<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[calendar plugin: all items one day ahead]]></title><description><![CDATA[<p dir="auto">Dear all</p>
<p dir="auto">The calendar plugin shows items on wrong date. The problem appears with multiple caldav calendars from different sources.  An Item which is scheduled for tomorrow appears to be due for the day after tomorrow. All other plugins like the clock are showing correct date + time</p>
<p dir="auto">I did some more digging and changed the timeFormat to “date headers” interestingly the plugin shows actually a wrong date. For example a item which is in the ical file for the 9th appears to be due on the 10th.</p>
<p dir="auto">This problem occurred once I updated the installation. Previously I was running a version dating back to April. Problem occurred without touching the config.js</p>
<p dir="auto"><a href="https://github.com/MichMich/MagicMirror/issues/1718" target="_blank" rel="noopener noreferrer nofollow ugc">I also added a bug report on git</a></p>
<p dir="auto">It would be great if someone could help me out getting this fixed</p>
]]></description><link>https://forum.magicmirror.builders/topic/10751/calendar-plugin-all-items-one-day-ahead</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 03:29:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/10751.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 Jul 2019 21:23:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to calendar plugin: all items one day ahead on Sun, 20 Dec 2020 18:37:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anderios" aria-label="Profile: anderios">@<bdi>anderios</bdi></a> i have worked for the last 3 months to get the calendar module working properly. I think I have solved all the reported problems.</p>
<p dir="auto">the fixes will be released on Jan 1, but in the meantime you can use the develop branch of the repo which has all the accepted fixes since last release</p>
]]></description><link>https://forum.magicmirror.builders/post/85935</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85935</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 20 Dec 2020 18:37:46 GMT</pubDate></item><item><title><![CDATA[Reply to calendar plugin: all items one day ahead on Sun, 20 Dec 2020 18:06:03 GMT]]></title><description><![CDATA[<p dir="auto">Something has been done wrong from your side, I will not be able to check it from <a href="https://mylistcrawler.com/" target="_blank" rel="noopener noreferrer nofollow ugc">my sources</a>. You can try the following thing. Uninstall the plugin completely and then download it again. It should work this time. If the mistake is there again, then it must be something incorrect with the code. And you will not be able to amend anything on your own. You should report the problem to developers.</p>
]]></description><link>https://forum.magicmirror.builders/post/85931</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85931</guid><dc:creator><![CDATA[anderios]]></dc:creator><pubDate>Sun, 20 Dec 2020 18:06:03 GMT</pubDate></item><item><title><![CDATA[Reply to calendar plugin: all items one day ahead on Fri, 18 Dec 2020 23:37:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anderios" aria-label="Profile: anderios">@<bdi>anderios</bdi></a> download the develop branch  which has a bunch  of calendar fixes.  see the office 365 topic at the top of the troubleshooting section</p>
]]></description><link>https://forum.magicmirror.builders/post/85857</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85857</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 18 Dec 2020 23:37:03 GMT</pubDate></item><item><title><![CDATA[Reply to calendar plugin: all items one day ahead on Fri, 18 Dec 2020 22:27:03 GMT]]></title><description><![CDATA[<p dir="auto">what about in 2020?</p>
]]></description><link>https://forum.magicmirror.builders/post/85855</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85855</guid><dc:creator><![CDATA[anderios]]></dc:creator><pubDate>Fri, 18 Dec 2020 22:27:03 GMT</pubDate></item><item><title><![CDATA[Reply to calendar plugin: all items one day ahead on Thu, 11 Jul 2019 06:26:09 GMT]]></title><description><![CDATA[<p dir="auto">For the record: I rolled back the default calendar plugin to the previous release (April) an the problem is solved. There seems to be something wrong with the latest release</p>
]]></description><link>https://forum.magicmirror.builders/post/58782</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58782</guid><dc:creator><![CDATA[Kugelfang]]></dc:creator><pubDate>Thu, 11 Jul 2019 06:26:09 GMT</pubDate></item></channel></rss>
