<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Changing fontsize causes text to overlap itself when stacked]]></title><description><![CDATA[<p dir="auto">Heya, when I edit the custom.css to make the text larger it eventually starts overlapping itself when the text is long enough to occupy two rows or more.</p>
<p dir="auto">Ive looked aroud in most of the files but cant find a solution. Any ideas?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/10746/changing-fontsize-causes-text-to-overlap-itself-when-stacked</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 22:02:51 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10746.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 Jul 2019 01:12:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Changing fontsize causes text to overlap itself when stacked on Tue, 09 Jul 2019 03:53:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> that did it thanks a lot :)</p>
]]></description><link>https://forum.magicmirror.builders/post/58727</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58727</guid><dc:creator><![CDATA[hefal]]></dc:creator><pubDate>Tue, 09 Jul 2019 03:53:53 GMT</pubDate></item><item><title><![CDATA[Reply to Changing fontsize causes text to overlap itself when stacked on Tue, 09 Jul 2019 01:34:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hefal" aria-label="Profile: hefal">@<bdi>hefal</bdi></a> the font vertical spacing needs to be increased.</p>
<p dir="auto">I don’t know how to do it myself…</p>
<p dir="auto">letter-spacing and line-height from Google search</p>
]]></description><link>https://forum.magicmirror.builders/post/58725</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58725</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 09 Jul 2019 01:34:56 GMT</pubDate></item><item><title><![CDATA[Reply to Changing fontsize causes text to overlap itself when stacked on Tue, 09 Jul 2019 01:23:38 GMT]]></title><description><![CDATA[<p dir="auto">Well, not really.</p>
<p dir="auto">In a perfect world id like it not to overlap once it switches rows. Ive got my mirror in a vertical setup which limits the width so most texts will require multiple rows.</p>
<p dir="auto">Pic:<br />
<img src="https://i.imgur.com/OErLLsD.png" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/58723</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58723</guid><dc:creator><![CDATA[hefal]]></dc:creator><pubDate>Tue, 09 Jul 2019 01:23:38 GMT</pubDate></item><item><title><![CDATA[Reply to Changing fontsize causes text to overlap itself when stacked on Tue, 09 Jul 2019 01:16:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hefal" aria-label="Profile: hefal">@<bdi>hefal</bdi></a> that’s what happens.</p>
<p dir="auto">Do u want to shorten the text?<br />
What text are you seeing?</p>
]]></description><link>https://forum.magicmirror.builders/post/58722</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58722</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 09 Jul 2019 01:16:22 GMT</pubDate></item></channel></rss>
