</ul>
<p dir="auto"><a href="http://www.spitzlberger.de/smartmirror" target="_blank" rel="noopener noreferrer nofollow ugc">Here</a> you can find a building instruction for my big mirror in the bathroom. I mounted an aluminium plate behind the spy mirror, which gives the whole thing stability, holds the monitor elegantly and ensures that no light falls through the spy mirror from behind.</p>
<p dir="auto">Greetings<br />
Sepp</p>
]]></description><link>https://forum.magicmirror.builders/post/58686</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58686</guid><dc:creator><![CDATA[spitzlbergerj]]></dc:creator><pubDate>Mon, 08 Jul 2019 06:33:39 GMT</pubDate></item><item><title><![CDATA[Reply to Need help for building magic mirror from scratch on Mon, 01 Jul 2019 15:33:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hayyatali" aria-label="Profile: HayyatAli">@<bdi>HayyatAli</bdi></a> yes, code on GitHub works for many different hardware and os combinations.<br />
I use pi 3b+, odroid, and Jetson nano. Raspian and Ubuntu.</p>
<p dir="auto">Error free? No such thing.  Not many errors in base anymore. Modules… It depends.</p>
<p dir="auto">This is a project, not a product. There is no official support, but community of users helps a lot.<br />
You are welcome to fix and submit errors u find. And make enhancements and submit too.</p>
]]></description><link>https://forum.magicmirror.builders/post/58397</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58397</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 Jul 2019 15:33:42 GMT</pubDate></item><item><title><![CDATA[Reply to Need help for building magic mirror from scratch on Mon, 01 Jul 2019 14:36:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nischi" aria-label="Profile: nischi">@<bdi>nischi</bdi></a><br />
you got the source code of magic mirror from github???<br />
that source code is compatible  with Raspberry Pi 3 or 4???<br />
and plzz also tell the code that is placed on github contains errors or the error free code???</p>
]]></description><link>https://forum.magicmirror.builders/post/58396</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58396</guid><dc:creator><![CDATA[HayyatAli]]></dc:creator><pubDate>Mon, 01 Jul 2019 14:36:13 GMT</pubDate></item><item><title><![CDATA[Reply to Need help for building magic mirror from scratch on Mon, 01 Jul 2019 14:32:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nischi" aria-label="Profile: nischi">@<bdi>nischi</bdi></a><br />
Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/58395</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58395</guid><dc:creator><![CDATA[HayyatAli]]></dc:creator><pubDate>Mon, 01 Jul 2019 14:32:00 GMT</pubDate></item><item><title><![CDATA[Reply to Need help for building magic mirror from scratch on Mon, 01 Jul 2019 14:19:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hayyatali" aria-label="Profile: HayyatAli">@<bdi>HayyatAli</bdi></a></p>
<p dir="auto"><strong>Software:</strong><br />
<a href="https://github.com/MichMich/MagicMirror#manual-installation" target="_blank" rel="noopener noreferrer nofollow ugc">Here</a> you will find a good installation guide.</p>
<p dir="auto"><strong>Hardware:</strong><br />
I would suggest that you use a Raspberry Pi 3 or 4. (4 was just released, so maybe not in stock everywhere). And then you need a Display and a Mirror (2 Way Mirror / Spy Mirror). And finally build a frame where you can all put togheter.</p>
<p dir="auto">Checkout the Forum and you will find a lot examples.<br />
<a href="https://forum.magicmirror.builders/category/12/show-your-mirror">https://forum.magicmirror.builders/category/12/show-your-mirror</a></p>
<p dir="auto">Thats mine :)<br />
<a href="https://forum.magicmirror.builders/topic/10567/my-old-wood-mirror?page=1">https://forum.magicmirror.builders/topic/10567/my-old-wood-mirror?page=1</a></p>
]]></description><link>https://forum.magicmirror.builders/post/58394</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58394</guid><dc:creator><![CDATA[nischi]]></dc:creator><pubDate>Mon, 01 Jul 2019 14:19:33 GMT</pubDate></item></channel></rss>
