<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Calendar issue 2.8.0 - Repeating events]]></title><description><![CDATA[<p dir="auto">As of 2.8.0 - Google Calendar Items that repeat are displayed a day early. Non-repeating events are correct.</p>
<p dir="auto">This is my office calendar so I can’t share details other than that…</p>
]]></description><link>https://forum.magicmirror.builders/topic/10716/calendar-issue-2-8-0-repeating-events</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 14:15:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10716.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 03 Jul 2019 19:51:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Calendar issue 2.8.0 - Repeating events on Fri, 17 Jan 2020 20:07:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clubjack" aria-label="Profile: Clubjack">@<bdi>Clubjack</bdi></a> and others,</p>
<p dir="auto">I noticed this problem too.<br />
For instance my birthday lasted 2 days ( only got presents once though) and my wedding-day is one day forward  (which will upset my wife).<br />
The entries were made using Google Calendar (so not a calendar app that synchronizes with Google).<br />
I notice this since 2020, but that does not mean it did not happen before, could have overlooked it.<br />
When I ran a test with a dummy entry, it worked fine.<br />
When I toggle a „faulty“ entry from repeating to not repeating and then back to repeating, the entry is shown correct.<br />
I collected some data and will post it when I sorted it out a bit.</p>
]]></description><link>https://forum.magicmirror.builders/post/68258</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68258</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Fri, 17 Jan 2020 20:07:35 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar issue 2.8.0 - Repeating events on Fri, 17 Jan 2020 19:42:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clubjack" aria-label="Profile: Clubjack">@<bdi>Clubjack</bdi></a> sorry, I have not been looking at that problem…</p>
]]></description><link>https://forum.magicmirror.builders/post/68257</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68257</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 17 Jan 2020 19:42:26 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar issue 2.8.0 - Repeating events on Fri, 17 Jan 2020 19:28:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Something New here?</p>
<p dir="auto">Have a similar problem with recurring appointments.  However, these are not displayed to me one day earlier, but a day later.</p>
]]></description><link>https://forum.magicmirror.builders/post/68255</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/68255</guid><dc:creator><![CDATA[Clubjack]]></dc:creator><pubDate>Fri, 17 Jan 2020 19:28:46 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar issue 2.8.0 - Repeating events on Sat, 17 Aug 2019 03:47:17 GMT]]></title><description><![CDATA[<p dir="auto">there is a bug in the default calendar for repeating events.<br />
so far no-one has had the time to investigate and propose a solution</p>
]]></description><link>https://forum.magicmirror.builders/post/60161</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60161</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 17 Aug 2019 03:47:17 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar issue 2.8.0 - Repeating events on Fri, 16 Aug 2019 07:32:51 GMT]]></title><description><![CDATA[<p dir="auto">I also have an issue with my recurring google calendar events.  If the recurring event has a start time between 00:01 and 09:59, then the event shows up in the calendar with that start time plus 24hrs. So an Event on Monday at 07:00 will show up in the calendar on Tuesday at 07:00.<br />
Also all day events start at 20:30.  I wonder if this might be causing the time issues.<br />
The recurring events show correctly with MMM-MyCalendar.</p>
]]></description><link>https://forum.magicmirror.builders/post/60139</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/60139</guid><dc:creator><![CDATA[mad mike]]></dc:creator><pubDate>Fri, 16 Aug 2019 07:32:51 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar issue 2.8.0 - Repeating events on Wed, 07 Aug 2019 02:12:05 GMT]]></title><description><![CDATA[<p dir="auto">I too have repeating events from Google Calendar that show up on the standard MM Calendar module one day early.  One is to occur every Monday at 6:30-8:30 pm, another Wed same 6:30-8:30pm.  MM shows them as Sunday and Tuesday.</p>
<p dir="auto">I will try MMM-MyCalendar and see if they show up correctly…</p>
]]></description><link>https://forum.magicmirror.builders/post/59880</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59880</guid><dc:creator><![CDATA[dlindval]]></dc:creator><pubDate>Wed, 07 Aug 2019 02:12:05 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar issue 2.8.0 - Repeating events on Tue, 16 Jul 2019 22:57:03 GMT]]></title><description><![CDATA[<p dir="auto">So, I ended up changing to MMM-MyCalendar, because of this.</p>
<p dir="auto">The bug appears to be that the “calendar” module is processing repeating events for itself, rather than using the event as I have it, and getting that all wrong.</p>
<p dir="auto">For example, I have a monthly meeting (except July) repeated out, with July removed. It shows (on the day before) in July anyway.</p>
]]></description><link>https://forum.magicmirror.builders/post/59039</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59039</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Tue, 16 Jul 2019 22:57:03 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar issue 2.8.0 - Repeating events on Sun, 07 Jul 2019 05:00:11 GMT]]></title><description><![CDATA[<p dir="auto">I’m also having the same issue as we work variable shifts we use the Calendar on MM to know when to go to work</p>
]]></description><link>https://forum.magicmirror.builders/post/58630</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58630</guid><dc:creator><![CDATA[skippy_oz]]></dc:creator><pubDate>Sun, 07 Jul 2019 05:00:11 GMT</pubDate></item></channel></rss>
