<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-SimpleTides stuck on loading]]></title><description><![CDATA[<p dir="auto">Got the api, got the long and lat and inputed all.<br />
Stuck on the loading message, First the tide rushes in.<br />
Can’t pinpoint which isn’t talking with the other. I did an npm install as well after all done. Any suggestions?</p>
]]></description><link>https://forum.magicmirror.builders/topic/10737/mmm-simpletides-stuck-on-loading</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 21:07:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10737.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 07 Jul 2019 18:05:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-SimpleTides stuck on loading on Tue, 09 Jul 2019 00:49:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chritix" aria-label="Profile: Chritix">@<bdi>Chritix</bdi></a></p>
<p dir="auto">Once you’ve signed in to your WorldTides account you have access to your settings (<a href="https://www.worldtides.info/settings" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.worldtides.info/settings</a>) which will show your API Key. The API Key is in this format. At least, mine is.</p>
<p dir="auto">12345678-1234-1234-1234-1234567890XX.</p>
<p dir="auto">MMM-SimpleTides is sort of deprecated, in that it has been incorporated into MMM-SORT. However, it should still be working. Now, MMM-SORT does everything SimpleTides does. It has better options for the user. I just fired it up and it is working as expected.</p>
<p dir="auto">EDIT</p>
<p dir="auto">I just ran MMM-SimpleTides. It also fires right up</p>
<pre><code>{
	disabled: false,
	module: "MMM-SimpleTides",
	position: "bottom_left",
		apiKey: "12345678-1234-1234-1234-1234567890XX",          // free from https://www.worldtides.info/developer
		lat: "40.111111",                // your latitude
		lon: "-74.111111",               // your longitude
		height: "ft",                    // ft = feet, m = meters
		useHeader: false,                // False if you don't want a header
		header: "",                      // Change in config file. useHeader must be true
		maxWidth: "300px",
		animationSpeed: 3000,            // fade speed
		rotateInterval: 15 * 1000,       // seconds between tides displayed
]]></description><link>https://forum.magicmirror.builders/post/58720</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58720</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 09 Jul 2019 00:49:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SimpleTides stuck on loading on Mon, 08 Jul 2019 01:23:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chritix" aria-label="Profile: Chritix">@<bdi>Chritix</bdi></a> no idea. Every API process is different.</p>
]]></description><link>https://forum.magicmirror.builders/post/58677</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58677</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 08 Jul 2019 01:23:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SimpleTides stuck on loading on Mon, 08 Jul 2019 01:00:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Yeah thats what I was leaning on. Is there a dfference between APPID and APIKEY? If the module requests one and the provider gives another, is there a translation?</p>
<p dir="auto">I copied an pasted the key given, plugged it in. The format was different then the weather api used (one long string). This one has dashes within it, would that bug out the coding language used?</p>
]]></description><link>https://forum.magicmirror.builders/post/58676</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58676</guid><dc:creator><![CDATA[Chritix]]></dc:creator><pubDate>Mon, 08 Jul 2019 01:00:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SimpleTides stuck on loading on Sun, 07 Jul 2019 21:17:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chritix" aria-label="Profile: Chritix">@<bdi>Chritix</bdi></a> sounds like the url or the key is wrong…</p>
]]></description><link>https://forum.magicmirror.builders/post/58668</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58668</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 07 Jul 2019 21:17:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SimpleTides stuck on loading on Sun, 07 Jul 2019 20:07:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Failed to load resource: the server responded with a stats of 400( )</p>
]]></description><link>https://forum.magicmirror.builders/post/58658</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58658</guid><dc:creator><![CDATA[Chritix]]></dc:creator><pubDate>Sun, 07 Jul 2019 20:07:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SimpleTides stuck on loading on Sun, 07 Jul 2019 18:31:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chritix" aria-label="Profile: Chritix">@<bdi>Chritix</bdi></a> should never edit the module.js</p>
]]></description><link>https://forum.magicmirror.builders/post/58651</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58651</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 07 Jul 2019 18:31:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SimpleTides stuck on loading on Sun, 07 Jul 2019 18:28:53 GMT]]></title><description><![CDATA[<p dir="auto">I’ve also tried to install MMM-Worldtides.<br />
It throws back an error saying: please set the correct <a href="http://worldtides.info" target="_blank" rel="noopener noreferrer nofollow ugc">worldtides.info</a> appid in the config.<br />
I’ve copy and pasted the apps for <a href="http://worldtides.info" target="_blank" rel="noopener noreferrer nofollow ugc">worldtides.info</a>, I have  100 credits.<br />
the format is <strong><strong><strong>-</strong></strong>-</strong><strong>-</strong><strong>-</strong>*******<br />
I’ve tried removing the dashes but no change. I’ve put the apps in both config and worldtides.js, no change.<br />
Thank you for any help given.</p>
]]></description><link>https://forum.magicmirror.builders/post/58649</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58649</guid><dc:creator><![CDATA[Chritix]]></dc:creator><pubDate>Sun, 07 Jul 2019 18:28:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SimpleTides stuck on loading on Sun, 07 Jul 2019 18:18:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chritix" aria-label="Profile: Chritix">@<bdi>Chritix</bdi></a> loading means the hard coded startup message is there, but no new data has come in</p>
<p dir="auto">open the developers console on the mirror,. ctrl-shift-i, select the console tab, and scroll up to see any errors (usually in red text)</p>
]]></description><link>https://forum.magicmirror.builders/post/58645</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58645</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 07 Jul 2019 18:18:09 GMT</pubDate></item></channel></rss>
