<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New user]]></title><description><![CDATA[<p dir="auto">I installed MM on a raspberry pi 3B+ using<br />
bash -c “$(curl -sL <a href="https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh</a>)”<br />
The magic mirror start but on a reboot the pi boots to its desktop<br />
I am completely new to this and would appreciate any help</p>
]]></description><link>https://forum.magicmirror.builders/topic/10730/new-user</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 13:34:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10730.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Jul 2019 20:06:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New user on Sat, 13 Jul 2019 14:07:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thedoorsfanatic" aria-label="Profile: thedoorsfanatic">@<bdi>thedoorsfanatic</bdi></a><br />
Yes and is working now</p>
]]></description><link>https://forum.magicmirror.builders/post/58868</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58868</guid><dc:creator><![CDATA[KenTP]]></dc:creator><pubDate>Sat, 13 Jul 2019 14:07:35 GMT</pubDate></item><item><title><![CDATA[Reply to New user on Sat, 06 Jul 2019 07:22:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kentp" aria-label="Profile: KenTP">@<bdi>KenTP</bdi></a></p>
<p dir="auto">I am a newbie myself and I have found everything I needed to run my mirror on this forum.  Just search for your problems.</p>
<p dir="auto">For me only the manual installation was working:<br />
<a href="https://github.com/MichMich/MagicMirror#automatic-installation-raspberry-pi-only" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror#automatic-installation-raspberry-pi-only</a></p>
<p dir="auto">Did you use the right installation command?</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> said in <a href="/post/55202">Anyone want to try updated installer...</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/55143">Anyone want to try updated installer...</a>:</p>
<p dir="auto">bash -c “$(curl -sL <a href="https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0</a>)”</p>
<p dir="auto">Just in case anyone else wants to test this,  don’t use the example in the original post. Try this instead:</p>
<p dir="auto"><code>bash -c "$(curl -sL https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0)"</code></p>
<p dir="auto">Did you use this script for auto starting the mirror?<br />
<a href="https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror</a></p>
]]></description><link>https://forum.magicmirror.builders/post/58602</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58602</guid><dc:creator><![CDATA[thedoorsfanatic]]></dc:creator><pubDate>Sat, 06 Jul 2019 07:22:41 GMT</pubDate></item><item><title><![CDATA[Reply to New user on Fri, 05 Jul 2019 20:44:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kentp" aria-label="Profile: KenTP">@<bdi>KenTP</bdi></a> so, post the output here for us to look at</p>
<p dir="auto">use three tildes ( left of 1) before the content and 3 after</p>
]]></description><link>https://forum.magicmirror.builders/post/58581</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58581</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 05 Jul 2019 20:44:31 GMT</pubDate></item><item><title><![CDATA[Reply to New user on Fri, 05 Jul 2019 20:43:34 GMT]]></title><description><![CDATA[<p dir="auto">I did as you say but it does not mean anything to me</p>
]]></description><link>https://forum.magicmirror.builders/post/58580</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58580</guid><dc:creator><![CDATA[KenTP]]></dc:creator><pubDate>Fri, 05 Jul 2019 20:43:34 GMT</pubDate></item><item><title><![CDATA[Reply to New user on Fri, 05 Jul 2019 20:36:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kentp" aria-label="Profile: KenTP">@<bdi>KenTP</bdi></a></p>
<p dir="auto">from the MagicMirror folder do</p>
<pre><code>pm2 list
pm2 logs
]]></description><link>https://forum.magicmirror.builders/post/58578</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58578</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 05 Jul 2019 20:36:45 GMT</pubDate></item></channel></rss>
