<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Text Generator]]></title><description><![CDATA[<p dir="auto">So I am looking for a module (whether it is a new one or one that can be modified to suit my needs) I have a list of “phrases” I’d like to be able to click a button (I could use MMM-Remote Control for this ideally)  and the phrase appears on the mirror. I could use the compliments module for this but I have no idea how to just make one appear that I want when I want! Please let me know if you can help me with this!</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://forum.magicmirror.builders/topic/10728/text-generator</link><generator>RSS for Node</generator><lastBuildDate>Sun, 16 Aug 2026 02:08:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10728.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Jul 2019 17:03:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Text Generator on Mon, 02 Feb 2026 15:33:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/comedyclub" aria-label="Profile: comedyclub">@<bdi>comedyclub</bdi></a> One simple approach could be to adapt the compliments module and trigger specific phrases through a custom action instead of letting it rotate randomly. You could store your phrases in a list and map each one to a button or remote command so only the selected text shows on the mirror when you want it. That way it behaves more like an on demand text generator rather than an automatic cycle. I have seen people do similar things when experimenting with stylized outputs like brat text, so the logic should be flexible enough with a bit of customization.</p>
]]></description><link>https://forum.magicmirror.builders/post/129890</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/129890</guid><dc:creator><![CDATA[eddiebrok]]></dc:creator><pubDate>Mon, 02 Feb 2026 15:33:40 GMT</pubDate></item><item><title><![CDATA[Reply to Text Generator on Fri, 05 Jul 2019 22:53:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a> This is really close to what I’m looking for but not quite. I wanna sent instant notifications that pop up and dominate the screen similar to the alerts from the Remote control! Sorry to be a PITA</p>
]]></description><link>https://forum.magicmirror.builders/post/58595</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58595</guid><dc:creator><![CDATA[comedyclub]]></dc:creator><pubDate>Fri, 05 Jul 2019 22:53:13 GMT</pubDate></item><item><title><![CDATA[Reply to Text Generator on Fri, 05 Jul 2019 22:51:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a> Thank you!!</p>
]]></description><link>https://forum.magicmirror.builders/post/58594</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58594</guid><dc:creator><![CDATA[comedyclub]]></dc:creator><pubDate>Fri, 05 Jul 2019 22:51:00 GMT</pubDate></item><item><title><![CDATA[Reply to Text Generator on Fri, 05 Jul 2019 19:46:51 GMT]]></title><description><![CDATA[<p dir="auto">MMM-syslog can recieve whatever text you send it (via http get) and it will display directly on your mirror</p>
]]></description><link>https://forum.magicmirror.builders/post/58574</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58574</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Fri, 05 Jul 2019 19:46:51 GMT</pubDate></item></channel></rss>
